Помогите! Ошибка в подключении приложения Discourse на Android
I am trying to connect the “Tecnoblog Comunidade” to the Discourse app on Android 14, but when I click the button to connect the community within the Discourse app, an error screen appears, and I don’t know how to fix it.
Error: “{“errors”:[“param is missing or the value is empty: public_key”]}”
Community: https://comunidade.tecnoblog.net
Does this happen when you try to connect any other forum?
2 лайка
Only with this community is the error happening; when I try to connect to others, it works normally.
1 лайк
This is possibly a Cloudflare problem.
(I get the same result btw)
2 лайка
Is there any solution on the way? It would be great to use it in the Discourse app, and it seems like it’s only happening with this community, @supermathie @sam
1 лайк
It’s best to get in touch with the administrators of “Tecnoblog Comunidade” - the problem is likely with their Cloudflare setup. Feel free to direct them to Using Discourse with Cloudflare: Best Practices.
If they can temporarily disable Cloudflare and successfully add the site to Hub with it off, that’ll confirm the theory.
1 лайк
Closing since the problem here needs to be fixed by the admins of Tecnoblog Comunidade. Looks like something in their setup is stripping parameters from requests.
