Ошибка 404 при отмене изменения имени тега без перезагрузки страницы
This is a very minor bug, sort of an edge case, but hitting a 404 is never pleasant as it triggers a “did I do something wrong?” when managing a website.
Changing a tag name and reverting it to a previous tag name choice on the same screen (meaning, without reloading the page) causes a 404 error.
tag 404)
tag 404
If you change a tag name at least once and end up choosing any tag name you previously validated on the same screen (or the original name), Discourses requests a wrong /tag/<tag_name>/notifications route using an unused tag_name, which results in a 404 error.
Reproduction steps:
  1. Open an existing tag page: https://your-discourse.com/tag/a
  2. Click the wrench, change the name and validate :white_check_mark:
  3. (optional) change the name again
  4. Revert the name to one of the previous ones (or the original tag name)
  5. :four: :zero: :four:
2 лайка
Thanks for the detailed report, I’ve got a fix for this now which should be merged soon:
3 лайка
Okay it’s merged now :rocket:
4 лайка
