Basic Usage
FormKit exposes a single component as its public API: <Form />. All other elements are yielded as contextual components, modifiers, or plain data.
Every form is composed of one or multiple fields, representing the value, validation, and metadata of a control. Each field encapsulates a control, which is the form element the user interacts with to enter data, such as an input or select. The control type is specified via @type on the field. Other utilities, like submit or alert, are also provided.
Here is the most basic example of a form:
import Component from "@glimmer/component";
import { action } from "@ember/object";
import Form from "discourse/components/form";
export default class MyForm extends Component {
@action
handleSubmit(data) {
// do something with data
<template>
<Form @onSubmit={{this.handleSubmit}} as |form|>
<form.Field
@name="username"
@title="Username"
@validation="required"
@type="input"
as |field|
<field.Control />
</form.Field>
<form.Field @name="age" @title="Age" @type="input-number" as |field|>
<field.Control />
</form.Field>
<form.Submit />
</Form>
</template>
Form
Yielded Parameters
form
The Form component yields a form object containing components and helpers.
Example
<Form as |form|>
<form.Row as |row|>
</form.Row>
</Form>
transientData
transientData represents the state of the data at a given time as itās represented in the form, and not yet propagated to @data.
This is useful if you want to have conditionals in your form based on other fields.
Example
<Form as |form transientData|>
<form.Field @name="amount" @type="input-number" as |field|>
<field.Control />
</form.Field>
{{#if (gt transientData.amount 200)}}
<form.Field @name="confirmed" @type="checkbox" as |field|>
<field.Control>I know what I'm doing</field.Control>
</form.Field>
{{/if}}
</Form>
Properties
@data
Initial state of the data you give to the form.
The keys matching the @names of the formās fields will be prepopulated.
@datais treated as an immutable object, following Emberās DDAU pattern. This means when the user enters new data for any of the fields, it will not cause a mutation of@data! You can mutate your initial object using@onSet.
When working with an object object we recommend to setup your form data object like this:
@cached
get formData() {
return getProperties(this.model, "foo", "bar", "baz");
Parameter
data(Object): The data object passed to the template.
Example
<Form @data={{hash foo="bar"}} as |form|>
<form.Field @name="foo" @type="input" as |field|>
<!-- This input will have "bar" as its initial value -->
<field.Control />
</form.Field>
</Form>
@onRegisterApi
Callback called when the form is inserted. It allows the developer to interact with the form through JavaScript.
Parameters
callback(Object): The object containing callback functions.callback.submit(Function): Function to submit the form.callback.reset(Function): Function to reset the form.callback.set(Function): Function to set a key/value on the form data object.callback.setProperties(Function): Function to set an object on the form data object.callback.isDirty(boolean): Tracked property return the state of the form. It will be true once changes have been done on the form. Resetting the changes will bring it back to false.
Example
registerAPI({ submit, reset, set }) {
// Interact with the form API
submit();
reset();
set("foo", 1);
<Form @onRegisterApi={{this.registerAPI}} />
@onSubmit
Callback called when the form is submitted and valid.
Parameters
data(Object): The object containing the form data.
Example
handleSubmit({ username, age }) {
console.log(username, age);
<form.Field @name="username" @type="input" as |field|>
<field.Control />
</form.Field>
<form.Field @name="age" @type="input-number" as |field|>
<field.Control />
</form.Field>
<form.Submit />
</Form>
@validate
A custom validation callback added directly to the form.
Example
@action
myValidation(data, { addError }) {
if (data.foo !== data.bar) {
addError("foo", { title: "Foo", message: "Bar must be equal to Foo" });
<Form @validate={{this.myValidation}} />
An asynchronous example:
@action
async myValidation(data, { addError }) {
try {
await ajax("/check-username", {
type: "POST",
data: { username: data.username }
} catch(e) {
addError("username", { title: "Username", message: "Already taken!" });
Field
@name
A field must have a unique name. This name is used to set the value on the data object and is also used for validation.
Example
<form.Field @name="foo" />
@title
A field must have a title. It will be displayed above the control and is also used in validation.
