ТК веселья: Конфетти дискурса кликов
:information_source: Summary Add fun to your community by having confetti where you click, using tsParticles.
:eyeglasses: Preview Theme Creator
:hammer_and_wrench: Repository GitHub - NateDhaliwal/discourse-confetti-clicks
:question: Install Guide How to install a theme or theme component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
This theme component creates confetti where the user clicks or taps. The amount of confetti and the angle of spread of confetti can both be controlled using settings.
This TC creates more fun for your community to make it more interactive.
The confetti is made possible with tsParticles, a JS library for animating confetti, snow, lines and more.
Some assistance came from ask.discourse.com.
Settings:
  1. confetti_amount changes the amount of confetti on each click.
:warning: Try not to put too high a number, or there will be more lag with the confetti appearing and dispersing. 100-200 is a good range.
  1. confetti_spread changes the angle of which the confetti disperses. All numbers are in degrees. A value of 360 causes the confetti to disperse in all directions. A value of 1 causes the confetti to disperse and fall in a straight line.
  2. allowed_in sets where the confetti can be used in. Enter the category slug(s) into this field. For multiple categories, separate the slugs with a | (no spaces).
    Leaving this field blank enables confetti in all pages.
13 лайков
This is fun! Might I suggest adding limits to where this is enabled? It doesn’t seem practical when navigating a general space, but it could be fun on a celebratory page.
5 лайков
this needs to be tied to the automation for members’ birthdays :smiley:
14 лайков
Would this be a forum page like /leaderboard or /about, or topics in a specific category?
UPDATE:
There is a new setting, allowed_in, that allows the confetti to be showed only in specific categories. Enter the category slug. For multiple categories, separate them with a |.
3 лайка
This is now fixed! Leaving this field blank enables confetti in all pages.
1 лайк
Update: the allowed_in category is now updated to use category as the list_type for the setting. This allows a better way to select categories.
The theme creator preview link doesn’t do anything for me.
1 лайк
Whoops, my bad. The categories in the setting were #school and #movies. I’ve changed it to #general.
This may be the most useless TC :laughing:
I’ll be modernising the script tag soon. Perhaps even with a setting to show on specific URL paths.
1 лайк
I’ve updated this component not use <script type='text/discourse-plugin'> anymore.
I’ve also added a setting allowed_in_urls to enable the confetti on certain paths within the forum (URL arguments are stripped when checking).
For example, the settings I have on Theme Creator look like this:
This means that confetti is enabled on:
2 лайка
