Discourse toolkit to render forms
Basic Usage
FormKit exposes a single component as its public API: <Form />. All other elements are yielded as contextual components, modifiers, or plain data.
Every form is composed of one or multiple fields, representing the value, validation, and metadata of a control. Each field encapsulates a control, which is the form element the user interacts with to enter data, such as an input or select. The control type is specified via @type on the field. Other utilities, like submit or alert, are also provided.
Here is the most basic example of a form:
import Component from "@glimmer/component";
import { action } from "@ember/object";
import Form from "discourse/components/form";
export default class MyForm extends Component {
  @action
  handleSubmit(data) {
    // do something with data
  <template>
    <Form @onSubmit={{this.handleSubmit}} as |form|>
      <form.Field
        @name="username"
        @title="Username"
        @validation="required"
        @type="input"
        as |field|
        <field.Control />
      </form.Field>
      <form.Field @name="age" @title="Age" @type="input-number" as |field|>
        <field.Control />
      </form.Field>
      <form.Submit />
    </Form>
  </template>
Form
Yielded Parameters
form
The Form component yields a form object containing contextual components and helper functions.
Common members include:
  • Field, Object, Collection, Fieldset, Row, Section, Container
  • Submit, Reset, Button, Alert, Actions
  • CheckboxGroup, InputGroup, ConditionalContent
  • set(name, value), setProperties(object), addItemToCollection(name, value)
Example
<Form as |form|>
  <form.Row as |row|>
  </form.Row>
</Form>
transientData
transientData is the form’s current draft state. It starts as a clone of @data, updates as the user edits fields, and does not mutate the original @data object.
:information_source: This is useful if you want to have conditionals in your form based on other fields.
Example
<Form as |form transientData|>
  <form.Field @name="amount" @title="Amount" @type="input-number" as |field|>
    <field.Control />
  </form.Field>
  {{#if (gt transientData.amount 200)}}
    <form.Field @name="confirmed" @title="Confirm" @type="checkbox" as |field|>
      <field.Control>I know what I'm doing</field.Control>
    </form.Field>
  {{/if}}
</Form>
Arguments
@data
Initial state of the form data.
FormKit expects a plain JavaScript object (POJO). Internally it clones that object into draft state, tracks patches, and only mutates its own internal copy.
Keys matching field @names are prepopulated automatically, including nested object and collection paths.
:information_source: @data is treated as immutable. Edits do not mutate the original object you pass in. If you need to keep some external state in sync while editing, do that explicitly in @onSet.
When deriving a form object from a model, prefer a cached getter:
@cached
get formData() {
  return getProperties(this.model, "foo", "bar", "baz");
Parameter
  • data (Object): The data object passed to the template.
Example
<Form @data={{hash foo="bar"}} as |form|>
  <form.Field @name="foo" @title="Foo" @type="input" as |field|>
    <!-- This input will have "bar" as its initial value -->
    <field.Control />
  </form.Field>
</Form>
@onRegisterApi
Callback called when the form instance is created. It allows the developer to interact with the form through JavaScript.
Parameters
  • callback (Object): The object containing callback functions.
  • callback.get (Function): Returns the current value for a field name.
  • callback.submit (Function): Function to submit the form.
  • callback.reset (Function): Function to reset the form.
  • callback.set (Function): Function to set a key/value on the form data object.
  • callback.setProperties (Function): Function to set an object on the form data object.
  • callback.addError (Function): Function to add an error programmatically.
  • callback.removeError (Function): Function to remove a single field error.
  • callback.removeErrors (Function): Function to clear all errors.
  • callback.isDirty (boolean): Tracked property exposing the dirty state of the form. It becomes true after changes are made and returns to false after reset.
Example
registerAPI({ get, submit, reset, set, addError }) {
  // Interact with the form API
  get("foo");
  submit();
  reset();
  set("foo", 1);
  addError("foo", { title: "Foo", message: "Something went wrong" });
<Form @onRegisterApi={{this.registerAPI}} />
@onSubmit
Callback called when the form is submitted and valid.
Parameters
  • data (Object): The current draft data for the form.
Example
handleSubmit({ username, age }) {
  console.log(username, age);
  <form.Field @name="username" @title="Username" @type="input" as |field|>
    <field.Control />
  </form.Field>
    <field.Control />
  </form.Field>
  <form.Submit />
</Form>
@onReset
Callback called after FormKit rolls the draft data back to its initial state and clears errors.
Parameters
  • data (Object): The rolled-back draft data.
Example
handleReset(data) {
  console.log("reset to", data);
<Form @data={{this.formData}} @onReset={{this.handleReset}} as |form|>
    <field.Control />
  </form.Field>
  <form.Reset />
</Form>
@validate
A custom validation callback added directly to the form. This runs once per validation pass, after field-level validation.
Example
@action
myValidation(data, { addError }) {
  if (data.foo !== data.bar) {
    addError("foo", { title: "Foo", message: "Bar must be equal to Foo" });
<Form @validate={{this.myValidation}} />
An asynchronous example:
@action
async myValidation(data, { addError }) {
  try {
    await ajax("/check-username", {
      type: "POST",
      data: { username: data.username }
  } catch(e) {
    addError("username", { title: "Username", message: "Already taken!" });
@validateOn
Controls when FormKit should validate.
  • Accepted values: submit (default), change, focusout, and input.
Example
<Form @validateOn="change" />
@onDirtyCheck
Callback used during route transitions when the form is dirty. Return a truthy value to show the built-in “dirty form” confirmation dialog, or a falsy value to skip it.
Parameters
  • transition (Transition): The Ember route transition being processed.
Example
@action
onDirtyCheck(transition) {
  return transition.to?.name !== "wizard.step";
<Form @onDirtyCheck={{this.onDirtyCheck}} />
Field
@name
A field must have a unique name. This name is used to read/write the value on the form data object and is also used for validation.
Names cannot contain . or -. Dots are reserved for nested paths such as profile.location.city.
Example
  <field.Control />
</form.Field>
@title
A field must have a title. It will be displayed above the control and is also used in validation.
Example
  <field.Control />
</form.Field>
@type
A field must have a type. This determines which control component is rendered. The available types are:
  • Input types: input (defaults to text), input-text, input-number, input-email, input-password, input-url, input-tel, input-date, input-time, input-datetime-local, input-color, input-month, input-week, input-range, input-search, input-hidden
  • Other controls: checkbox, code, calendar, color, composer, custom, emoji, icon, image, menu, password, question, radio-group, select, tag-chooser, textarea, toggle
Example
  <field.Control />
</form.Field>
@description
The description is optional and will be shown under the title when set.
Example
<form.Field
  @name="foo"
  @title="Foo"
  @description="Bar"
  @type="input"
  as |field|
  <field.Control />
</form.Field>
@helpText
The help text is optional and will be shown under the field when set.
Example
<form.Field @name="foo" @title="Foo" @helpText="Baz" @type="input" as |field|>
  <field.Control />
</form.Field>
@showTitle
By default, the title will be shown on top of the control. You can choose not to render it by setting this property to false.