Example
<form.Field @title="Foo" />
@type
A field must have a type. This determines which control component is rendered. The available types are:
- Input types:
input(defaults to text),input-number,input-email,input-password,input-url,input-tel,input-date,input-time,input-datetime-local,input-color,input-month,input-week,input-range,input-search,input-hidden - Other controls:
checkbox,code,calendar,color,composer,custom,emoji,icon,image,menu,password,question,radio-group,select,tag-chooser,textarea,toggle
Example
<form.Field @name="foo" @type="input" />
@description
The description is optional and will be shown under the title when set.
Example
<form.Field @description="Bar" />
@helpText
The help text is optional and will be shown under the field when set.
Example
<form.Field @helpText="Baz" />
@showTitle
By default, the title will be shown on top of the control. You can choose not to render it by setting this property to false.
Example
<form.Field @showTitle={{false}} />
@disabled
A field can be disabled to prevent any changes to it.
Example
<form.Field @disabled={{true}} />
@tooltip
Allows to display a tooltip next to the fieldās title. Wonāt display if title is not shown.
You can pass a string or a <DTooltip /> component.
Example
<Form as |form|>
<form.Field
@name="foo"
@title="Foo"
@type="input"
@tooltip="a nice input"
as |field|
<field.Control />
</form.Field>
</Form>
<Form as |form|>
<form.Field
@name="foo"
@title="Foo"
@type="input"
@tooltip={{component DTooltip content="a nice input"}}
as |field|
<field.Control />
</form.Field>
</Form>
@validation
Read the dedicated validation section.
@validate
Read the dedicated custom validation section.
@onSet
By default, when changing the value of a field, this value will be set on the formās internal data object. However, you can choose to have full control over this process for a field.
Example
@action
handleFooChange(value, { set }) {
set("foo", value + "-bar");
<form.Field
@name="foo"
@type="input"
@onSet={{this.handleFooChange}}
as |field|
<field.Control />
</form.Field>
You can use
@onSetto also mutate the initial data object if you need more reactivity for a specific case.
Example
@action
this.model.foo = value + "-bar";
<Form @data={{this.model}} as |form|>
<form.Field
@name="foo"
@type="input"
as |field|
<field.Control />
</form.Field>
</Form>
Yielded Parameters
The field yields a single field object. The control component determined by @type is available as field.Control.
<field.Control />
</form.Field>
field.Control
field.Control is the control component determined by @type. You can pass control-specific attributes directly to it (e.g., @height, @lang, placeholder).
field
The yielded field object provides access to the fieldās data and helpers:
| Name | Description |
Control |
Contextual component for the control set by @type |
id |
ID to be used on the control for accessibility |
name |
Name of the field |
value |
The value of the field |
set |
Function to set the fieldās value |
Controls
Controls, as we use the term here, refer to the UI widgets that allow a user to enter data. In its most basic form, this would be an input. The control type is specified via @type on the field.
You can pass down HTML attributes to the underlying control.
Example
<Form as |form|>
<form.Field
@name="query"
@title="Query"
@type="input"
@description="You should make sure the query doesn't include bots."
as |field|
<field.Control placeholder="Foo" />
</form.Field>
</Form>
@format
Controls accept a @format property which can be: small, medium, large, or full.
Form Kit sets defaults for each control, but you can override them using @format:
- small:
100px - medium:
220px - large:
400px - full:
100%
Additionally, the following CSS variables are provided to customize these defaults:
- small:
--form-kit-small-input - medium:
--form-kit-medium-input - large:
--form-kit-large-input
@titleFormat
Allows to override @format for the title. See @format for details.
@descriptionFormat
Allows to override @format for the description. See @format for details.
Checkbox
Renders an <input type="checkbox"> element.
When to use a single checkbox
There are only 2 options: yes/no. It feels like agreeing to something. Checking the box doesnāt save; there is a submit button further down.
Example
<Form as |form|>
<form.Field @name="approved" @title="Approved" @type="checkbox" as |field|>
<field.Control />
</form.Field>
</Form>
Code
Renders an <AceEditor /> component.
@height
Sets the height of the editor.
@lang
Sets the language of the editor.
