The discussion is about Automating Discourse Topic Creation using a Python script. MihirR introduced the script, which offers efficiency, customizability, and is API-friendly. It can be used for bulk topic creation, importing content, and testing Discourse forums.
MihirR provided a step-by-step guide on how to use the script, including cloning the repository, setting up credentials, and running the script.
Huynhthai824 asked if the script supports Vietnamese and suggested adding a feature to rewrite content and titles using a pre-trained script, such as Gemini. MihirR confirmed that the script supports Vietnamese and offered to help with integrating it with Gemini.
The conversation ended with huynhthai824 thanking MihirR for the help, and MihirR offering further assistance via direct message without any charges.
Set up the .env file with your Discourse instance credentials.
Prepare a JSON file (topic.json for one, topics.json for many).
Run the script to automatically create topics!
This tool is great for testing and checking how your Discourse forum handles multiple posts. Feel free to explore, suggest improvements, or ask questions here!
While this script is useful for testing, it’s important to focus on growing your community with real users. Genuine users contribute engagement, feedback, and value to your forum. While bots are helpful for testing, they aren’t a substitute for fostering an active, thriving community!
Does the plugin support Vietnamese? When pasting content, can we add a feature to:
Rewrite both the content and the title according to a script that the user has pre-trained? I’ve already trained Gemini to rewrite content and titles, but I want a faster way by pasting directly into the topic creation interface! I don’t want to copy from Gemini and then cut a part to make the title.
Yes, it can be done just need to make some adjustments in the script to connect it with Gemini, I can give it a shot if it’s something important for you.
