I’m just copy pasting some simple text from a Google Docs document with some links into a post or reply. And then I get this:
It is not a media file. It is just some text with links.
If I first paste the text into an email (gmail) and then copy the text from there the issue is solved.
But I really would like to avoid this extra step.
In the Google Docs document the links are normal crtl+k links and not Markdown formatted links.
Any suggestions would be fantastic. I prefer to use Google Docs because I can access this from both my desktop and my mobile.
Cheers
dax
(Daniela)
You need to allowlist the extensions you want to use in the authorized extensions site setting:
If you click on Documents, all the main text document extensions will be automatically added. Remember to confirm by clicking
Thanks a million.
This is something my administrator needs to fix, right?
dax
(Daniela)
4
Yes, only site admins can make changes to the site settings.
system
(system)
Closed
5