Example
<Form as |form|>
<form.Field @name="query" @title="Query" @type="code" as |field|>
<field.Control @lang="sql" @height={{400}} />
</form.Field>
</Form>
Calendar
Renders a datepicker and a time input. On mobile the datepicker will be replaced by a date input.
@includeTime
Displays the time input or not. Defaults to true.
Example
<Form as |form|>
<form.Field @name="start" @title="Start" @type="calendar" as |field|>
<field.Control @includeTime={{false}} />
</form.Field>
</Form>
@expandedDatePickerOnDesktop
Displays date picker expanded on desktop. Defaults to true.
Example
<Form as |form|>
<field.Control @expandedDatePickerOnDesktop={{false}} />
</form.Field>
</Form>
Composer
Renders a <DEditor /> component.
@height
Sets the height of the composer.
Example
<Form as |form|>
<form.Field @name="message" @title="Message" @type="composer" as |field|>
<field.Control @height={{400}} />
</form.Field>
</Form>
@preview
Controls the display the composer preview. Defaults to false.
Example
<Form as |form|>
<field.Control @preview={{true}} />
</form.Field>
</Form>
Icon
Renders an <IconPicker /> component.
Example
<Form as |form|>
<form.Field @name="icon" @title="Icon" @type="icon" as |field|>
<field.Control />
</form.Field>
</Form>
Renders an <UppyImageUploader /> component.
Upload Handling
By default, the component will set an upload object. Itās common to only want the URL and the ID of the upload. To achieve this, you can use the @onSet property on the field:
@action
handleUpload(upload, { set }) {
set("upload_id", upload.id);
set("upload_url", getURL(upload.url));
<Form as |form|>
<form.Field
@name="upload"
@title="Upload"
@type="image"
@onSet={{this.handleUpload}}
as |field|
<field.Control />
</form.Field>
</Form>
Example
<Form as |form|>
<form.Field @name="upload" @title="Upload" @type="image" as |field|>
<field.Control />
</form.Field>
</Form>
Input
Renders an <input> element.
@type
The input variant is specified as part of the fieldās @type using the input- prefix. For example, @type="input", @type="input-number", etc. @type="input" defaults to text.
Allowed Types
input(defaults to text)input-colorinput-dateinput-datetime-localinput-emailinput-hiddeninput-monthinput-numberinput-passwordinput-rangeinput-searchinput-telinput-timeinput-urlinput-week
Special Cases
fileis supported only for images through image- checkbox
Examples
<Form as |form|>
<form.Field @name="email" @title="Email" @type="input" as |field|>
<field.Control />
</form.Field>
<field.Control />
</form.Field>
</Form>
@before
Renders text before the input
Examples
<Form as |form|>
<field.Control @before="mailto:" />
</form.Field>
</Form>
@after
Renders text after the input
Examples
<Form as |form|>
<field.Control @after=".com" />
</form.Field>
</Form>
Menu
Renders a component.
@selection
The text to show on the trigger.
yielded parameters
Item
Renders a selectable row. Accepts @value, @icon and @action props.
- @value: allows to assign a value to a row.
- @icon: shows an icon at the start of the row.
- @action: override the default action which would set the value of the field with the value of this row.
The content will be yielded.
Divider
Renders a separator.
Container
Renders a div which will have for content the yielded content.
Examples
<Form as |form|>
<form.Field @name="email" @title="Email" @type="menu" as |field|>
<field.Control as |menu|>
<menu.Item @value={{1}} @icon="pencil-alt">Edit</menu.Item>
<menu.Divider />
<menu.Container class="foo">
Bar
</menu.Container>
<menu.Item @action={{this.doSomething}}>Something</menu.Item>
</field.Control>
</form.Field>
</Form>
Password
Renders an <input /> of type password. This control also includes a button which will allow to toggle the visibility of the text. When toggle the type of the input will be switched to text.
Example
<Form as |form|>
<form.Field @name="secret" @title="Secret" @type="password" as |field|>
<field.Control />
</form.Field>
</Form>
Question
Renders two inputs of type radio where the first one is a positive answer, the second one a negative answer.
@yesLabel
Allows to customize the positive label.
@noLabel
Allows to customize the negative label.
