Après avoir reconstruit, erreur suivante renvoyée : #
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1631 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
below is all the log, who can help me
/usr/local/bin/pups --stdin
I, [2024-12-26T12:50:52.207241 #1]  INFO -- : Reading from stdin
I, [2024-12-26T12:50:52.223092 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-12-26T12:50:52.226838 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-12-26T12:50:52.231373 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-12-26T12:50:52.234873 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
I, [2024-12-26T12:50:52.238419 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-12-26T12:50:52.240056 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /        etc/postgresql/13/main/postgresql.conf
I, [2024-12-26T12:50:52.240707 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql        .conf
I, [2024-12-26T12:50:52.241185 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgr        esql/13/main/postgresql.conf
I, [2024-12-26T12:50:52.241563 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main        /postgresql.conf
I, [2024-12-26T12:50:52.241951 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-26T12:50:52.242323 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_sea        rch_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-26T12:50:52.242699 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/pos        tgresql/13/main/postgresql.conf
I, [2024-12-26T12:50:52.243215 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresq        l/13/main/postgresql.conf
I, [2024-12-26T12:50:52.243612 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_        statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-12-26T12:50:52.244219 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postg        resql/13/main/pg_hba.conf
I, [2024-12-26T12:50:52.244634 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba        .conf
I, [2024-12-26T12:50:52.244999 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba        .conf
I, [2024-12-26T12:50:52.245528 #1]  INFO -- : > if [ -f /root/install_postgres ]; then
  /root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
  socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
I, [2024-12-26T12:50:58.805083 #1]  INFO -- : Generating locales (this might take a while)...
  en_US.UTF-8... done
Generation complete.
I, [2024-12-26T12:50:58.805434 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-        cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-12-26T12:50:58.812375 #1]  INFO -- : File > /usr/local/bin/create_db  chmod: +x  chown:
I, [2024-12-26T12:50:58.818965 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-12-26T12:50:58.823036 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-12-26T12:50:58.823281 #1]  INFO -- : > sleep 5
2024-12-26 12:50:58.899 GMT [39] LOG:  skipping missing configuration file "/shared/postgres_data/postgresql.auto.conf"
2024-12-26 12:50:58.903 UTC [39] FATAL:  data directory "/shared/postgres_data" has wrong ownership
2024-12-26 12:50:58.903 UTC [39] HINT:  The server must be started by the user that owns the data directory.
I, [2024-12-26T12:51:03.826002 #1]  INFO -- :
I, [2024-12-26T12:51:03.826212 #1]  INFO -- : > /usr/local/bin/create_db
createdb: error: could not connect to database template1: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: No such file or dire        ctory
        Is the server running locally and accepting connections on that socket?
psql: error: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: No such file or directory
I, [2024-12-26T12:51:04.472673 #1]  INFO -- :
I, [2024-12-26T12:51:04.472805 #1]  INFO -- : > echo postgres installed!
I, [2024-12-26T12:51:04.474368 #1]  INFO -- : postgres installed!
I, [2024-12-26T12:51:04.479147 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2024-12-26T12:51:04.483492 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2024-12-26T12:51:04.487637 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2024-12-26T12:51:04.488582 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2024-12-26T12:51:04.489262 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2024-12-26T12:51:04.489751 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-12-26T12:51:04.493498 #1]  INFO -- :
I, [2024-12-26T12:51:04.493959 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-12-26T12:51:04.494534 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2024-12-26T12:51:04.495122 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-12-26T12:51:04.495772 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-12-26T12:51:04.496298 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-12-26T12:51:04.496781 #1]  INFO -- : > echo redis installed
I, [2024-12-26T12:51:04.498507 #1]  INFO -- : redis installed
I, [2024-12-26T12:51:04.498696 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-12-26T12:51:04.502939 #1]  INFO -- : logfile ""
I, [2024-12-26T12:51:04.503105 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-12-26T12:51:04.504381 #1]  INFO -- : > sleep 10
87:C 26 Dec 2024 12:51:04.522 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
87:C 26 Dec 2024 12:51:04.522 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=87, just started
87:C 26 Dec 2024 12:51:04.522 # Configuration loaded
87:M 26 Dec 2024 12:51:04.523 * monotonic clock: POSIX clock_gettime
87:M 26 Dec 2024 12:51:04.525 * Running mode=standalone, port=6379.
