帮助翻译/正确显示标签
我正在尝试创建一个为编辑器工具栏添加下划线的组件。
我能够让它工作,按钮标签也正常,但使用时会返回
[en.composer.underline_text]
而不是预期的
Example Text
我一直在纠结,但无法弄清楚原因,有人知道我遗漏了什么吗?
谢谢
api-setup.js
import I18n from "I18n";
import { iconNode } from "discourse-common/lib/icon-library";
export default apiInitializer("0.11.1", (api) => {
  const currentLocale = I18n.currentLocale();
  I18n.translations[currentLocale].js.underline_button_title = settings.underline_button;
  I18n.translations[currentLocale].js.underline_text = settings.underline_text;
  api.onToolbarCreate((toolbar) => {
    const buttons = [
        group: "fontStyles",
        icon: "underline",
        shortcut: "U",
        title: "underline_button_title",
        perform: (e) => e.applySurround("[u]", "[/u]", "underline_text"),
    buttons.forEach((button) => toolbar.addButton(button));
  api.decorateCookedElement(
    async (elem, helper) => {
      const id = helper ? `post_${helper.getModel().id}` : "composer";
      applyHighlight(elem, id);
    { id: "wrap-mark" }
settings.yml
underline_button:
  default: "Underline"
  description:
    en: Enter the text for the title of the button in the composer.
underline_text:
  default: "Example Text"
  description:
    en: Enter the placeholder text that appears in the composer after the user clicks the button.
Svg_icons:
  type: 'list'
  list_type: 'compact'
  default: 'underline'
  description:
    en: "Include FontAwesome 6 icon classes for each icon used in the list."
en.yml
en:
  js:
    underline_button_title: settings.underline_button
    underline_text: settings.underline_text
为什么您将文本创建为设置,而不是直接放入 en.yml?
我认为 Composer Footnote Button 是一个有用的例子
感谢您指明了正确的方向
结果发现
应该是
I18n.translations[currentLocale].js.composer.underline_text = settings.underline_text;