Examples
<Form as |form|>
<form.Field @name="email" @title="Email" @type="question" as |field|>
<field.Control @yesLabel="Correct" @noLabel="Wrong" />
</form.Field>
</Form>
RadioGroup
Renders a list of radio buttons sharing a common name.
Example
<Form as |form|>
<form.Field @name="foo" @title="Foo" @type="radio-group" as |field|>
<field.Control as |radioGroup|>
<radioGroup.Radio @value="one">One</radioGroup.Radio>
<radioGroup.Radio @value="two">Two</radioGroup.Radio>
<radioGroup.Radio @value="three">Three</radioGroup.Radio>
</field.Control>
</form.Field>
</Form>
Radio yielded parameters
Title
Allows to render a title.
Examples
<Form as |form|>
<field.Control as |RadioGroup|>
<RadioGroup.Radio @value="one" as |radio|>
<radio.Title>One title</radio.Title>
</RadioGroup.Radio>
</field.Control>
</form.Field>
</Form>
Description
Allows to render a description.
Examples
<Form as |form|>
<radio.Description>One description</radio.Description>
</RadioGroup.Radio>
</field.Control>
</form.Field>
</Form>
Select
Renders a <select> element.
Example
<Form as |form|>
<form.Field @name="fruits" @title="Fruits" @type="select" as |field|>
<field.Control as |select|>
<select.Option @value="1">Mango</select.Option>
<select.Option @value="2">Apple</select.Option>
<select.Option @value="3">Coconut</select.Option>
</field.Control>
</form.Field>
</Form>
Text
Renders a <textarea> element.
@height
Sets the height of the textarea.
Example
<Form as |form|>
<form.Field
@name="description"
@title="Description"
@type="textarea"
as |field|
<field.Control @height={{120}} />
</form.Field>
</Form>
Toggle
Renders a <DToggleSwitch /> component.
There are only 2 states: enabled/disabled. It should feel like turning something on. Toggling takes effect immediately, there is no submit button.
Example
<Form as |form|>
<form.Field @name="allowed" @title="Allowed" @type="toggle" as |field|>
<field.Control />
</form.Field>
</Form>
Layout
Form Kit aims to provide good defaults, allowing you to mainly use fields and controls. However, if you need more control, we provide several helpers: Row and Col, Section, Fieldset, Container and Actions.
You can also use utilities like Submit, Reset,Alert and InputGroup.
Actions
Actions is a custom Container designed to wrap your buttons in the footer of your form.
Example
<Form as |form|>
<form.Actions>
<form.Submit />
</form.Actions>
</Form>
Alert
Displays an alert in the form.
@icon
An optional icon to use in the alert.
Example
<form.Alert @icon="info-circle">
Foo
</form.Alert>
@type
Specifies the type of alert. Allowed types: success, error, warning, or info.
Example
<form.Alert @type="warning">
Foo
</form.Alert>
Checkbox Group
CheckboxGroup allows grouping checkboxes together.
Example
<form.CheckboxGroup @title="Preferences" as |group|>
<group.Field @name="editable" @title="Editable" @type="checkbox" as |field|>
<field.Control />
</group.Field>
<group.Field
@name="searchable"
@title="Searchable"
@type="checkbox"
as |field|
<field.Control />
</group.Field>
</form.CheckboxGroup>
Container
Container allows you to render a block similar to a field without tying it to specific data. It is useful for custom controls.
Example
<Form as |form|>
<form.Container @title="Important" @subtitle="This is important">
<!-- Container content here -->
</form.Container>
</Form>
Fieldset
Wraps content in a fieldset.
Example
<form.Fieldset @name="a-fieldset" class="my-fieldset">
Foo
</form.Fieldset>
@title
Displays a title for the fieldset, will use the legend element.
Example
<form.Fieldset @title="A title">
Foo
</form.Fieldset>
@description
Displays a description for the fieldset.
Example
<form.Fieldset @description="A description">
Foo
</form.Fieldset>
@name
Sets the name of the fieldset. This is necessary if you want to use the fieldset test helpers.
Example
<form.Fieldset @name="a-name">
Foo
</form.Fieldset>
Input Group
Input group allows to group multiple inputs together on one line.