87:M 26 Dec 2024 12:51:04.525 # Server initialized
87:M 26 Dec 2024 12:51:04.525 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory conditi        on. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue        add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
87:M 26 Dec 2024 12:51:04.526 * Loading RDB produced by version 7.0.7
87:M 26 Dec 2024 12:51:04.526 * RDB age 1152 seconds
87:M 26 Dec 2024 12:51:04.526 * RDB memory usage when created 0.92 Mb
87:M 26 Dec 2024 12:51:04.526 * Done loading RDB, keys loaded: 1, keys expired: 0.
87:M 26 Dec 2024 12:51:04.526 * DB loaded from disk: 0.000 seconds
87:M 26 Dec 2024 12:51:04.526 * Ready to accept connections
I, [2024-12-26T12:51:14.506650 #1]  INFO -- :
I, [2024-12-26T12:51:14.507053 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-12-26T12:51:14.512648 #1]  INFO -- : thpoff is installed!
I, [2024-12-26T12:51:14.513141 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-12-26T12:51:14.599767 #1]  INFO -- :
I, [2024-12-26T12:51:14.599873 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-12-26T12:51:14.687292 #1]  INFO -- :
I, [2024-12-26T12:51:14.687398 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-12-26T12:51:14.767418 #1]  INFO -- :
I, [2024-12-26T12:51:14.767643 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-12-26T12:51:14.770302 #1]  INFO -- :
I, [2024-12-26T12:51:14.772555 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2024-12-26T12:51:14.780855 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2024-12-26T12:51:14.784714 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2024-12-26T12:51:14.788282 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2024-12-26T12:51:14.791993 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2024-12-26T12:51:14.795425 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2024-12-26T12:51:14.795568 #1]  INFO -- : Replacing # postgres with if [ -f /root/install_postgres ]; then
  rm /root/install_postgres
fi
sv start postgres || exit 1
 in /etc/service/unicorn/run
I, [2024-12-26T12:51:14.797041 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-12-26T12:51:15.572806 #1]  INFO -- :
I, [2024-12-26T12:51:15.572932 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
From https://github.com/discourse/discourse
 - [deleted]             (none)     -> origin/0-a-extra-item-classes
 - [deleted]             (none)     -> origin/abstract_autocomplete_textarea
 - [deleted]             (none)     -> origin/add-plugin-wrapper-to-user-profile-avatar
 - [deleted]             (none)     -> origin/better-conflict-handling
 - [deleted]             (none)     -> origin/custom-flag-default-translation
 - [deleted]             (none)     -> origin/dependabot/bundler/sass-embedded-1.81.0
 - [deleted]             (none)     -> origin/dependabot/bundler/webrick-1.9.1
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/sass-1.81.0
 - [deleted]             (none)     -> origin/dev/ember-5-12
 - [deleted]             (none)     -> origin/feature/backup-cli-sql-only-option
 - [deleted]             (none)     -> origin/feature/block-ip-and-email-to-bulk-delete
 - [deleted]             (none)     -> origin/fix-undefined-controller
 - [deleted]             (none)     -> origin/fix/hide-profiles
 - [deleted]             (none)     -> origin/mobile-firefox-keyboard-fix
