재구축 문제: [커스텀 엔드포인트와 함께 dual-stack을 설정할 수 없습니다.]
Hello :wave:
Cannot rebuild with the following issue.
I, [2024-11-07T08:00:56.758061 #1]  INFO -- : > cd /var/www/discourse && sudo -E -u discourse bundle exec rake s3:upload_assets
rake aborted!
ArgumentError: Cannot set dual-stack in combination with a custom endpoint. (ArgumentError)
          raise ArgumentError, "Cannot set dual-stack in combination with a custom endpoint."
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -E -u discourse bundle exec rake s3:upload_assets failed with return #<Process::Status: pid 3349 exit 1>
exec failed with the params {"cd"=>"$home", "cmd"=>["sudo -E -u discourse bundle exec rake s3:upload_assets", "sudo -E -u discourse bundle exec rake s3:expire_missing_assets"]}
567dc9e1f9a4e662de6024b8504915d8b6ef1ee2d9b4303af75323ba478679e4
Probably related commit: FIX: Use dualstack S3 endpoint for direct uploads (#29611) · discourse/discourse@0568d36 · GitHub
I use S3 object storage upload to DO Spaces. The issue is probably with this.
Thanks :slight_smile:
1개의 좋아요
I commented out these lines which makes the rebuild run successfully but the site stuck on splash I think because cannot load assets. :thinking: Safe mode same…
  after_assets_precompile:
    - exec:
        cd: $home
        cmd:
          - sudo -E -u discourse bundle exec rake s3:upload_assets
          - sudo -E -u discourse bundle exec rake s3:expire_missing_assets
Any idea? I know it’s a bad timing… :confused:
1개의 좋아요
Hey Don, we’ll have a look. Thanks for reporting.
1개의 좋아요
Thanks Natalie :hugs:
For quick fix I’ve rebuild with cc01555fce59e116b76c912b4c5195e111a652b2 version, which is one commit behind this FIX: Use dualstack S3 endpoint for direct uploads (#29611) · discourse/discourse@0568d36 · GitHub
2개의 좋아요
My rebuild with a Digital Ocean Spaces S3 setup started failing with this error:
, [2024-11-07T19:09:38.615466 #1]  INFO -- : > cd /var/www/discourse && sudo -E -u discourse bundle exec rake s3:upload_assets
rake aborted!
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.143.0/lib/aws-sdk-s3/endpoint_provider.rb:34:in `resolve_endpoint'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.143.0/lib/aws-sdk-s3/plugins/endpoints.rb:37:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/seahorse/client/plugins/endpoint.rb:47:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/plugins/param_validator.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.143.0/lib/aws-sdk-s3/plugins/sse_cpk.rb:24:in `call'
But omitting setting it to whatever makes the build fail like this:
I, [2024-11-07T19:15:31.060936 #1]  INFO -- : > cd /var/www/discourse && sudo -E -u discourse bundle exec rake s3:upload_assets
ERROR: Ensure S3 is configured in config/discourse.conf or environment vars
I, [2024-11-07T19:15:36.056204 #1]  INFO -- :
I found this:
https://github.com/hashicorp/terraform-provider-aws/issues/37878
and this:
https://github.com/aws/aws-sdk-php/issues/2614
Maybe S3_REGION should be cleared if an endpoint is set here?
EDIT: Oops. I thought I’d searched. Sorry Falco.
1개의 좋아요
Strangely, that gives me this error:
Gem::LoadError: can't activate webrick-1.9.0, already activated webrick-1.8.2 (Gem::LoadError)
which I’d just seen on an instance I was using to run an import, which I “fixed” by upgrading.
I guess I just can’t upgrade this server right now. :frowning:
I am not sure but maybe worth a try. I did a rebuild succesfully before do this.
And just after this try to rebuild with pick the commit. Second time run the rebuild successfully.
1개의 좋아요
@martin usually what we do here is providing a GlobalSetting to disable the behavior that people running incompatible S3 clones can then opt-in to make it work.
IMO, the current behavior should stay as the default, but provide toggles to increase compatibility.
See prior art in DISCOURSE_S3_HTTP_CONTINUE_TIMEOUT, DISCOURSE_S3_INSTALL_CORS_RULE, etc.
3개의 좋아요
Ah sorry my bad here everyone, these S3 clones always slip my mind. I actually had to fix this custom endpoint issue with Minio yesterday. I think the fix here can just to be never use dualstack if DISCOURSE_S3_ENDPOINT has been set since they are incompatible, and everyone here is seemingly using that.
3개의 좋아요
I merged a fix for this now:
https://github.com/discourse/discourse/pull/29654
4개의 좋아요
Thanks for the quick fix! I’m back in business. :tada:
Thanks for the lucid explanation, Rafael!
That’s because there’s a lot of stuff to keep in mind! And the spec tests, I think, would require those annoying stub_requests which I know I hate writing.
FWIW, that sounds right to me. And you could probably write tests for that that didnt’ require stubs for stub_requests.
1개의 좋아요
10 posts were split to a new topic: Unable to backup or navigate to backups
I don’t think this should be marked as fixed .
This change has very likely caused a break to backups on several instances (with others not knowing that their instances aren’t backing up yet presumably).
That suggests to me the specs are not broad enough to capture all the real use cases and changes are passing that shouldn’t have?
4개의 좋아요
It sounds to me like it is fixed just for sites that have use_s3 turned on but not those that are using S3 only for backups.
Though it is again possible to rebuild, it’s just that S3 backups are broken. :crying_cat_face:
3개의 좋아요
The backup problem is fixed here Unable to backup or navigate to backups - #20 by martin
3개의 좋아요
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