Example
<form.Field
  @name="foo"
  @title="Foo"
  @showTitle={{false}}
  @type="input"
  as |field|
  <field.Control />
</form.Field>
@disabled
A field can be disabled to prevent any changes to it.
Example
<form.Field
  @name="foo"
  @title="Foo"
  @disabled={{true}}
  @type="input"
  as |field|
  <field.Control />
</form.Field>
@tooltip
Allows to display a tooltip next to the field’s title. Won’t display if title is not shown.
You can pass a string or a <DTooltip /> component.
Example
<Form as |form|>
  <form.Field
    @name="foo"
    @title="Foo"
    @type="input"
    @tooltip="a nice input"
    as |field|
    <field.Control />
  </form.Field>
</Form>
<Form as |form|>
  <form.Field
    @name="foo"
    @title="Foo"
    @type="input"
    @tooltip={{component DTooltip content="a nice input"}}
    as |field|
    <field.Control />
  </form.Field>
</Form>
@validation
Read the dedicated validation section.
@validate
Read the dedicated custom validation section.
@onSet
By default, when changing the value of a field, this value will be set on the form’s internal data object. However, you can choose to have full control over this process for a field.
Example
@action
handleFooChange(value, { set, name, parentName, index }) {
  set("foo", value + "-bar");
<form.Field
  @name="foo"
  @title="Foo"
  @type="input"
  @onSet={{this.handleFooChange}}
  as |field|
  <field.Control />
</form.Field>
:information_source: You can use @onSet to also mutate the initial data object if you need more reactivity for a specific case.
The second argument passed to @onSet contains:
  • set(name, value): update form draft state
  • name: the field’s full name
  • parentName: the parent path for nested fields
  • index: the current collection index when inside a collection
Example
@action
handleFooChange(value, { set }) {
  this.model.foo = value + "-bar";
<Form @data={{this.model}} as |form|>
  <form.Field
    @name="foo"
    @title="Foo"
    @type="input"
    as |field|
    <field.Control />
  </form.Field>
</Form>
Yielded Parameters
The field yields a single field object. The control component determined by @type is available as field.Control.
  <field.Control />
</form.Field>
field.Control
field.Control is the control component determined by @type. You can pass control-specific attributes directly to it (e.g., @height, @lang, placeholder).
:information_source: field.Control is the supported API. Older yielded names such as field.Input are deprecated.
field
The yielded field object provides access to the field’s data and helpers:
Name Description
Control Contextual component for the control set by @type
id ID to be used on the control for accessibility
errorId ID of the field error container
name Full field name, including nested path prefixes
value Current value from draft data
set Function to set the field’s value
Controls
Controls, as we use the term here, refer to the UI widgets that allow a user to enter data. In its most basic form, this would be an input. The control type is specified via @type on the field.
:information_source: You can pass down HTML attributes to the underlying control.
Example
<Form as |form|>
  <form.Field
    @name="query"
    @title="Query"
    @type="input"
    @description="You should make sure the query doesn't include bots."
    as |field|
    <field.Control placeholder="Foo" />
  </form.Field>
</Form>
@format
Controls accept a @format property which can be: small, medium, large, or full.
Form Kit sets defaults for each control, but you can override them using @format:
  • small: 100px
  • medium: 220px
  • large: 400px
  • full: 100%
Additionally, the following CSS variables are provided to customize these defaults:
  • small: --form-kit-small-input
  • medium: --form-kit-medium-input
  • large: --form-kit-large-input
@labelFormat
Overrides the width of the title and description (the label area) independently of @format. Useful when long descriptions need more room than the input itself — e.g. @format="small" with @labelFormat="full" keeps a small input but lets the description span the form. Only emit it when the label area should differ from the field; otherwise both inherit from @format. See @format for the available values.
Checkbox
Renders an <input type="checkbox"> element.
:information_source: When to use a single checkbox
There are only 2 options: yes/no. It feels like agreeing to something. Checking the box doesn’t save; there is a submit button further down.
Example
<Form as |form|>
  <form.Field @name="approved" @title="Approved" @type="checkbox" as |field|>
    <field.Control />
  </form.Field>
</Form>
Calendar
Renders a datepicker and a time input. On mobile the datepicker will be replaced by a date input.
@includeTime
Displays the time input or not. Defaults to true.
Example
<Form as |form|>
  <form.Field @name="start" @title="Start" @type="calendar" as |field|>
    <field.Control @includeTime={{false}} />
  </form.Field>
</Form>
@expandedDatePickerOnDesktop
Displays date picker expanded on desktop. Defaults to true.
Example
<Form as |form|>
    <field.Control @expandedDatePickerOnDesktop={{false}} />
  </form.Field>
</Form>
Code
Renders an <AceEditor /> component.
@height
Sets the height of the editor in pixels.
@lang
Sets the editor mode.
Example
<Form as |form|>
  <form.Field @name="query" @title="Query" @type="code" as |field|>
    <field.Control @lang="sql" @height={{400}} />
  </form.Field>
</Form>
Color
Renders a color input with optional preset swatches.
Common control arguments:
  • @colors: array of preset colors
  • @usedColors: array of already-used colors
  • @collapseSwatches: collapse swatches into a menu
  • @collapseSwatchesLabel: label for the collapsed swatches button
  • @allowNamedColors: allow named colors instead of only hex values
  • @fallbackValue: value to restore on blur when left blank
Example
<Form as |form|>
  <form.Field @name="color" @title="Color" @type="color" as |field|>
    <field.Control
      @colors={{array "0088CC" "FFCC00"}}
      @usedColors={{array "FFCC00"}}
  </form.Field>
</Form>
Composer
Renders a <DEditor /> component.
@height
Sets the height of the composer.
Example
<Form as |form|>
  <form.Field @name="message" @title="Message" @type="composer" as |field|>
    <field.Control @height={{400}} />
  </form.Field>
</Form>
@preview
Controls the display the composer preview. Defaults to false.
Example
<Form as |form|>
    <field.Control @preview={{true}} />
  </form.Field>
</Form>
Custom
Renders a wrapper for custom content. This is the right choice when you want to provide your own control markup but still use FormKit field metadata and state.
Example
<Form as |form|>
  <form.Field @name="slug" @title="Slug" @type="custom" as |field|>
    <field.Control>
      <MyCustomControl
        id={{field.id}}
        @value={{field.value}}
        @onChange={{field.set}}
    </field.Control>
  </form.Field>
</Form>
Emoji
Renders an <EmojiPicker /> component.
@context
Passes the picker context through to <EmojiPicker />.
Example
<Form as |form|>
  <form.Field @name="emoji" @title="Emoji" @type="emoji" as |field|>
    <field.Control @context="chat" />
  </form.Field>
</Form>
Icon
Renders an <IconPicker /> component.
Example
<Form as |form|>
  <form.Field @name="icon" @title="Icon" @type="icon" as |field|>
    <field.Control />
  </form.Field>
</Form>
Renders an <UppyImageUploader /> component.