 - [deleted]             (none)     -> origin/relax-emoji-sanitization
 - [deleted]             (none)     -> origin/separate_upload_placeholder
 - [deleted]             (none)     -> origin/update-robots-desc
   251333995..bf3279d75  main                    -> origin/main
 * [new branch]          0-a-gjs-comp            -> origin/0-a-gjs-comp
 * [new branch]          0-a-no-nest             -> origin/0-a-no-nest
 * [new branch]          0-a-presence            -> origin/0-a-presence
 * [new branch]          add-devenv              -> origin/add-devenv
 + 8741e0f07...04bf23c03 br/directory            -> origin/br/directory  (forced update)
 * [new branch]          category-page-mobile    -> origin/category-page-mobile
   07c91ff5b..1a3925b17  composer_toolbar_improv -> origin/composer_toolbar_improv
 * [new branch]          dependabot/bundler/mocha-2.7.1 -> origin/dependabot/bundler/mocha-2.7.1
 * [new branch]          dependabot/bundler/nokogiri-1.18.0 -> origin/dependabot/bundler/nokogiri-1.18.0
 * [new branch]          dependabot/bundler/sass-embedded-1.83.0 -> origin/dependabot/bundler/sass-embedded-1.83.0
 * [new branch]          dependabot/npm_and_yarn/ember-cli-6.1.0 -> origin/dependabot/npm_and_yarn/ember-cli-6.1.0
 * [new branch]          dependabot/npm_and_yarn/highlightjs-4b4c138b28 -> origin/dependabot/npm_and_yarn/highlightjs-4b4c138b28
 * [new branch]          dependabot/npm_and_yarn/sass-1.83.0 -> origin/dependabot/npm_and_yarn/sass-1.83.0
 * [new branch]          dev-no-text-on-yields   -> origin/dev-no-text-on-yields
 * [new branch]          dev-update-svg-icon-subset-site-setting-help-text -> origin/dev-update-svg-icon-subset-site-setting-help-text
 + d5f594c07...3759d9cf2 dev/admin-api-ui-guidelines -> origin/dev/admin-api-ui-guidelines  (forced update)
 * [new branch]          dev/admin-webhooks-ui-guidelines -> origin/dev/admin-webhooks-ui-guidelines
 * [new branch]          dev/import-support-discourse-reactions-plugin -> origin/dev/import-support-discourse-reactions-plugin
 * [new branch]          dev/settable-fields     -> origin/dev/settable-fields
 * [new branch]          embedding-ux            -> origin/embedding-ux
 * [new branch]          feature/add-trigger-on-option-to-on-tag-change-automation -> origin/feature/add-trigger-on-option-to-on-tag-change-automation
 * [new branch]          feature/default-value-to-fields-in-automation -> origin/feature/default-value-to-fields-in-automation
 * [new branch]          feature/option-for-optional-name-at-signup -> origin/feature/option-for-optional-name-at-signup
 + 2921205f2...7902d7260 feature/wizard-look-and-feel-improvements -> origin/feature/wizard-look-and-feel-improvements  (forced update)
 * [new branch]          fitzy/org-runners       -> origin/fitzy/org-runners
 * [new branch]          fix-chat                -> origin/fix-chat
 * [new branch]          fix-firefox-android-followup -> origin/fix-firefox-android-followup
 * [new branch]          fix-is-replying-when-offline -> origin/fix-is-replying-when-offline
 * [new branch]          fix-open-composer-error -> origin/fix-open-composer-error
 * [new branch]          hide-login-outlets      -> origin/hide-login-outlets
 * [new branch]          i18n/banned-lint        -> origin/i18n/banned-lint
