The discussion is about using separate S3 access keys for backups and uploads in Discourse. wttw wants to use separate Backblaze B2 buckets for backups and uploads, but Discourse requires the same S3 credentials for both. Walter_Jenkins mentions that this is possible in AWS by setting up an IAM user with separate roles, but Backblaze’s permission key system is simpler and only allows access to either a single bucket or all buckets. wttw confirms this and notes that the Discourse S3 interface is not well-suited for Backblaze B2 buckets. Walter_Jenkins suggests using AWS or creating a separate Backblaze account as potential workarounds. stanski is having the same issue and mentions a Discourse FAQ that suggests using the same bucket with different paths, but is encountering an error in their version of Discourse (3.4.0.beta3-dev).
I want to use separate backblaze B2 buckets for backups and uploads. I don’t want discourse to have access to any buckets other than the two it is using.
Backblaze allows creating an application key to access either a single bucket, or all buckets.
But discourse requires that uploads and backups use the same S3 credentials, as far as I can tell, so there’s no way to do that.
Sadly, no. For Backblaze the example given just puts the backups in a /backups subdirectory of the (publicly readable) uploads bucket. I’m sure it’s possible to secure that, but it doesn’t seem like a great approach.
So I was able to setup an IAM user with 2 roles in AWS that allows for separate permissions for my backup and assets buckets. Each role is scoped to that bucket and has specific permissions. I believe that the backup is set to only put and not read or list. Where as the assets bucket is allowing all functions.
However this sounds like an issue with the Backblaze role specification is that correct? Seems like you can only attach a permission to 1 or all buckets and the way that it works with discourse is that they share the same permission keys?
Having the same issue with Backblaze.
This FAQ would suggest that you can use the same bucket, but with different paths, except our current version of discourse (3.4.0.beta3-dev) throws an error when I try to save that setting.