  • @type: uploader context passed to <UppyImageUploader />
  • @placeholderUrl: optional placeholder image
Upload Handling
By default, the component will set an upload object. It’s common to only want the URL and the ID of the upload. To achieve this, you can use the @onSet property on the field:
@action
handleUpload(upload, { set }) {
  set("upload_id", upload.id);
  set("upload_url", getURL(upload.url));
<Form as |form|>
  <form.Field
    @name="upload"
    @title="Upload"
    @type="image"
    @onSet={{this.handleUpload}}
    as |field|
    <field.Control />
  </form.Field>
</Form>
Example
<Form as |form|>
  <form.Field @name="upload" @title="Upload" @type="image" as |field|>
    <field.Control />
  </form.Field>
</Form>
Input
Renders an <input> element.
@type
The input variant is specified as part of the field’s @type using the input- prefix. For example, @type="input", @type="input-number", or @type="input-email". @type="input" defaults to text.
Allowed Types
  • input (defaults to text)
  • input-color
  • input-date
  • input-datetime-local
  • input-email
  • input-hidden
  • input-month
  • input-number
  • input-password
  • input-range
  • input-search
  • input-tel
  • input-text
  • input-time
  • input-url
  • input-week
Special Cases
  • checkbox and radio have dedicated controls
  • file uploads should use @type="image"
Examples
<Form as |form|>
  <form.Field @name="email" @title="Email" @type="input" as |field|>
    <field.Control />
  </form.Field>
    <field.Control />
  </form.Field>
</Form>
@before
Renders text before the input
Examples
<Form as |form|>
    <field.Control @before="mailto:" />
  </form.Field>
</Form>
@after
Renders text after the input
Examples
<Form as |form|>
    <field.Control @after=".com" />
  </form.Field>
</Form>
Menu
Renders a <DMenu /> trigger with yielded menu content.
@selection
The text to show on the trigger.
yielded parameters
Item
Renders a selectable row. Accepts @value, @icon and @action props.
  • @value: allows to assign a value to a row.
  • @icon: shows an icon at the start of the row.
  • @action: override the default action which would set the value of the field with the value of this row.
The content will be yielded.
Divider
Renders a separator.
Container
Renders a div which will have for content the yielded content.
Examples
<Form as |form|>
  <form.Field @name="email" @title="Email" @type="menu" as |field|>
    <field.Control as |menu|>
      <menu.Item @value={{1}} @icon="pencil-alt">Edit</menu.Item>
      <menu.Divider />
      <menu.Container class="foo">
        Bar
      </menu.Container>
      <menu.Item @action={{this.doSomething}}>Something</menu.Item>
    </field.Control>
  </form.Field>
</Form>
Password
Renders a password input with a visibility toggle.
:information_source: This is different from @type="input-password". The dedicated password control adds the show/hide button.
Example
<Form as |form|>
  <form.Field @name="secret" @title="Secret" @type="password" as |field|>
    <field.Control />
  </form.Field>
</Form>
Question
Renders two inputs of type radio where the first one is a positive answer, the second one a negative answer.
@yesLabel
Allows to customize the positive label.
@noLabel
Allows to customize the negative label.
Examples
<Form as |form|>
  <form.Field @name="email" @title="Email" @type="question" as |field|>
    <field.Control @yesLabel="Correct" @noLabel="Wrong" />
  </form.Field>
</Form>
RadioGroup
Renders a list of radio buttons sharing a common name.
Example
<Form as |form|>
  <form.Field @name="foo" @title="Foo" @type="radio-group" as |field|>
    <field.Control as |radioGroup|>
      <radioGroup.Radio @value="one">One</radioGroup.Radio>
      <radioGroup.Radio @value="two">Two</radioGroup.Radio>
      <radioGroup.Radio @value="three">Three</radioGroup.Radio>
    </field.Control>
  </form.Field>
</Form>
Radio yielded parameters
Title
Allows to render a title.
Examples
<Form as |form|>
    <field.Control as |RadioGroup|>
      <RadioGroup.Radio @value="one" as |radio|>
        <radio.Title>One title</radio.Title>
      </RadioGroup.Radio>
    </field.Control>
  </form.Field>
</Form>
Description
Allows to render a description.
Examples
<Form as |form|>
        <radio.Description>One description</radio.Description>
      </RadioGroup.Radio>
    </field.Control>
  </form.Field>
</Form>
Select
Renders a <DNativeSelect /> component.
@includeNone
By default, Select includes a “none” option when the field is blank or when the field is not marked required. Override this with @includeNone.
Example
<Form as |form|>
  <form.Field @name="fruits" @title="Fruits" @type="select" as |field|>
    <field.Control as |select|>
      <select.Option @value="1">Mango</select.Option>
      <select.Option @value="2">Apple</select.Option>
      <select.Option @value="3">Coconut</select.Option>
    </field.Control>
  </form.Field>
</Form>
Tag Chooser
Renders a <TagChooser /> component.
  • @allowCreate
  • @categoryId
  • @showAllTags
  • @excludeSynonyms
  • @excludeTagsWithSynonyms
  • @unlimited
  • @placeholder
Example
<Form as |form|>
  <form.Field @name="tags" @title="Tags" @type="tag-chooser" as |field|>
    <field.Control @categoryId={{1}} @allowCreate={{true}} />
  </form.Field>
</Form>
Textarea
Renders a <textarea> element.
@height
Sets the height of the textarea.
Example
<Form as |form|>
  <form.Field
    @name="description"
    @title="Description"
    @type="textarea"
    as |field|
    <field.Control @height={{120}} />
  </form.Field>
</Form>
@autoResize
Grows the textarea with its content (renders via <ExpandingTextArea>). Bounds can be set via the --expanding-text-area-min-height (default auto) and --expanding-text-area-max-height (default none) custom properties on any ancestor.
Example
<form.Field @name="description" @type="textarea" as |field|>
  <field.Control @autoResize={{true}} />
</form.Field>
[data-name="description"] {
  --expanding-text-area-min-height: 10rem;
  --expanding-text-area-max-height: 50rem;
Toggle
Renders a <DToggleSwitch /> component.
:information_source: There are only 2 states: enabled/disabled. It should feel like turning something on. Toggling takes effect immediately, there is no submit button.
Example
<Form as |form|>
  <form.Field @name="allowed" @title="Allowed" @type="toggle" as |field|>
    <field.Control />
  </form.Field>
</Form>
Layout
Form Kit aims to provide good defaults, allowing you to mainly use fields and controls. However, if you need more control, we provide several helpers: Row and Col, Section, Fieldset, Container and Actions.
You can also use utilities like Submit, Reset, Alert, CheckboxGroup, InputGroup, and ConditionalContent.
Actions
Actions is a custom Container designed to wrap your buttons in the footer of your form.
Example
<Form as |form|>
  <form.Actions>
    <form.Submit />
  </form.Actions>
</Form>
Alert
Displays an alert in the form.
@icon
An optional icon to use in the alert.
Example
<form.Alert @icon="info-circle">
  Foo
</form.Alert>
@type
Specifies the type of alert. Allowed types: success, error, warning, or info.