 * [new branch]          issue/allow-admin-to-use-reserved-usernames -> origin/issue/allow-admin-to-use-reserved-usernames
 + 50c0a90ba...56e8c5245 less_invasive_autocomplete -> origin/less_invasive_autocomplete  (forced update)
 * [new branch]          login-css               -> origin/login-css
 + 8834e37c4...d502d7c37 loic-enable-rspec-rule  -> origin/loic-enable-rspec-rule  (forced update)
 * [new branch]          mt/fix-poll-options     -> origin/mt/fix-poll-options
 + 1fc526eb4...9e46da1b7 mt/idb                  -> origin/mt/idb  (forced update)
 + 72f3215c0...eaded6223 mt/pr4                  -> origin/mt/pr4  (forced update)
 * [new branch]          multiple-drafts-dropdown -> origin/multiple-drafts-dropdown
 * [new branch]          plugin-outlet-for-full-page-search-container-and-filter -> origin/plugin-outlet-for-full-page-search-container-and-filter
 * [new branch]          plugin-outlet-on-full-page-search-container-and-filter -> origin/plugin-outlet-on-full-page-search-container-and-filter
 * [new branch]          plugin-outlet-on-full-page-search-container-and-filter-1 -> origin/plugin-outlet-on-full-page-search-container-and-filter-1
 * [new branch]          post-dup-event          -> origin/post-dup-event
 * [new branch]          reapply_refactor        -> origin/reapply_refactor
 * [new branch]          refactor-mobile-coposer-position -> origin/refactor-mobile-coposer-position
 * [new branch]          refactor-mobile-coposer-position-replace-actions -> origin/refactor-mobile-coposer-position-replace-actions
 * [new branch]          remove-u-blocked        -> origin/remove-u-blocked
 * [new branch]          renato/pm               -> origin/renato/pm
 * [new branch]          skip_compressing_assets_if_assets_is_already_on_s3 -> origin/skip_compressing_assets_if_assets_is_already_on_s3
 * [new branch]          speed_up_bundle         -> origin/speed_up_bundle
 * [new branch]          splash-screen-optim     -> origin/splash-screen-optim
 * [new branch]          split-badge-grant       -> origin/split-badge-grant
   f5b108bf9..bb7b5ec70  stable                  -> origin/stable
   251333995..bf3279d75  tests-passed            -> origin/tests-passed
 * [new branch]          topic-tracking-dmenu    -> origin/topic-tracking-dmenu
 * [new branch]          translations-from-crowdin-main -> origin/translations-from-crowdin-main
 * [new branch]          translations-from-crowdin-stable -> origin/translations-from-crowdin-stable
 * [new branch]          user-fields-plugin-outlets-update -> origin/user-fields-plugin-outlets-update
 * [new branch]          user-menu-plugin-outlet -> origin/user-menu-plugin-outlet
 * [new branch]          vite                    -> origin/vite
 * [new branch]          wip-merged-topics       -> origin/wip-merged-topics
 t [tag update]          beta                    -> beta
 t [tag update]          latest-release          -> latest-release
 * [new tag]             v3.3.3                  -> v3.3.3
 * [new tag]             v3.4.0.beta3            -> v3.4.0.beta3
I, [2024-12-26T12:51:18.637477 #1]  INFO -- :
I, [2024-12-26T12:51:18.637601 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2024-12-26T12:51:32.760569 #1]  INFO -- : branch 'tests-passed' set up to track 'origin/tests-passed'.
