색상 스킴이 이제 색상 팔레트로 변경되었습니다
We’ve updated the terminology in Discourse’s interface to improve consistency across the platform. What was previously called a “color scheme” is now referred to as a “color palette” throughout the user interface.
What’s Changed
  • The term “color scheme” has been replaced with “color palette” across the Discourse interface.
  • This change affects what you’ll see in the admin area, customization settings, and other UI elements.
  • The functionality remains exactly the same - only the terminology has changed.
What to Expect
  • If you’re writing documentation or guides about Discourse, please use “color palette” going forward.
  • You may still see references to “color scheme” in some documentation as we gradually update all materials.
  • For developers: References to “scheme” will remain in the codebase (variable names, function names, etc.) for technical stability.
Why This Change?
This update brings more consistency to our interface language and aligns with modern design terminology. While this is a small change, we believe that consistent terminology makes the platform more intuitive to use.
Questions?
If you have any questions about this change, or notice any areas where it has not been appropriately updated, please reply below.
11개의 좋아요
Meta에 있는 문서에서 “새로운” 표현을 사용하도록 업데이트할 계획이 있나요? 이 PR을 찾았습니다: Change scheme to palette - Pull Request #25 - discourse/discourse-developer-docs - GitHub, 하지만 꽤 오래 전에 생성되었고 현재는 충돌이 있는 것 같습니다.
그 부분은 우리가 놓친 것 같습니다. 해당 이슈는 닫아두었는데, 문서의 내부 'id’를 변경하지 않는 한 새 이슈에 대해 pr-welcome 태그를 붙여두었습니다.
