Как предотвратить превращение юникод-сердца в ❤️ при публикации?
Hello! I frequent a forum that switched to Discourse back in April. I used to leave the U+2661 white heart suit unicode character in my posts but since the switch when I do that it turns into the red heart emoji. I don’t want the emoji. I want my unicode lol. I’ve tried leading with a backslash to prevent the formatting but it does nothing. Is there another way around this?
2 лайка
Hi there :wave: and welcome to Discourse Meta :slight_smile:
I guess that forum has that unicode on watched words perhaps? I can do it here and on my instance.
maybe I should read the post after I see it in the previewer lol :joy:
:heart:
you can also use the HTML equivalent that markdown recognizes. - ♡. :heart:
2 лайка
You could use escape it with backticks:
I do recognise it’s a bit annoying when it autoconverts :frowning:
:spades: :heart::clubs::heart: :diamonds:
2 лайка
Maybe use an alternative heart that isn’t mapped to the Emoji?
Glyph Description HTML code
U+2766 FLORAL HEART ❦
U+2767 ROTATED FLORAL HEART BULLET ❧
U+2619 REVERSED ROTATED FLORAL HEART BULLET ☙
U+2765 ROTATED HEAVY BLACK HEART BULLET ❥ or ❥
🎔 U+1F394 HEART WITH TIP ON THE LEFT 🎔
3 лайка
I have no idea. I insert the heart with the character viewer in macOS and it auto-converts when I hit post. I was trying to find a way to convey what unicode character I was talking about because I knew it would probably auto-convert here and no one would be able to see it.
That’s the only method I’ve found to keep it visible but I also want to be able to add color tags to the character.
For the purposes of the post I was making, it had to be the empty outline of a heart.
Is there really no way around this? Why is backslashing just completely ignored in its case?
1 лайк
Hello :wave:
There are some other you can try.
Discourse Icon Theme Component
With this theme component you can display icons in posts.
I mean the is maybe a good option.
[wrap=icon id=far-heart][/wrap]
Plus you can add a watched word for this to easy replacement in /admin/customize/watched_words/action/replace
For example:
far-heart word replace to [wrap=icon id=far-heart][/wrap]
Make sure to check in the HTML checkbox.
The second one is probably not what you want because it globally change the :heart: emoji for everyone.
Same like the first option: Use watched word replace to change the :heart: to ♡.
I would prefer the first option.
6 лайков
Thank you. Can I color tag the icons?
If not, where would I put in a feature request to have formatting of into emoji prevented with a backslash? This is that important to me lol.
I moved it to Feature
1 лайк
Are you sure [wrap] is allowed? I can’t make that work and AI claims it is not allowed.
Wrap is allowed by theme components, it is allow-listed in core, will see where ask got the wrong idea from
1 лайк
I kind of solved it out. I continued conversation and then it explained that can be expanded using plugins (or components). So at first it gave me minimum needed answer.
Anyway, [wrap] doesn’t seems to work, for me.
2 лайка