I, [2024-12-26T12:51:32.760686 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-12-26T12:51:32.769978 #1]  INFO -- :
I, [2024-12-26T12:51:32.770075 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-12-26T12:51:32.772833 #1]  INFO -- :
I, [2024-12-26T12:51:32.772915 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-12-26T12:51:32.775404 #1]  INFO -- :
I, [2024-12-26T12:51:32.775482 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-12-26T12:51:32.778308 #1]  INFO -- :
I, [2024-12-26T12:51:32.778383 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-12-26T12:51:32.780841 #1]  INFO -- :
I, [2024-12-26T12:51:32.780926 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-12-26T12:51:32.784451 #1]  INFO -- :
I, [2024-12-26T12:51:32.784543 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2024-12-26T12:51:32.787109 #1]  INFO -- :
I, [2024-12-26T12:51:32.787191 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-12-26T12:51:32.790727 #1]  INFO -- :
I, [2024-12-26T12:51:32.790896 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-12-26T12:51:32.794789 #1]  INFO -- :
I, [2024-12-26T12:51:32.794877 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2024-12-26T12:51:32.798800 #1]  INFO -- :
I, [2024-12-26T12:51:32.798885 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-12-26T12:51:32.802599 #1]  INFO -- :
I, [2024-12-26T12:51:32.802677 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2024-12-26T12:51:32.806850 #1]  INFO -- :
I, [2024-12-26T12:51:32.806935 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-12-26T12:51:32.810393 #1]  INFO -- :
I, [2024-12-26T12:51:32.810479 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-12-26T12:51:32.888664 #1]  INFO -- :
I, [2024-12-26T12:51:32.888804 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-12-26T12:51:32.890931 #1]  INFO -- :
I, [2024-12-26T12:51:32.891136 #1]  INFO -- : Replacing # redis with if [ ! -d /shared/redis_data ]; then
fi
sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-12-26T12:51:32.891767 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-12-26T12:51:35.362595 #1]  INFO -- :
I, [2024-12-26T12:51:35.362724 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-data-explorer.git
Cloning into 'discourse-data-explorer'...
I, [2024-12-26T12:51:37.397513 #1]  INFO -- :
I, [2024-12-26T12:51:37.397655 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-solved.git
Cloning into 'discourse-solved'...
I, [2024-12-26T12:51:39.372227 #1]  INFO -- :
I, [2024-12-26T12:51:39.372361 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-user-notes.git
Cloning into 'discourse-user-notes'...
I, [2024-12-26T12:51:43.860556 #1]  INFO -- :
I, [2024-12-26T12:51:43.860787 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-adplugin.git
Cloning into 'discourse-adplugin'...
I, [2024-12-26T12:51:45.872895 #1]  INFO -- :
I, [2024-12-26T12:51:45.873053 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-policy.git
Cloning into 'discourse-policy'...
I, [2024-12-26T12:51:47.722593 #1]  INFO -- :
I, [2024-12-26T12:51:47.722971 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-12-26T12:51:47.727257 #1]  INFO -- :
I, [2024-12-26T12:51:47.727641 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-12-26T12:51:47.729606 #1]  INFO -- :
I, [2024-12-26T12:51:47.729712 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2024-12-26T12:51:47.731912 #1]  INFO -- :
I, [2024-12-26T12:51:47.732880 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2024-12-26T12:51:47.733403 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2024-12-26T12:51:47.733788 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2024-12-26T12:51:47.734148 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2024-12-26T12:51:47.734484 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2024-12-26T12:51:47.734778 #1]  INFO -- : > echo "done configuring web"
I, [2024-12-26T12:51:47.736525 #1]  INFO -- : done configuring web
I, [2024-12-26T12:51:47.736920 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-12-26T12:51:48.089770 #1]  INFO -- :
I, [2024-12-26T12:51:48.089887 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2024-12-26T12:51:52.139597 #1]  INFO -- :
I, [2024-12-26T12:51:52.140257 #1]  INFO -- : > cd /var/www/discourse && if [ -f yarn.lock ]; then
  if [ -d node_modules/.pnpm ]; then
    echo "This version of Discourse uses yarn, but pnpm node_modules are preset. Cleaning up..."
