Настройка Discourse успешно завершена, но не работает из-за ошибки SSL
Here is the error log
2024/12/14 14:04:39 [warn] 5993#5993: duplicate extension "wasm", content type: "application/wasm", previous content type: "application/wasm" in /etc/nginx/conf.d/discourse.conf:4
2024/12/14 14:04:39 [emerg] 5993#5993: cannot load certificate "/shared/ssl/masked.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2024/12/14 14:04:40 [warn] 5995#5995: duplicate extension "wasm", content type: "application/wasm", previous content type: "application/wasm" in /etc/nginx/conf.d/discourse.conf:4
2024/12/14 14:04:40 [emerg] 5995#5995: cannot load certificate "/shared/ssl/masked.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2024/12/14 14:04:41 [warn] 5997#5997: duplicate extension "wasm", content type: "application/wasm", previous content type: "application/wasm" in /etc/nginx/conf.d/discourse.conf:4
2024/12/14 14:04:41 [emerg] 5997#5997: cannot load certificate "/shared/ssl/masked.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2024/12/14 14:04:42 [warn] 5999#5999: duplicate extension "wasm", content type: "application/wasm", previous content type: "application/wasm" in /etc/nginx/conf.d/discourse.conf:4
2024/12/14 14:04:42 [emerg] 5999#5999: cannot load certificate "/shared/ssl/masked.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2024/12/14 14:04:43 [warn] 6001#6001: duplicate extension "wasm", content type: "application/wasm", previous content type: "application/wasm" in /etc/nginx/conf.d/discourse.conf:4
2024/12/14 14:04:43 [emerg] 6001#6001: cannot load certificate "/shared/ssl/masked.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE).
When I looked into SSL its look empty. I tried rebuilding the application and my email id provided to letsencrypt is right one.
Regards,
Nu
This must often happens if you bypass the host name check in discourse-setup and rebuild several times so that you get rate limited by discourse. Maybe you have cloudflare orange cloud?
You can look at the logs, though they are hard to find. If that’s the problem, the solution is to wait a week or add another hostname as described at Set up Let’s Encrypt with multiple domains / redirects
Thanks for your reply. I am using Digital Ocean, I didn’t bypass hostname check and didn’t do rebuild. I did as mentioned in the GitHub instructions for docker based setup. I think I have to setup Let’s Encrypt manually.
2 лайка
Also I couldn’t find /etc/ngnix/ngnix.conf file ? Is there any thing I am missing before running the.installation script ?
-Nu
It’s inside the container. You can
 ./launcher enter app
To get in it. You can poke around and find the command that tries to get the certificate. I do it infrequently enough that I can never remember what it is. You can likely search here and find it.
My best guess is still a dns issue, but it sounds like you’ve done things right.
found the root cause , 1. Installation was not successful because in DNS IPv4 pointed correctly but IPv6 pointed wrongly (not updated). 2. Digital ocean not supporting smtp mail service on their droplets.
Installation now completed but still unable to receive admin verification email because of digital ocean restriction, checking with multiple options.
  • Sendgrid option failed :frowning: don’t know whether its technology limitation or my mistake.
Nu
Sorry I was busy with other task. Anyone know how to use/configure mailgun or sendgrid or anyother smtp provider in discourse which is hosted in digital ocean. I did filling the details of sendgrid smtp credentials (username,password, smtp server, port, email, reply email, ssl email …) and ran rebuild but still no use.
