Клавиатура перекрывает поля ввода внизу страницы
Hello :wave:
There are a few place where the opened keyboard is covers the input / dropdown etc… field on mobile. I think it would be good to find a solution for this because now you it makes write blindly in these cases.
Maybe using virtual keyboard env(keyboard-inset-height)?
An example from search page.
Before
After
Thanks
4 лайка
Sure, that looks like a reasonable change. Can you submit a PR for this narrow use case, the search page?
This has no effect on Safari or Firefox for Android, right? But maybe the OP isn’t an issue on those browsers, I can’t repro on Safari, for example.
Yeah, I think this is only a Chrome thing.
1 лайк