    find ./node_modules ./app/assets/javascripts/*/node_modules -mindepth 1 -maxdepth 1 -exec rm -rf {} +
  fi
  su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
else
  su discourse -c 'CI=1 pnpm install --frozen-lockfile && pnpm prune'
fi
I, [2024-12-26T12:52:29.760119 #1]  INFO -- : Scope: all 18 workspace projects
Lockfile is up to date, resolution step is skipped
Progress: resolved 1, reused 0, downloaded 0, added 0
Packages: +232 -97
Progress: resolved 232, reused 164, downloaded 0, added 2
Progress: resolved 232, reused 164, downloaded 0, added 29
Progress: resolved 232, reused 164, downloaded 0, added 45
Progress: resolved 232, reused 164, downloaded 14, added 59
Progress: resolved 232, reused 164, downloaded 19, added 71
Progress: resolved 232, reused 164, downloaded 29, added 79
Progress: resolved 232, reused 164, downloaded 46, added 94
Progress: resolved 232, reused 164, downloaded 59, added 106
Progress: resolved 232, reused 164, downloaded 60, added 109
Progress: resolved 232, reused 164, downloaded 65, added 111
Progress: resolved 232, reused 164, downloaded 67, added 113
Progress: resolved 232, reused 164, downloaded 67, added 116
Progress: resolved 232, reused 164, downloaded 67, added 122
Progress: resolved 232, reused 164, downloaded 67, added 123
Progress: resolved 232, reused 164, downloaded 68, added 125
Progress: resolved 232, reused 164, downloaded 68, added 126
Progress: resolved 232, reused 164, downloaded 68, added 127
Progress: resolved 232, reused 164, downloaded 68, added 127, done
.../node_modules/@swc/core postinstall$ node postinstall.js
.../esbuild@0.24.2/node_modules/esbuild postinstall$ node install.js
.../node_modules/lefthook postinstall$ node postinstall.js
.../node_modules/@swc/core postinstall: Done
.../node_modules/lefthook postinstall: Done
.../esbuild@0.24.2/node_modules/esbuild postinstall: Done
devDependencies:
- @swc/core 1.9.3
+ @swc/core 1.10.1
- esbuild 0.24.0
+ esbuild 0.24.2
- lefthook 1.8.5
+ lefthook 1.10.0
- lint-to-the-future 2.5.1
+ lint-to-the-future 2.6.1
- lint-to-the-future-ember-template 2.0.0
+ lint-to-the-future-ember-template 3.0.0
- puppeteer-core 23.9.0
+ puppeteer-core 23.11.1
- terser 5.36.0
+ terser 5.37.0
Done in 34.7s
Already up to date
I, [2024-12-26T12:52:29.760701 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --jobs $(($(nproc) - 1)) --retry 3'
WARN: Unresolved or ambiguous specs during Gem::Specification.reset:
      stringio (>= 0)
      Available/installed versions of this gem:
      - 3.1.2
      - 3.1.1
WARN: Clearing out unresolved specs. Try 'gem cleanup <gem>'
Please report a bug if this causes problems.
I, [2024-12-26T12:53:29.944202 #1]  INFO -- : Fetching gem metadata from https://rubygems.org/........
Fetching bigdecimal 3.1.9
Fetching minitest 5.25.4
Fetching logger 1.6.4
Installing bigdecimal 3.1.9 with native extensions
Installing minitest 5.25.4
Installing logger 1.6.4
Fetching securerandom 0.4.1
Fetching erubi 1.13.1
Installing securerandom 0.4.1
Fetching useragent 0.16.11
Installing erubi 1.13.1
Fetching timeout 0.4.3
Installing useragent 0.16.11
Fetching openssl 3.3.0
Installing timeout 0.4.3
Fetching csv 3.3.2
Installing openssl 3.3.0 with native extensions
Installing csv 3.3.2
Fetching discourse-fonts 0.0.12
Installing discourse-fonts 0.0.12
Fetching json 2.9.1
Installing json 2.9.1 with native extensions
Fetching io-console 0.8.0
Installing io-console 0.8.0 with native extensions
Fetching regexp_parser 2.10.0
Installing regexp_parser 2.10.0
Fetching webrick 1.9.1
Installing webrick 1.9.1
Fetching rexml 3.4.0
Installing rexml 3.4.0