Example
<Form as |form|>
<form.InputGroup as |inputGroup|>
<inputGroup.Field @title="Foo" @name="foo" @type="input" as |field|>
<field.Control />
</inputGroup.Field>
<inputGroup.Field @title="Bar" @name="bar" @type="input" as |field|>
<field.Control />
</inputGroup.Field>
</form.InputGroup>
</Form>
Reset
The Reset component renders a <DButton /> which will reset the form when clicked. It accepts all the same parameters as a standard <DButton />. The label and default action are set by default.
Example
<form.Reset />
To customize the Reset button further, you can pass additional parameters as needed:
Example with Additional Parameters
<form.Reset @translatedLabel="Remove changes" />
Row and Col
Row and Col enable you to utilize a simple grid system (12 columns) within your form.
Example
<Form as |form|>
<form.Row as |row|>
<row.Col @size={{4}}>
<form.Field @name="foo" @title="Foo" @type="input" as |field|>
<field.Control />
</form.Field>
</row.Col>
<row.Col @size={{8}}>
<form.Field @name="bar" @title="Bar" @type="input" as |field|>
<field.Control />
</form.Field>
</row.Col>
</form.Row>
</Form>
Section
Section provides a simple way to create a section with or without a title.
Example
<Form as |form|>
<form.Section @title="Settings">
<!-- Section content here -->
</form.Section>
</Form>
Submit
The Submit component renders a <DButton /> which will submit the form when clicked. It accepts all the same parameters as a standard <DButton />. The label, default action, and primary style are set by default.
Example
<form.Submit />
To customize the Submit button further, you can pass additional parameters as needed:
<form.Submit @translatedLabel="Send" />
Object
The object component allows to handle an object in your form.
Example
<Form @data={{hash foo=(hash bar=1 baz=2)}} as |form|>
<form.Object @name="foo" as |object data|>
<object.Field @name="bar" @title="Bar" @type="input" as |field|>
<field.Control />
</object.Field>
<object.Field @name="baz" @title="Baz" @type="input" as |field|>
<field.Control />
</object.Field>
</form.Object>
</Form>
@name
An object must have a unique name. This name is used as a prefix for the underlying fields.
Example
<form.Object @name="foo" />
Nesting
An object can accept a nested Object or Collection.
Example
<Form @data={{hash foo=(hash bar=(hash baz=1 bol=2))}} as |form|>
<form.Object @name="foo" as |parentObject|>
<parentObject.Object @name="bar" as |childObject data|>
<childObject.Field @name="baz" @title="Baz" @type="input" as |field|>
<field.Control />
</childObject.Field>
</parentObject.Object>
</form.Object>
</Form>
<Form @data={{hash foo=(hash bar=(array 1 2))}} as |form|>
<parentObject.Collection @name="bar" as |collection index|>
<collection.Field @title="Baz" @type="input" as |field|>
<field.Control />
</collection.Field>
<form.Button
class={{concat "remove-" index}}
@action={{fn collection.remove index}}
>Remove</form.Button>
</parentObject.Collection>
</form.Object>
</Form>
Collection
The collection component allows to handle array of objects in your form.
Example
<Form @data={{hash foo=(array (hash bar=1) (hash bar=2))}} as |form|>
<form.Collection @name="foo" as |collection index|>
<collection.Field @name="bar" @title="Bar" @type="input" as |field|>
<field.Control placeholder={{concat "item-" index}} />
</collection.Field>
</form.Collection>
</Form>
@name
A collection must have a unique name. This name is used as a prefix for the underlying fields.
For example, if collection has the name āfooā, the 2nd field of the collection with the name ābarā, will actually have āfoo.1.barā as name.
Example
<form.Collection @name="foo" />
@tagName
A collection will by default render as a <div class="form-kit__collection>, you can alter this behavior by using a @tagName.
Example
<form.Collection @name="foo" @tagName="tr" />
Primitive array
If the shape of your data is an array of primitives, eg: [1, 2, 3], form-kit is able to handle it. You just have to omit the name on the field in this case, as the name will be auto generated for you with the index.
Example
<Form @data={{hash foo=(array 1 2)}} as |form|>
<form.Collection @name="foo" as |collection|>
<field.Control />
</collection.Field>
</form.Collection>
</Form>
Nesting
A collection can accept a nested Object or Collection.