Example
<form.Alert @type="warning">
  Foo
</form.Alert>
Checkbox Group
CheckboxGroup allows grouping checkboxes together.
Example
<form.CheckboxGroup @title="Preferences" as |group|>
  <group.Field @name="editable" @title="Editable" @type="checkbox" as |field|>
    <field.Control />
  </group.Field>
  <group.Field
    @name="searchable"
    @title="Searchable"
    @type="checkbox"
    as |field|
    <field.Control />
  </group.Field>
</form.CheckboxGroup>
ConditionalContent
ConditionalContent helps you switch between mutually exclusive blocks of content using a small radio control.
Example
<Form as |form|>
  <form.ConditionalContent @activeName="basic" as |conditional|>
    <conditional.Conditions as |Condition|>
      <Condition @name="basic">Basic</Condition>
      <Condition @name="advanced">Advanced</Condition>
    </conditional.Conditions>
    <conditional.Contents as |Content|>
      <Content @name="basic">
        <form.Alert>Basic settings</form.Alert>
      </Content>
      <Content @name="advanced">
        <form.Alert @type="warning">Advanced settings</form.Alert>
      </Content>
    </conditional.Contents>
  </form.ConditionalContent>
</Form>
Container
Container allows you to render a block similar to a field without tying it to specific data. It is useful for custom controls.
Common arguments:
  • @title
  • @subtitle
  • @format
  • @direction
Example
<Form as |form|>
  <form.Container @title="Important" @subtitle="This is important">
    <!-- Container content here -->
  </form.Container>
</Form>
Fieldset
Wraps content in a fieldset.
Example
<form.Fieldset @name="a-fieldset" class="my-fieldset">
  Foo
</form.Fieldset>
@title
Displays a title for the fieldset, will use the legend element.
Example
<form.Fieldset @title="A title">
  Foo
</form.Fieldset>
@description
Displays a description for the fieldset.
Example
<form.Fieldset @description="A description">
  Foo
</form.Fieldset>
@name
Sets the name of the fieldset. This is necessary if you want to use the fieldset test helpers.
Example
<form.Fieldset @name="a-name">
  Foo
</form.Fieldset>
Input Group
Input group allows you to group multiple inputs together on one line.
Example
<Form as |form|>
  <form.InputGroup as |inputGroup|>
    <inputGroup.Field @title="Foo" @name="foo" @type="input" as |field|>
      <field.Control />
    </inputGroup.Field>
    <inputGroup.Field @title="Bar" @name="bar" @type="input" as |field|>
      <field.Control />
    </inputGroup.Field>
  </form.InputGroup>
</Form>
Reset
The Reset component renders a <DButton /> which will reset the form when clicked. It accepts all the same parameters as a standard <DButton />. The label and default action are set by default.
Example
<form.Reset />
To customize the Reset button further, you can pass additional parameters as needed:
Example with Additional Parameters
<form.Reset @translatedLabel="Remove changes" />
Row and Col
Row and Col enable you to utilize a simple grid system (12 columns) within your form.
Example
<Form as |form|>
  <form.Row as |row|>
    <row.Col @size={{4}}>
        <field.Control />
      </form.Field>
    </row.Col>
    <row.Col @size={{8}}>
      <form.Field @name="bar" @title="Bar" @type="input" as |field|>
        <field.Control />
      </form.Field>
    </row.Col>
  </form.Row>
</Form>
Section
Section provides a simple way to create a section with or without a title.
@subtitle
Displays secondary text in the section header.
Example
<Form as |form|>
  <form.Section @title="Settings">
    <!-- Section content here -->
  </form.Section>
</Form>
Submit
The Submit component renders a <DButton /> which will submit the form when clicked. It accepts all the same parameters as a standard <DButton />. The label, default action, and primary style are set by default.
Example
<form.Submit />
To customize the Submit button further, you can pass additional parameters as needed:
<form.Submit @translatedLabel="Send" />
Object
The object component lets you work with a nested object in your form.
Example
<Form @data={{hash foo=(hash bar=1 baz=2)}} as |form|>
  <form.Object @name="foo" as |object data|>
    <object.Field @name="bar" @title="Bar" @type="input" as |field|>
      <field.Control />
    </object.Field>
    <object.Field @name="baz" @title="Baz" @type="input" as |field|>
      <field.Control />
    </object.Field>
  </form.Object>
</Form>
@name
An object must have a unique name. This name is used as a prefix for the underlying fields.
Like field names, object names should not contain . or -.
Example
<form.Object @name="foo" />
Nesting
An object can accept a nested Object or Collection.
Example
<Form @data={{hash foo=(hash bar=(hash baz=1 bol=2))}} as |form|>
  <form.Object @name="foo" as |parentObject|>
    <parentObject.Object @name="bar" as |childObject data|>
      <childObject.Field @name="baz" @title="Baz" @type="input" as |field|>
        <field.Control />
      </childObject.Field>
    </parentObject.Object>
  </form.Object>
</Form>
<Form @data={{hash foo=(hash bar=(array 1 2))}} as |form|>
    <parentObject.Collection @name="bar" as |collection index|>
      <collection.Field @title="Baz" @type="input" as |field|>
        <field.Control />
      </collection.Field>
      <form.Button
        class={{concat "remove-" index}}
        @action={{fn collection.remove index}}
      >Remove</form.Button>
    </parentObject.Collection>
  </form.Object>
</Form>
Collection
The collection component lets you work with arrays in your form.
It yields three values: the collection API, the current index, and the current item.
Example
<Form @data={{hash foo=(array (hash bar=1) (hash bar=2))}} as |form|>
  <form.Collection @name="foo" as |collection index item|>
    <collection.Field @name="bar" @title="Bar" @type="input" as |field|>
      <field.Control placeholder={{concat "item-" index}} />
    </collection.Field>
  </form.Collection>
</Form>
@name
A collection must have a unique name. This name is used as a prefix for the underlying fields.
For example, if collection has the name “foo”, the 2nd field of the collection with the name “bar”, will actually have “foo.1.bar” as name.
Like field names, collection names should not contain . or -.
Example
<form.Collection @name="foo" />
@tagName
A collection renders as a <div class="form-kit__collection"> by default. You can alter this behavior with @tagName.
Example
<form.Collection @name="foo" @tagName="tr" />
Primitive array
If the shape of your data is an array of primitives, eg: [1, 2, 3], form-kit is able to handle it. You just have to omit the name on the field in this case, as the name will be auto generated for you with the index.
Example
<Form @data={{hash foo=(array 1 2)}} as |form|>
  <form.Collection @name="foo" as |collection|>
      <field.Control />
    </collection.Field>
  </form.Collection>
</Form>
Nesting
A collection can accept a nested Object or Collection.
