<br> нужна дополнительная пустая строка
This doesn’t work
<br>
<kbd>[wrap=icon id=fa-share][/wrap]&nbsp;Reply</kbd>
[wrap=icon id=fa-share][/wrap] Reply
But this works:
<br>
 Reply
This can be a UX/UI-question too, but because it worked earlier, I count it as a bug.
Not a biggie, though. But it can affect every situation when a HTML-tag is used. In my forum it broke almost every helps where an example-button is used or I’ve needed extra space after an image.
2 лайка
I also had that problem yesterday at User Card Directory: message button should not show on mobile - #5 by Moin. I wasn’t able to figure out why the link did not work:
So, in the end, I removed the <br>. And now I was able to add it again because you told me that all I needed to fix it was an empty line. Thanks.
1 лайк
This is not really a bug, it is just commonmark spec which makes mixing html and markdown somewhat quirky.
When you do <br> it thinks it is a multi line html element, so certain rules do not kick in.
1 лайк
this works:
 Reply
1 лайк
Before kicked in, so those certain rules are only few days old :man_shrugging:
No can do then and I have to start fix posts manually.
I still claim there is something more, because that quirky thing stops totally <br>.
<br>
<kbd>[wrap=icon id=fa-share][/wrap]&nbsp;Vastaa</kbd>
<br />
[wrap=icon id=fa-share][/wrap] Vastaa
 Vastaa