Example
<Form
@data={{hash foo=(array (hash bar=(hash baz=1)) (hash bar=(hash baz=2)))}}
as |form|
<collection.Object @name="bar" as |object|>
<field.Control />
</object.Field>
</collection.Object>
</form.Collection>
</Form>
<Form
@data={{hash
foo=(array (hash bar=(array (hash baz=1))) (hash bar=(array (hash baz=2))))
as |form|
<form.Collection @name="foo" as |parent parentIndex|>
<parent.Collection @name="bar" as |child childIndex|>
<child.Field @name="baz" @title="Baz" @type="input" as |field|>
<field.Control />
</child.Field>
</parent.Collection>
</form.Collection>
</Form>
Add an item to the collection
The <Form /> component yielded object has a addItemToCollection function that you can call to add an item to a specific collection.
Example
<form.Button @action={{fn form.addItemToCollection "foo" (hash bar=3)}}>
Add
</form.Button>
</collection.Field>
</form.Collection>
</Form>
Remove an item from the collection
The <Collection /> component yielded object has a remove function that you can call to remove an item from this collection, it takes the index as parameter
Example
<field.Control />
<form.Button @action={{fn collection.remove index}}>
Remove
</form.Button>
</collection.Field>
</form.Collection>
</Form>
Validation
Field accepts a @validation property which allows you to describe the validation rules of the field.
List of Available Rules
Accepted
The value must be "yes", "on", true, 1, or "true". Useful for checkbox inputs ā often where you need to validate if someone has accepted terms.
Example
<form.Field @name="terms" @type="checkbox" @validation="accepted" as |field|>
<field.Control />
</form.Field>
Length
Checks that the inputās value is over a given length, or between two length values.
Example
<form.Field @name="username" @type="input" @validation="length:5,16" as |field|>
<field.Control />
</form.Field>
Number
Checks if the input is a valid number as evaluated by isNaN().
When applicable, prefer to use the number input:
@type="input-number".
Example
<form.Field @name="amount" @type="input" @validation="number" as |field|>
<field.Control />
</form.Field>
Required
Checks if the input is empty.
Example
<form.Field @name="username" @type="input" @validation="required" as |field|>
<field.Control />
</form.Field>
URL
Checks if the input value appears to be a properly formatted URL including the protocol. This does not check if the URL actually resolves.
Example
<form.Field @name="endpoint" @type="input-url" @validation="url" as |field|>
<field.Control />
</form.Field>
integer
Checks if the input value is an integer.
Example
<form.Field @name="age" @type="input-number" @validation="integer" as |field|>
<field.Control />
</form.Field>
dateAfterOrEqual
Checks if the calendar data is after or equal to the specified date. Format must be YYYY-MM-DD.
Example
<form.Field
@name="start"
@type="calendar"
@validation="dateAfterOrEqual:2022-02-01"
as |field|
<field.Control />
</form.Field>
dateBeforeOrEqual
Checks if the calendar data is before or equal to the specified date. Format must be YYYY-MM-DD.
Example
<form.Field
@name="start"
@type="calendar"
@validation="dateBeforeOrEqual:2022-02-01"
as |field|
<field.Control />
</form.Field>
Combining Rules
Rules can be combined using the pipe operator: |.
Example
<form.Field
@name="username"
@type="input"
@validation="required|length:5,16"
as |field|
<field.Control />
</form.Field>
Custom Validation
Field
Field accepts a @validate property which allows you to define a callback function to validate the field. Read more about addError in helpers section.
Parameters
name(string): The name of the form field being validated.value(string): The value of the form field being validated.data(Object): The data object containing additional information for validation.handlers(Object): An object containing handler functions.handlers.addError(Function): A function to add an error if validation fails.
Example
validateUsername(name, value, data, { addError }) {
if (data.bar / 2 === value) {
addError(name, { title: I18n.t(`foo.bar.${name}`), message: "That's not how maths work." });
<form.Field @name="username" @validate={{this.validateUsername}} />
Form
Form accepts a @validate property which allows you to define a callback function to validate the form. This will be called for each field of the form.