Fetching rack-test 2.2.0
Installing rack-test 2.2.0
Fetching reline 0.6.0
Installing reline 0.6.0
Fetching psych 5.2.2
Installing psych 5.2.2 with native extensions
Fetching css_parser 1.21.0
Installing css_parser 1.21.0
Fetching net-imap 0.5.4
Installing net-imap 0.5.4
Fetching rdoc 6.10.0
Installing rdoc 6.10.0
Fetching mini_scheduler 0.18.0
Installing mini_scheduler 0.18.0
Fetching rails-html-sanitizer 1.6.2
Installing rails-html-sanitizer 1.6.2
Fetching faraday 2.12.2
Installing faraday 2.12.2
Fetching irb 1.14.3
Installing irb 1.14.3
Fetching activesupport 7.2.2.1
Fetching google-protobuf 4.29.2 (x86_64-linux)
Installing activesupport 7.2.2.1
Fetching oj 3.16.8
Installing google-protobuf 4.29.2 (x86_64-linux)
Installing oj 3.16.8 with native extensions
Fetching activemodel 7.2.2.1
Installing activemodel 7.2.2.1
Fetching actionview 7.2.2.1
Installing actionview 7.2.2.1
Fetching activejob 7.2.2.1
Installing activejob 7.2.2.1
Fetching activerecord 7.2.2.1
Installing activerecord 7.2.2.1
Fetching actionpack 7.2.2.1
Installing actionpack 7.2.2.1
Fetching actionmailer 7.2.2.1
Installing actionmailer 7.2.2.1
Fetching railties 7.2.2.1
Installing railties 7.2.2.1
Bundle complete! 146 Gemfile dependencies, 187 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
2 installed gems you directly depend on are looking for funding.
  Run `bundle fund` for details
I, [2024-12-26T12:53:29.944330 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle clean'
I, [2024-12-26T12:53:30.602553 #1]  INFO -- : Removing actionmailer (7.2.2)
Removing actionpack (7.2.2)
Removing actionview (7.2.2)
Removing activejob (7.2.2)
Removing activemodel (7.2.2)
Removing activerecord (7.2.2)
Removing activesupport (7.2.2)
Removing bigdecimal (3.1.8)
Removing css_parser (1.19.1)
Removing csv (3.3.0)
Removing discourse-fonts (0.0.9)
Removing erubi (1.13.0)
Removing faraday (2.12.1)
Removing google-protobuf-4.29.0-x86_64 (linux)
Removing io-console (0.7.2)
Removing irb (1.14.1)
Removing json (2.8.2)
Removing logger (1.6.2)
Removing mini_scheduler (0.17.0)
Removing minitest (5.25.2)
Removing net-imap (0.5.1)
Removing oj (3.16.7)
Removing openssl (3.2.0)
Removing psych (5.2.1)
Removing rack-test (2.1.0)
Removing rails-html-sanitizer (1.6.1)
Removing railties (7.2.2)
Removing rdoc (6.8.1)
Removing regexp_parser (2.9.3)
Removing reline (0.5.12)
Removing rexml (3.3.9)
Removing securerandom (0.4.0)
Removing timeout (0.4.2)
Removing useragent (0.16.10)
Removing webrick (1.9.0)
I, [2024-12-26T12:53:30.602867 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2024-12-26T12:53:34.804140 #1]  INFO -- : Symlinking fonts from discourse-fonts gem
discourse-adplugin is already at latest compatible version
discourse-data-explorer is already at latest compatible version
discourse-policy is already at latest compatible version
discourse-solved is already at latest compatible version
discourse-user-notes is already at latest compatible version
docker_manager is already at latest compatible version
I, [2024-12-26T12:53:34.804366 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-12-26T12:53:34.806082 #1]  INFO -- : > sleep 10
1628:C 26 Dec 2024 12:53:34.814 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
1628:C 26 Dec 2024 12:53:34.814 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=1628, just started
1628:C 26 Dec 2024 12:53:34.814 # Configuration loaded
1628:M 26 Dec 2024 12:53:34.814 * monotonic clock: POSIX clock_gettime
1628:M 26 Dec 2024 12:53:34.815 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
1628:M 26 Dec 2024 12:53:34.815 # Failed listening on port 6379 (TCP), aborting.
