Семейство шрифтов не работает
It drives me crazy the fact that I cannot change the font family. I select Inter (or other font family) as my font family and there are no changes, I can’t change the Arial font family.
I also tried Inter with the CSS method with the @import from Google Font. NOT WORKING! How do I actually change the font family?
Much appreciated.
Obligatory silly question. Did you reload the page?
Can you select any text of your forum (like a post contents) and see what font-family is set to, using your browser dev tools ?
1 лайк
Please try clearing the cache or performing a hard refresh of the browser; it will most likely work.
I did all of that. I cannot get rid of Arial.
Thanks @MihirR I did that, I do it all the time. Still Arial everywhere…
To check why it’s not working, you can add this to your Edit HTML/CSS and see if the new font appears:
body {
  font-family: 'Times New Roman', serif !important;
h1 {
  font-family: 'Courier New', monospace !important;
That’s weird.
What does it look like when using safe mode (the safe mode should keep the custom font)?
Is there any error in the js console or network tab?
1 лайк
I tried this yesterday and It works only for H1.
OMG… :man_facepalming:
It’s a fresh Discourse install. I’m trying do figure this issue.
Yeah, it’s for h1. If you want it for everything, you can use this:
Not working. As you can see above it seems that there are some http problem, I have no idea why since everything else is https.
You may want to diagnose why the font is served over http instead of https.
Is your Discourse a standard install?
2 лайка
  font-family: 'Inter', sans-serif !important;
See, if the H1 works, this should definitely work too.
You can try running: ./launcher rebuild app
Also, are you using any themes? (I assume not, since you mentioned it’s a fresh install, so it’s free of themes and plugins.)
However, I tested some fonts, and they work well on my end, so it’s not an issue on Discourse’s side.
By any chance, are you using a reverse proxy?
Hello :wave:
If so, the force_https site setting is automatically enabled. This is a hidden site setting that you can change in the rails console. It might not be enabled somehow :thinking:
Give it a try :slightly_smiling_face:
cd /var/discourse
./launcher enter app
rails c
SiteSetting.force_https=true
exit
6 лайков
I’m new to Discourse, installed it via Docker / Github. I have no idea what Standard means.
Yes, I use reverse proxy because I have Fastpanel. Fastpanel and Discourse use the same ports, so I had to use reverse proxy.
1 лайк
Oh my god! It worked!!!
Thank you so much, you saved me!!
Much appreciated @Don !!!
2 лайка
There’s a link in my post, “standard install” automatically links to the topic that explains what it is :slight_smile:
To elaborate on what Don said, the force https was one available in Discourse admin settings, but not anymore as HTTPS has been enabled by default on Discourse for a long time now (like, 2 years maybe?). So, if needed, this now hidden setting must be enabled via the command line for example.
I suppose :thinking: using a reverse proxy makes your Discourse not a standard install and may have caused the issue you faced (can’t know for sure).
Anyway, enjoy Discourse :discourse: :partying_face:
3 лайка
Depends of reverse proxy how it talks with a backend. Varnish, if not Enterprise, doesn’t use SSL after termination and that’s why reverse proxy must send something like proxy_set_header X-Forwarded-Proto https;.
But good to know I have to go to hidden settings next time I use Varnish between Nginx and Discourse (plus something else, because otherwise it would be just stupid in my scale).
Or am I totally misunderstanding what forcing means now?
2 лайка