Example
<Form
  @data={{hash foo=(array (hash bar=(hash baz=1)) (hash bar=(hash baz=2)))}}
  as |form|
    <collection.Object @name="bar" as |object|>
        <field.Control />
      </object.Field>
    </collection.Object>
  </form.Collection>
</Form>
<Form
  @data={{hash
    foo=(array (hash bar=(array (hash baz=1))) (hash bar=(array (hash baz=2))))
  as |form|
  <form.Collection @name="foo" as |parent parentIndex|>
    <parent.Collection @name="bar" as |child childIndex|>
      <child.Field @name="baz" @title="Baz" @type="input" as |field|>
        <field.Control />
      </child.Field>
    </parent.Collection>
  </form.Collection>
</Form>
Add an item to the collection
The <Form /> component yielded object has a addItemToCollection function that you can call to add an item to a specific collection.
Example
  <form.Button @action={{fn form.addItemToCollection "foo" (hash bar=3)}}>
    Add
  </form.Button>
  <form.Collection @name="foo" as |collection index|>
    </collection.Field>
  </form.Collection>
</Form>
Remove an item from the collection
The <Collection /> component yielded object has a remove function that you can call to remove an item from this collection, it takes the index as parameter
Example
      <field.Control />
      <form.Button @action={{fn collection.remove index}}>
        Remove
      </form.Button>
    </collection.Field>
  </form.Collection>
</Form>
Validation
Field accepts a @validation property which allows you to describe the validation rules of the field.
List of Available Rules
Accepted
The value must be "yes", "on", true, 1, or "true". Useful for checkbox inputs — often where you need to validate if someone has accepted terms.
Example
<form.Field
  @name="terms"
  @title="Terms"
  @type="checkbox"
  @validation="accepted"
  as |field|
  <field.Control />
</form.Field>
Between
Checks that a numeric value is between a minimum and maximum value.
Example
<form.Field
  @name="amount"
  @title="Amount"
  @validation="between:1,10"
  as |field|
  <field.Control />
</form.Field>
dateAfterOrEqual
Checks if a calendar value is after or equal to the specified date. Format must be YYYY-MM-DD.
Example
<form.Field
  @name="start"
  @title="Start"
  @type="calendar"
  @validation="dateAfterOrEqual:2022-02-01"
  as |field|
  <field.Control />
</form.Field>
dateBeforeOrEqual
Checks if a calendar value is before or equal to the specified date. Format must be YYYY-MM-DD.
Example
<form.Field
  @name="start"
  @title="Start"
  @type="calendar"
  @validation="dateBeforeOrEqual:2022-02-01"
  as |field|
  <field.Control />
</form.Field>
EndsWith
Checks that a string ends with a given suffix.
Example
<form.Field
  @name="domain"
  @title="Domain"
  @type="input"
  @validation="endsWith:.com"
  as |field|
  <field.Control />
</form.Field>
Integer
Checks if the value is an integer.
Example
<form.Field
  @name="age"
  @title="Age"
  @validation="integer"
  as |field|
  <field.Control />
</form.Field>
Length
Checks that the input’s value is over a given length, or between two length values.
Example
<form.Field
  @name="username"
  @title="Username"
  @type="input"
  @validation="length:5,16"
  as |field|
  <field.Control />
</form.Field>
Number
Checks if the input is a valid number as evaluated by isNaN().
:information_source: When applicable, prefer to use the number input: @type="input-number".
Example
<form.Field
  @name="amount"
  @title="Amount"
  @type="input"
  @validation="number"
  as |field|
  <field.Control />
</form.Field>
Required
Checks if the input is empty.
required:trim trims leading and trailing whitespace before checking the value.
Example
<form.Field
  @name="username"
  @title="Username"
  @type="input"
  @validation="required:trim"
  as |field|
  <field.Control />
</form.Field>
StartsWith
Checks that a string starts with a given prefix.
Example
<form.Field
  @name="handle"
  @title="Handle"
  @type="input"
  @validation="startsWith:@"
  as |field|
  <field.Control />
</form.Field>
URL
Checks if the input value appears to be a properly formatted URL including the protocol. This does not check if the URL actually resolves.
Example
<form.Field
  @name="endpoint"
  @title="Endpoint"
  @type="input-url"
  @validation="url"
  as |field|
  <field.Control />
</form.Field>
Combining Rules
Rules can be combined using the pipe operator: |.
Example
<form.Field
  @name="username"
  @title="Username"
  @type="input"
  @validation="required|length:5,16"
  as |field|
  <field.Control />
</form.Field>
Custom Validation
Custom validators can call preventSubmit to stop the current submission without marking the form invalid. It only affects the current validation pass and must be called again to prevent a later submission attempt. Calling it during a validation pass that was not triggered by submission has no effect.
Field
Field accepts a @validate property which allows you to define a callback function to validate a single field.
Parameters
  • name (string): The name of the form field being validated.
  • value (unknown): The current field value.
  • context (Object)
    • context.data (Object): Current form draft data.
    • context.type (string): Field control type.
    • context.addError (Function): Adds an error if validation fails.
    • context.preventSubmit (Function): Prevents the current submission without adding an error.
Example
@action
validateUsername(name, value, { data, addError }) {
  if (value === data.slug) {
    addError(name, {
      title: "Username",
      message: "Username and slug must differ.",
<form.Field
  @name="username"
  @title="Username"
  @type="input"
  @validate={{this.validateUsername}}
  as |field|
  <field.Control />
</form.Field>
Form
Form accepts a @validate property which allows you to define a callback function to validate the full form state once per validation pass.
Parameters
  • data (Object): The data object containing additional information for validation.
  • handlers (Object): An object containing handler functions.
    • handlers.addError (Function): A function to add an error if validation fails.
    • handlers.removeError (Function): A function to clear an existing error.
    • handlers.preventSubmit (Function): Prevents the current submission without adding an error.
Example
@action
validateForm(data, { addError, removeError }) {
  if (data.start && data.end && data.end < data.start) {
    addError("end", {
      title: "End",
      message: "End must be after start.",
  } else {
    removeError("end");
<Form @validate={{this.validateForm}} as |form|>
  <form.Field @name="start" @title="Start" @type="input-date" as |field|>
    <field.Control />
  </form.Field>
  <form.Field @name="end" @title="End" @type="input-date" as |field|>
    <field.Control />
  </form.Field>
  <form.Submit />
</Form>
:information_source: Unknown validation rule names raise at runtime. Keep the rule list above in sync with the implementation when extending FormKit.
Helpers
Helpers are yielded by some blocks, like Form, or provided as parameters to callbacks. They allow you to interact with the form state in a simple and clear way.
set
set allows you to assign a value to a specific field in the form’s data.
Parameters
  • name (string): The name of the field to which the value is to be set.
  • value (number): The value to be set.
Example
set("foo", 1);
Using the set helper yielded by the form:
<Form as |form|>
  <DButton @action={{fn form.set "foo" 1}} @translatedLabel="Set foo" />
</Form>
setProperties
setProperties allows you to assign an object to the form’s data.
Parameters
  • data (object): A POJO where each key is going to be set on the form using its value.
Example
setProperties({ foo: 1, bar: 2 });
Using the setProperties helper yielded by the form:
<Form as |form|>
  <DButton
    @action={{fn form.setProperties (hash foo=1 bar=2)}}
    @translatedLabel="Set foo and bar"
</Form>
addError
addError allows you to add an error message to a specific field in the form.
