I used the standard install many months ago. I do use an nginx reverse proxy, note that it has been running w/o issue since August.
I did not run discourse-setup ( well 5 seconds got away once and it started to run the setup script but I kllled it and restored from a snapshot., I did run ./launcher rebuild app.
Yes: “that runs immediately, automatically on login?” As soon as I logon and sudo su to root, it runs automatically,
I don’t use Digital Ocean.
I just looked at the .bashrc file for root, last line is:
/opt/hostinger/scripts/discourse_conf.sh
Let me see what that does. If it has not been there all along, note that I did not add it.
#!/bin/bash
clear
cd /var/discourse
if ./discourse-setup; then
clear
echo "Discourse is now installed. Log into your admin account in a browser to continue"
echo "configuring Discourse."
cp -f /etc/skel/.bashrc /root/.bashrc
else
echo ""
echo "-----------------------------------------------------------------------------"
echo "The setup script failed with the provided Discourse details."
echo "It will rerun. Please address the above issues."
echo "When you are ready, press Enter"
echo "To cancel setup, press Ctrl+C and this script will be rerun on your next login"
read wait
fi
Hostinger hosts the vm. Let me remove that line, and try to logon and su again, I have no idea how that got into the .bashrc file, I certainly did not manually add it.
Yes, that corrects the issue, it never dawned on me that a rc file would be modified like that, so it never dawned on me to check. Thanks guys for your help, it is much appreciated!
After commening that line in the bashrc:
cd /var/discourse
if ./discourse-setup; then echo 'found it'; else echo 'not found'; fi
returns: not found
To me it is odd it found it at all, ever.
However, if I now run (like 15 minutes later) ls -al ./discourse-setup returns: -rwxr-xr-x 1 root root 28715 Dec 23 23:24 ./discourse-setup
If I run if ./discourse-setup; then echo 'found it'; else echo 'not found'; fi now, runs the issue I was having: ...Stopping existing container in 5 seconds or Control-C to cancel
I removed the comment, logged in again and ran sudo su, and it wanted to start the install process, but it did not create the discourse-setup script, so how does the discourse-setup get created?
How is the discourse-setup script getting created, and can I manually delete it? If I rename it, I do not see it re-created on login, with or without the /opt/hostinger/scripts/discourse_conf.sh line in the root .bashrc.
Note that I never saw:
It cleared the screen, and t only comments I saw were:
The configuration file containers/app.yml already exists!
Saving old file as app.yml.2024-12-25-193919.bak
Stopping existing container in 5 seconds or Control-C to cancel.
diff ./.bashrc /etc/skel/.bashrc
118d117
< # /opt/hostinger/scripts/discourse_conf.sh
No idea how that line got into the .bashrc file, and the text I see on issue is not what is described in the /opt/hostinger/scripts/discourse_conf.sh file, but the issue seems to have gone away.
I also note that when I now run ./launcher rebuild app, or reboot the vm, I got a 502 error if i try to access the website too quickly, it takes like a minute for the website to be available. I don’t recall that in the past, but I may never have tried to immediately access the website. Any thoughts on that?