Parameters
Example
validateForm(data, { addError }) {
if (data.bar / 2 === data.baz) {
<Form @validate={{this.validateForm}} />
Helpers
Helpers are yielded by some blocks, like Form, or provided as parameters to callbacks. They allow you to interact with the form state in a simple and clear way.
set
set allows you to assign a value to a specific field in the formās data.
Parameters
name(string): The name of the field to which the value is to be set.value(number): The value to be set.
Example
set("foo", 1);
Using the set helper yielded by the form:
<Form as |form|>
<DButton @action={{fn form.set "foo" 1}} @translatedLabel="Set foo" />
</Form>
setProperties
setProperties allows you to assign an object to the formās data.
Parameters
data(object): A POJO where each key is going to be set on the form using its value.
Example
setProperties({ foo: 1, bar: 2 });
Using the setProperties helper yielded by the form:
<Form as |form|>
<DButton
@action={{fn form.setProperties (hash foo=1 bar=2)}}
@translatedLabel="Set foo and bar"
</Form>
addError
addError allows you to add an error message to a specific field in the form.
Parameters
name(string): The name of the field that is invalid.error(object): The errorās datatitle(string): The title of the error, usually the translated name of the fieldmessage(string): The error message
Example
addError("foo", { title: "Foo", message: "This should be another thing." });
Customize
Plugin Outlets
FormKit works seamlessly with <PluginOutlet />. You can use plugin outlets inside your form to extend its functionality:
<Form as |form|>
<PluginOutlet @name="above-foo-form" @outletArgs={{hash form=form}} />
</Form>
Then, in your connector, you can use the outlet arguments to add custom fields:
<@outletArgs.form.Field @name="bar" @type="input" as |field|>
<field.Control />
</@outletArgs.form.Field>
Styling
All FormKit components propagate attributes, allowing you to set classes and data attributes, for example:
<Form class="my-form" as |form|>
<form.Field @name="foo" @type="input" class="my-field" as |field|>
<field.Control class="my-control" />
</form.Field>
</Form>
Custom Control
Creating a custom control is straightforward with the properties yielded by form and field:
<Form as |form|>
<form.Field @type="custom" class="my-field" as |field|>
<field.Control>
<MyCustomControl id={{field.id}} @onChange={{field.set}} />
</field.Control>
</form.Field>
</Form>
Available Parameters on form
set |
Allows you to set the value of any field by name: set("bar", 1) |
Custom Validation
Field
The Field component accepts a @validate property, allowing you to define a callback function for custom field validation. Read more about addError in the helpers section.
Parameters
Example
Form
The Form component accepts a @validate property, allowing you to define a callback function for custom form validation.
Parameters
Example
Javascript assertions
Form
The form element assertions are available at assert.form(...).*. By default it will select the first āformā element.
Parameters
target(string | HTMLElement): The form element or selector.
hasErrors()
Asserts that the form has errors.
Parameters
message(string): The description of the test.
Example
assert.form().hasErrors("the form shows errors");
Field
The field element assertions are available at assert.form(...).field(...).*.
Parameters
name(string): The name of the field.
Example
assert.form().field("foo");
hasValue()
Asserts that the value of the field matches the expected text.
Parameters
expected(anything): The expected value.message(string) [optional]: The description of the test.
Example
assert.form().field("foo").hasValue("bar", "user has set the value");
isDisabled()
Asserts that the field is disabled.
Parameters
Example
assert.form().field("foo").isDisabled("the field is disabled");
isEnabled()
Asserts that the field is enabled.
Parameters
Example
assert.form().field("foo").isEnabled("the field is enabled");
hasError()
Asserts that the field has a specific error.
Parameters
error(string): The error message on the field.message(string) [optional]: The description of the test.
Example
assert.form().field("foo").hasError("Required", "it is required");
hasNoErrors()
Asserts that the field has no error.
Parameters
Example
assert.form().field("foo").hasNoErrors("it is valid");
exists()
Asserts that the field is present.
Parameters
Example
assert.form().field("foo").exists("it has the food field");
doesNotExist()
Asserts that the field is not present.