Parameters
  • name (string): The name of the field that is invalid.
  • error (object): The error’s data
    • title (string): The title of the error, usually the translated name of the field
    • message (string): The error message
Example
addError("foo", { title: "Foo", message: "This should be another thing." });
Customize
Plugin Outlets
FormKit works seamlessly with <PluginOutlet />. You can use plugin outlets inside your form to extend its functionality:
<Form as |form|>
  <PluginOutlet @name="above-foo-form" @outletArgs={{hash form=form}} />
</Form>
Then, in your connector, you can use the outlet arguments to add custom fields:
<template>
  <@outletArgs.form.Field @name="bar" @title="Bar" @type="input" as |field|>
    <field.Control />
  </@outletArgs.form.Field>
</template>
Styling
All FormKit components propagate attributes, allowing you to set classes and data attributes, for example:
<Form class="my-form" as |form|>
  <form.Field
    @name="foo"
    @title="Foo"
    @type="input"
    class="my-field"
    as |field|
    <field.Control class="my-control" />
  </form.Field>
</Form>
Custom Control
Creating a custom control is straightforward with the properties yielded by form and field:
<Form as |form|>
  <form.Field
    @name="foo"
    @title="Foo"
    @type="custom"
    class="my-field"
    as |field|
    <field.Control>
      <MyCustomControl id={{field.id}} @onChange={{field.set}} />
    </field.Control>
  </form.Field>
</Form>
Common Values on form
Name Description
set Set any field by name, e.g. set("bar", 1)
setProperties Set multiple field values at once
addItemToCollection Append an item to a collection by path
Common Values on field
Name Description
id Input ID
errorId Error container ID
name Full nested field path
value Current field value from draft state
set Set the current field value
Javascript assertions
Form
The form element assertions are available at assert.form(...).*. By default it will select the first “form” element.
Parameters
  • target (string | HTMLElement): The form element or selector.
hasErrors()
Asserts that the form error summary contains the given field errors.
Parameters
  • fields (Object): A map of field names to error messages, e.g. { username: "Required" }.
  • message (string) [optional]: The description of the test.
Example
assert.form().hasErrors({ username: "Required" }, "the form shows errors");
hasNoErrors()
Asserts that the form error summary is not present.
Parameters
Example
assert.form().hasNoErrors("the form is valid");
Field
The field element assertions are available at assert.form(...).field(...).*.
Parameters
  • name (string): The name of the field.
Example
assert.form().field("foo");
hasValue()
Asserts that the value of the field matches the expected text.
Parameters
  • expected (anything): The expected value.
Example
assert.form().field("foo").hasValue("bar", "user has set the value");
hasNoValue()
Asserts that the field is blank.
Parameters
Example
assert.form().field("foo").hasNoValue("the field starts blank");
isDisabled()
Asserts that the field is disabled.
Parameters
Example
assert.form().field("foo").isDisabled("the field is disabled");
isEnabled()
Asserts that the field is enabled.
Parameters
Example
assert.form().field("foo").isEnabled("the field is enabled");
hasTitle()
Asserts that the field title matches the expected text.
Parameters
Example
assert.form().field("foo").hasTitle("Foo", "it shows the field title");
hasDescription()
Asserts that the field description matches the expected text.
Parameters
Example
assert
  .form()
  .field("foo")
  .hasDescription("Helpful copy", "it shows the description");
hasError()
Asserts that the field has a specific error.
Parameters
  • error (string): The error message on the field.
Example
assert.form().field("foo").hasError("Required", "it is required");
hasNoErrors()
Asserts that the field has no error.
Parameters
Example
assert.form().field("foo").hasNoErrors("it is valid");
exists()
Asserts that the field is present.
Parameters
Example
assert.form().field("foo").exists("it has the foo field");
doesNotExist()
Asserts that the field is not present.
Parameters
Example
assert.form().field("foo").doesNotExist("it has no foo field");
hasCharCounter()
Asserts that the field has a char counter.
Parameters
  • current (integer): The current length of the field.
  • max (integer): The max length of the field.
Example
assert.form().field("foo").hasCharCounter(2, 5, "it has updated the counter");
Fieldset
The field element assertions are available at assert.form(...).fieldset(...).*.
Parameters
  • name (string): The name of the fieldset.
Example
assert.form().fieldset("foo");
hasTitle()
Asserts that the title of the fieldset matches the expected value.
Parameters
Example
assert.form().fieldset("foo").hasTitle("bar", "it has the correct title");
hasDescription()
Asserts that the description of the fieldset matches the expected value.
Parameters
Example
assert
  .form()
  .fieldset("foo")
  .hasDescription("bar", "it has the correct description");
includesText()
Asserts that the fieldset has yielded the expected value.
Parameters
Example
assert.form().fieldset("foo").includesText("bar", "it has the correct text");
exists()
Asserts that the fieldset is present.
Parameters
Example
assert.form().fieldset("foo").exists("the fieldset is rendered");
doesNotExist()
Asserts that the fieldset is not present.
Parameters
Example
assert.form().fieldset("foo").doesNotExist("the fieldset is hidden");
Javascript helpers
Form
The FormKit helper allows you to manipulate a form and its fields through a clear and expressive API.
Example
import formKit from "discourse/tests/helpers/form-kit-helper";
test("fill in input", async function (assert) {
  await render(
    <template>
      <Form class="my-form" as |form data|>
          <field.Control />
        </form.Field>
      </Form>
    </template>
  const myForm = formKit(".my-form");
submit()
Submits the associated form.
Example
formKit().submit();
reset()
Resets the associated form.
Example
formKit().reset();
field()
Returns a field helper for a named field.
Parameters
Example
const field = formKit().field("foo");
hasField()
Checks whether a field with the given name exists in the form.
Parameters
Example
formKit().hasField("foo");
Field
Parameters
value()
Returns the current UI value for supported controls.
Example
formKit().field("foo").value();
options()
Returns the available option values for a @type="select" field.
Example
formKit().field("foo").options();
fillIn()
Can be used on input-like controls such as @type="input", @type="input-text", @type="input-number", @type="password", @type="color", @type="code", @type="textarea", and @type="composer".
Parameters
  • value (string | integer | undefined): The value to set on the input.
Example
await formKit().field("foo").fillIn("bar");
toggle()
Can be used on @type="checkbox", @type="toggle", or @type="password" fields.
Will toggle the state of the control. In the case of the password control it will actually toggle the visibility of the field.
Example
await formKit().field("foo").toggle();
accept()
Can be used on @type="question" fields.
Example
await formKit().field("foo").accept();
refuse()
Example
await formKit().field("foo").refuse();
select()
Can be used on @type="select", @type="menu", @type="icon", @type="radio-group", and @type="color" fields.
Will select the given value.
Parameters
  • value (string | integer | undefined): The value to select.
Example
await formKit().field("foo").select("bar");
setDay()
Can be used on @type="calendar" fields.
Parameters
  • day (integer): The day of the month to select.
Example
await formKit().field("start").setDay(15);
setTime()
Parameters
  • time (string): The time to set, e.g. "14:30".
