Discourse 재구축 실패
when ever i try to ./launcher rebuild app it gives an error.
root@amsaal:~# cd /var/discourse/
root@amsaal:/var/discourse# ./launcher rebuild app
x86_64 arch detected.
fatal: No such ref: HEAD
Stopping old container
  • /usr/bin/docker stop -t 600 app
    app
    2.0.20241203-0251: Pulling from discourse/base
    Digest: sha256:d5d4e6d361d56745e37f2609db58a6970cc9b3fcd26d0b2dcba23d0cb581f067
    Status: Image is up to date for discourse/base:2.0.20241203-0251
    docker.io/discourse/base:2.0.20241203-0251
    /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
    /usr/local/bin/pups --stdin
    docker: invalid reference format: repository name (library/#<NoMethodError) must be lowercase.
    See ‘docker run --help’.
    cat: cids/app_bootstrap.cid: No such file or directory
    bootstrap failed with exit code 125
    Container name cannot be empty
Did you check status of the launcher repo?
git status
root@amsaal:/var/discourse# git status
No commits yet
Untracked files:
(use “git add …” to include in what will be committed)
.github/
.gitignore
LICENSE
README.md
discourse-doctor
discourse-setup
image/
launcher
rebuild.log
samples/
scripts/
templates/
tests/
nothing added to commit but untracked files present (use “git add” to track)
You should have seen something like this:
# git status
On branch main
Your branch is up to date with 'origin/main'.
nothing to commit, working tree clean
so I think somehow your /var/discourse directory is broken - is no longer connected to the repo. Did you somehow tidy up, lose, or rename the .git subfolder?
i did not touch anything actually? how can i fix it?
Sorry, I don’t know. Do you have a .git subdirectory? What is in it?
In my case, the config file looks like this:
# cat .git/config
[core]
	repositoryformatversion = 0
	filemode = true
	bare = false
	logallrefupdates = true
[remote "origin"]
	url = https://github.com/discourse/discourse_docker.git
	fetch = +refs/heads/*:refs/remotes/origin/*
[branch "main"]
	remote = origin
	merge = refs/heads/main
But this is for reference. I don’t think the fix is to edit a config file!
i have same result
root@amsaal:/var/discourse# cat .git/config
[core]
filemode = true
bare = false
[remote “origin”]
url = GitHub - discourse/discourse_docker: A Docker image for Discourse · GitHub
fetch = +refs/heads/:refs/remotes/origin/
[branch “main”]
remote = origin
And git status
On branch main
Your branch is based on ‘origin/main’, but the upstream is gone.
(use “git branch --unset-upstream” to fixup)
Changes not staged for commit:
(use “git add …” to update what will be committed)
(use “git restore …” to discard changes in working directory)
modified: .github/workflows/build.yml
modified: LICENSE
modified: README.md
modified: templates/postgres.13.template.yml
modified: templates/postgres.15.template.yml
modified: templates/postgres.template.yml
modified: templates/web.ssl.template.yml
modified: templates/web.template.yml
Untracked files:
rebuild.log
no changes added to commit (use “git add” and/or “git commit -a”)
Looks like you must have changed something - your latest git status gives you very different results from your previous report. This is mysterious!
so can reinstall discourse can solve it and can you advice how can i do it from SSH?
For a full reinstall, you need your full backup (including your app.yml file) and a fresh OS on your instance.
The instructions are here: INSTALL-cloud
It might be best to try the install on a new instance. You’ll need to add the new IP address to a temporary subdomain in your DNS. Or, if you are happy with the downtime, just update your DNS to the new IP address.
You do need to have some idea what you’re doing, otherwise you need help. Sorry, I can’t be that help.
