Обновление Discourse не работает
When I go to click upgrade for Discourse version 2.9.0.beta9 to the latest 3.4.0.beta2 it just loads to an empty page and doesn’t update. How can I upgrade to the latest version? Thank you! (screenshot of blank page attatched)
Any errors is the console or in /logs?
Wow your version was old!!!
With a difference that large I would definitely do this on the command line!!
./launcher rebuild app
also make sure you are on the main branch.
git status
4 лайка
Fixed! I upgraded kernel linux so that the docker would work. Then, I was able to update discourse manually through ubuntu. Now the upgrade page works! If anyone needs the website guides I used to fix this let me know!
1 лайк