Example
await formKit().field("start").setTime("14:30");
isDisabled()
Returns whether the field is disabled.
Example
formKit().field("foo").isDisabled();
hasPrefix()
Can be used on @type="color" fields. Returns whether the color input renders its prefix.
Example
formKit().field("color").hasPrefix();
swatches()
Can be used on @type="color" fields. Returns the rendered swatches as { color, isUsed, isDisabled }.
Example
formKit().field("color").swatches();
triggerEvent()
Triggers a DOM event on the field’s input element.
Parameters
  • eventName (string): The event to trigger.
  • options (Object) [optional]: Extra event options.
Example
await formKit().field("foo").triggerEvent("blur");
System specs page object
Form
The FormKit page object component is available to help you write system specs for your forms.
Parameters
  • target (string): The selector of the form.
Example
form = PageObjects::Components::FormKit.new(".my-form")
submit
Submits the form.
Example
form.submit
reset
Resets the form.
Example
form.reset
has_an_alert?
Checks whether the form renders an alert with the given message.
Example
form.has_an_alert?("message")
expect(form).to have_an_alert("message")
has_field_with_name?
Checks whether a field with the given data-name exists.
Example
form.has_field_with_name?("foo")
has_no_field_with_name?
Checks whether a field with the given data-name is absent.
Example
form.has_no_field_with_name?("foo")
container
Returns a container helper for the named container.
Example
container = form.container("advanced-settings")
container.has_content?("More options")
choose_conditional
Chooses a ConditionalContent branch by radio value.
Example
form.choose_conditional("advanced")
Field
The field helper allows you to interact with a specific field of a form.
Parameters
Example
field = form.field("foo")
value
Returns the value of the field.
Example
field.value
expect(field).to have_value("bar")
has_value?
Checks that the field value matches the expected value.
Example
field.has_value?("bar")
checked?
Returns if the control of a checkbox is checked or not.
Example
field.checked?
expect(field).to be_checked
unchecked?
Returns if the control of a checkbox is unchecked or not.
Example
field.unchecked?
expect(field).to be_unchecked
disabled?
Returns if the field is disabled or not.
Example
field.disabled?
expect(field).to be_disabled
enabled?
Returns if the field is enabled or not.
Example
field.enabled?
expect(field).to be_enabled
toggle
Allows toggling a field. Available for @type="checkbox", @type="password", and @type="toggle".
Example
field.toggle
fill_in
Allows filling a field with a given value. Available for @type="input", @type="input-*" variants, @type="password", @type="color", @type="textarea", @type="code", and @type="composer".
Example
field.fill_in("bar")
select
Allows selecting a specified value in a field. Available for @type="select", @type="icon", @type="menu", @type="radio-group", @type="question", tag choosers, and custom multi-select controls.
Example
field.select("bar")
accept
Allows accepting a field. Only available for: @type="question".
Example
field.accept
refuse
Allows refusing a field. Only available for: @type="question".
Example
field.refuse
upload_image
Takes an image path on the filesystem and uploads it for the field. Only available for the @type="image" control.
Example
field.upload_image(image_file_path)
has_errors?
Checks that the field renders the given error messages.
Example
field.has_errors?("Required")
has_no_errors?
Checks that the field has no errors.
Example
field.has_no_errors?
has_selected_names?
Checks the selected names for a @type="tag-chooser" field.
Example
field.has_selected_names?("support", "meta")
This document is version controlled - suggest changes on github.
6 « J'aime »
Le code ci-dessus ne fonctionnera pas. Ce code fonctionne :
  validateApiKeyValue(name, value, { data, addError }) {
    console.log(`validate ${name} with ${value}`, data);
La documentation est-elle erronée ou le code est-il erroné ?
EDIT : J’ai décidé que c’était le cas, Update 21-form-kit.md by pfaffman · Pull Request #62 · discourse/discourse-developer-docs · GitHub
1 « J'aime »
Je pense que tout ce qui concerne les @ devrait être entre guillemets inversés. Cela contacte actuellement les utilisateurs ayant les mêmes noms d’utilisateur.
1 « J'aime »
Je pense que l’importation de Form était incorrecte, j’ai donc mis à jour l’OP
de
import Form from "discourse/form";
à
1 « J'aime »
Ai-je bien compris que c’est maintenant la manière recommandée de créer un formulaire pour, disons, collecter des données pour un nouveau modèle ajouté par un plugin ? Ou est-ce pour autre chose ?
Un rapide coup d’œil au code source principal montre aucun peu d’exemples en dehors des tests et tous — y compris ceux que je vois dans les plugins officiels — se trouvent dans /admin
Ce plugin ajoute un modèle résolument différent d’un forum à Discourse (Discourse est mon seul outil, donc tout ce que je développe sur le web sera probablement un plugin Discourse). Puis-je supposer qu’il est logique d’utiliser cette boîte à outils pour tous mes formulaires ?
3 « J'aime »
Oui, c’est l’intention… si tous les formulaires utilisent les mêmes modèles, il est plus facile pour nous de les prendre en charge ainsi que les futures mises à jour.
2 « J'aime »
C’est logique, et un jour, les plugins Core et Official passeront à son utilisation, j’aurai donc plus d’exemples ? :wink:
Et personne n’a encore fait grand-chose de cela puisque tout le code fonctionne sans utiliser ce merveilleux nouveau modèle ?
Merci pour votre patience ! J’ai passé au moins une heure à déboguer ce plugin parce qu’il n’était pas activé, donc je me sens assez incertain de tout en ce moment.
1 « J'aime »
Pouvez-vous également modifier l’exemple de code, que les gens comme moi copient aveuglément dans leurs éditeurs ?
J’ai essayé de le modifier, mais j’ai reçu une erreur concernant la mention de plus de 10 utilisateurs.
1 « J'aime »
J’ai fait des progrès ces derniers jours en essayant de faire fonctionner cela. J’ai l’impression d’être la première personne à essayer de suivre ces instructions. Voici quelques éléments qui m’ont bloqué. Je pense qu’un exemple complet et fonctionnel, que ce soit sous forme de gist ou peut-être dans le cœur, serait d’une grande aide. Mais, ça fonctionne maintenant !
Peut-être déplacer transientData plus bas car il n’est pas toujours nécessaire, et un tas de choses qui n’ont pas été introduites à ce moment-là sont toujours nécessaires pour avoir un exemple fonctionnel ?
De même, je ne comprends pas comment utiliser formData() dans cet exemple. À part le déclarer, il n’est jamais utilisé. Peut-être l’appelleriez-vous comme data = formData() ou le passeriez-vous comme <Form @data=this.formData ...> ?
Parler de validation n’a de sens que lorsque nous connaissons les champs.
Sauf que cela ne fonctionnera pas (si vous voulez qu’il utilise des données ?) sans (d’après ce que je peux dire) si vous ne
Mais vous ne pouvez pas faire cela sans
import { cached, tracked } from "@glimmer/tracking";
Ou peut-être que vous n’avez pas à faire cela, mais vous devez inclure @data={{@somethign}} dans la balise <Form> ? (Cela a au moins permis d’afficher les données dans le formulaire.