Parameters
Example
assert.form().field("foo").doesNotExist("it has no food field");
hasCharCounter()
Asserts that the field has a char counter.
Parameters
current(integer): The current length of the field.max(integer): The max length of the field.message(string) [optional]: The description of the test.
Example
assert.form().field("foo").hasCharCounter(2, 5, "it has updated the counter");
Fieldset
The field element assertions are available at assert.form(...).fieldset(...).*.
Parameters
name(string): The name of the fieldset.
Example
assert.form().fieldset("foo");
hasTitle()
Asserts that the title of the fieldset matches the expected value.
Parameters
Example
assert.form().fieldset("foo").hasTitle("bar", "it has the correct title");
hasDescription()
Asserts that the description of the fieldset matches the expected value.
Parameters
Example
assert
.form()
.fieldset("foo")
.hasDescription("bar", "it has the correct description");
includesText()
Asserts that the fieldset has yielded the expected value.
Parameters
Example
assert.form().fieldset("foo").includesText("bar", "it has the correct text");
Javascript helpers
Form
The FormKit helper allows you to manipulate a form and its fields through a clear and expressive API.
Example
import formKit from "discourse/tests/helpers/form-kit";
test("fill in input", async function (assert) {
await render(
<template>
<Form class="my-form" as |form data|>
<field.Control />
</form.Field>
</Form>
</template>
const myForm = formKit(".my-form");
submit()
Submits the associated form.
Example
formKit().submit();
reset()
Resets the associated form.
Example
formKit().reset();
Field
Parameters
fillIn()
Can be used on @type="input", @type="code", @type="textarea", and @type="composer" fields.
Parameters
value(string | integer | undefined): The value to set on the input.
Example
await formKit().field("foo").fillIn("bar");
toggle()
Can be used on @type="checkbox", @type="toggle", or @type="password" fields.
Will toggle the state of the control. In the case of the password control it will actually toggle the visibility of the field.
Example
await formKit().field("foo").toggle();
accept()
Can be used on @type="question" fields.
Example
await formKit().field("foo").accept();
refuse()
Example
await formKit().field("foo").refuse();
select()
Can be used on @type="select", @type="menu", @type="icon", and @type="radio-group" fields.
Will select the given value.
Parameters
value(string | integer | undefined): The value to select.
Example
await formKit().field("foo").select("bar");
System specs page object
Form
The FormKit page object component is available to help you write system specs for your forms.
Parameters
target(string | Capybara::Node::Element): The selector or node of the form.
Example
form = PageObjects::Components::FormKit.new(".my-form")
form = PageObjects::Components::FormKit.new(find(".my-form"))
submit
Submits the form
Example
form.submit
reset
Reset the form
Example
form.reset
has_an_alert?
Returns if the field is enabled or not.
Example
form.has_an_alert?("message")
expect(form).to have_an_alert("message")
Field
The field helper allows you to interact with a specific field of a form.
Parameters
Example
field = form.field("foo")
value
Returns the value of the field.
Example
field.value
expect(field).to have_value("bar")
checked?
Returns if the control of a checkbox is checked or not.
Example
field.checked?
expect(field).to be_checked
unchecked?
Returns if the control of a checkbox is unchecked or not.
Example
field.unchecked?
expect(field).to be_unchecked
disabled?
Returns if the field is disabled or not.
Example
field.disabled?
expect(field).to be_disabled
enabled?
Example
field.enabled?
expect(field).to be_enabled
toggle
Allows toggling a field. Only available for: @type="checkbox".
Example
field.toggle
fill_in
Allows filling a field with a given value. Only available for: @type="input", @type="textarea", @type="code", and @type="composer".
Example
field.fill_in("bar")
select
Allows selecting a specified value in a field. Only available for: @type="select", @type="icon", @type="menu", @type="radio-group", and @type="question".
Example
field.select("bar")
accept
Allows accepting a field. Only available for: @type="question".
Example
field.accept
refuse
Allows refusing a field. Only available for: @type="question".
Example
field.refuse
upload_image
Takes an image path on the filesystem and uploads it for the field. Only available for the @type="image" control.
Example
field.upload_image(image_file_path)
This document is version controlled - suggest changes on github.