Non. Textarea rend une zone de texte comme montré dans l’exemple ci-dessous.
Je n’arrive pas à faire afficher le volet de prévisualisation du DEditor. Je suis à peu près sûr de l’avoir vu lorsque j’ai essayé de créer un DEditor en tant que champ personnalisé.
1 « J'aime »
Je l’utilise dans un TC à venir ; cependant, ce ne sont que les bases.
Je suis d’accord que la documentation pourrait être plus précise. J’ai également eu des difficultés, principalement parce que les explications et les exemples étaient parfois déroutants. Je pense que c’est plus une question de l’ordre dans lequel les choses sont expliquées dans le problème. De plus, dans les exemples, la déclaration d’un tableau avec hash m’a initialement dérouté pour certaines raisons. :sweat_smile:
Cela dit, c’est vraiment du bon matériel, et avoir une manière normalisée de créer des formulaires est excellent !
Je ne sais pas si cela vous aidera, mais voici ce que j’ai essentiellement fait (en gardant uniquement l’essentiel)
const FORM_FIELDS = ["title", "maxWidth", "autoFit", "duration"];
export default class OptionsMarkmap extends Component {
  @tracked data;
  constructor() {
    super(...arguments);
    // Définit les valeurs par défaut
    this.data = {
      title: "",
      maxWidth: 0,
      autoFit: "true",
      duration: 400,
  @cached
  get formData() {
    return getProperties(this.data, ...FORM_FIELDS);
  @action
  save(data) {
  <template>
    <Form @data={{this.formData}} @onSubmit={{this.save}} as |form|>
      <form.Field
        @name="title"
        @title="Title"
        @format="large"
        as |field|
        <form.Container>
          <field.Input />
        </form.Container>
      </form.Field>
      <form.Field
        @name="maxWidth"
        @title="Max Node Width"
        @type="number"
        as |field|
        <form.Container>
          <field.Input />
        </form.Container>
      </form.Field>
      <form.Field
        @name="autoFit"
        @title="Auto Fit"
        as |field|
        <form.Container>
          <field.Checkbox />
        </form.Container>
      </form.Field>
      <form.Actions>
        <form.Submit @label="Save" />
      </form.Actions>
    </Form>
  </template>
Concernant data, ce sont vos valeurs initiales.
L’utilisation de formData vous permet de mettre en cache l’objet (puisque data est immuable), et getProperties est une bonne façon de spécifier les champs que vous incluez, je crois. formData est ce que vous fournissez dans <Form @data=....
get formData() {
3 « J'aime »
Oui. Tout cela a du sens, mais surtout une fois qu’on le sait !
Mais je pense que je ne comprends pas ce qui est mis en cache, ou peut-être où et pourquoi ?
Ah ! C’est bien.
Oui. Je pense que cela ressemble beaucoup plus à un “modèle minimal fonctionnel” !
Merci !
Et plus sur field.Composer
Je n’arrive toujours pas à comprendre comment afficher l’aperçu. J’ai trouvé du CSS pour afficher l’aperçu, mais je n’arrive toujours pas à le faire prendre toute la largeur.
J’ai <field.Composer @height={{80}} /> et cela ressemble exactement à <field.Composer @height={{800}} />, (peut-être y a-t-il un CSS par défaut qui remplace cela ?) – trouvé ! --form-kit-large-input: 100%; (en fait, cela affecte la largeur, mais je ne suis toujours pas sûr pour la hauteur)
1 « J'aime »
Il existe des exemples complets et fonctionnels dans le cœur de FTR.
Il y avait de vrais problèmes à ce sujet. Je les ai tous corrigés dans FIX: supports height/preview form-kit composer by jjaffeux · Pull Request #31121 · discourse/discourse · GitHub et documentés dans document composer preview option by jjaffeux · Pull Request #37 · discourse/discourse-developer-docs · GitHub
2 « J'aime »
Il n’y en avait pas (beaucoup ?) la dernière fois que j’ai regardé. Soit j’étais mauvais avec grep la dernière fois, soit un bon paquet a été ajouté au cours des une ou deux dernières semaines. Ce serait génial si cette documentation en indiquait un qui soit un bon exemple.
Mec ! C’est génial ! J’ai hâte de voir ça. J’ai passé (ce qui m’a semblé) toute la journée hier là-dessus (au moins 2 heures, cependant). Je suis tellement nul en CSS que j’ai supposé que j’étais juste idiot. Ah, tu as corrigé les parties cachées et la hauteur. C’est la largeur avec laquelle j’ai du mal maintenant. Je n’arrive pas à faire en sorte que le compositeur prenne la moitié de l’écran et au lieu de cela, il prend plus de place à mesure que du texte est tapé, et si le champ est vide, il est si petit qu’il n’y a nulle part où taper du texte. Je regarderai plus tard, mais je suis tellement excité que je voulais répondre le plus rapidement possible.
1 « J'aime »
@format="full" sur le champ qui enveloppe le compositeur
1 « J'aime »
Essayez cette recherche - elle contient au moins 10 exemples ‘réels’, ainsi qu’un tas d’exemples dans les tests.
3 « J'aime »
Oui, et honnêtement, je suis réticent à lier des exemples de la documentation car ces liens ont tendance à mal vieillir, car les gens ne sauront pas que la documentation y renvoie s’ils suppriment le fichier, modifient le chemin, …
3 « J'aime »
En effet, vous l’avez fait ! Ça fonctionne vraiment !
Merci beaucoup.
1 « J'aime »
Quelle est la bonne façon d’implémenter une sélection « Multi » ? C’est-à-dire où je peux offrir à l’utilisateur la possibilité de mettre à jour un tableau à partir d’un ensemble constant d’énumérations.
Je suppose que je pourrais utiliser un groupe de cases à cocher
Mais existe-t-il une variante « liste déroulante » ?
Par exemple, si j’ai des ingrédients :
[« riz », « mangue », « œuf », « sel », « cumin »]
et je veux que l’utilisateur puisse en sélectionner aucun, un, plusieurs ou tous.
Et le résultat doit être stocké dans un seul tableau.
C’est-à-dire une bascule pour chaque membre de l’ensemble complet.
Existe-t-il un exemple existant de cela ?
1 « J'aime »
Peut-être utiliser un champ personnalisé en plus de MultiSelect ? https://meta.discourse.org/t/discourse-toolkit-to-render-forms/326439#p-1603904-custom-control-110
Je vois quelques exemples dans le code principal, par exemple :
<form.Field
    @name="appliesTo"
    @title={{i18n "admin.config_areas.flags.form.applies_to"}}
    @validate={{this.validateAppliesTo}}
    @format="large"
    as |field|
    <field.Custom>
      <MultiSelect
        @id={{field.id}}
        @content={{this.appliesToValues}}
        @options={{hash allowAny=false}}
        class="admin-flag-form__applies-to"
    </field.Custom>
  </form.Field>
Est-ce que cela fonctionnerait pour vous ?
2 « J'aime »