I, [2024-12-26T12:53:44.808580 #1]  INFO -- :
I, [2024-12-26T12:53:44.809131 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
URGENT: Failed to initialize site default: ActiveRecord::ConnectionNotEstablished connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: No such file or directory
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:69:in `rescue in new_client'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:57:in `new_client'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:982:in `connect'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:994:in `reconnect'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:662:in `block in reconnect!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:661:in `reconnect!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:763:in `block in verify!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:754:in `verify!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:771:in `connect!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:977:in `block in with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:976:in `with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/quoting.rb:128:in `quote_string'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/quoting.rb:76:in `quote'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/quoting.rb:122:in `quote'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/schema_statements.rb:1099:in `quoted_scope'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/schema_statements.rb:1076:in `data_source_sql'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/schema_statements.rb:60:in `table_exists?'
/var/www/discourse/lib/site_settings/db_provider.rb:58:in `table_exists?'
/var/www/discourse/lib/site_settings/db_provider.rb:14:in `all'
/var/www/discourse/lib/site_settings/defaults_provider.rb:30:in `db_all'
/var/www/discourse/lib/site_setting_extension.rb:360:in `block in refresh!'
/var/www/discourse/lib/site_setting_extension.rb:353:in `synchronize'
/var/www/discourse/lib/site_setting_extension.rb:353:in `refresh!'
/var/www/discourse/config/initializers/005-site_settings.rb:20:in `block (2 levels) in <main>'
/var/www/discourse/lib/freedom_patches/rails_multisite.rb:16:in `block in safe_each_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:36:in `each_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `each_connection'
/var/www/discourse/lib/freedom_patches/rails_multisite.rb:9:in `each_active_connection'
/var/www/discourse/lib/freedom_patches/rails_multisite.rb:14:in `safe_each_connection'
/var/www/discourse/config/initializers/005-site_settings.rb:18:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:407:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:407:in `block in make_lambda'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:179:in `block in call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:668:in `block (2 levels) in default_terminator'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:667:in `catch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:667:in `block in default_terminator'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:180:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:559:in `block in invoke_before'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:559:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:559:in `invoke_before'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:109:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/reloader.rb:96:in `prepare!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application/finisher.rb:74:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:61:in `block in run_initializers'
/usr/local/lib/ruby/3.3.0/tsort.rb:231:in `block in tsort_each'
/usr/local/lib/ruby/3.3.0/tsort.rb:353:in `block (2 levels) in each_strongly_connected_component'
/usr/local/lib/ruby/3.3.0/tsort.rb:434:in `each_strongly_connected_component_from'
/usr/local/lib/ruby/3.3.0/tsort.rb:352:in `block in each_strongly_connected_component'
/usr/local/lib/ruby/3.3.0/tsort.rb:350:in `each'
/usr/local/lib/ruby/3.3.0/tsort.rb:350:in `call'
/usr/local/lib/ruby/3.3.0/tsort.rb:350:in `each_strongly_connected_component'
/usr/local/lib/ruby/3.3.0/tsort.rb:229:in `tsort_each'
/usr/local/lib/ruby/3.3.0/tsort.rb:208:in `tsort_each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:435:in `initialize!'
/var/www/discourse/config/environment.rb:7:in `<main>'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `require'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `block (2 levels) in replace_require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/zeitwerk-2.7.1/lib/zeitwerk/core_ext/kernel.rb:34:in `require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:411:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:559:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:243:in `block in invoke_prerequisites'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:241:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:241:in `invoke_prerequisites'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:218:in `block in invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:188:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:147:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:132:in `top_level'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:214:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:80:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/rake:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/rake:25:in `<top (required)>'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:58:in `load'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:58:in `kernel_load'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:455:in `exec'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor.rb:527:in `dispatch'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:35:in `dispatch'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/base.rb:584:in `start'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:29:in `start'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/exe/bundle:28:in `block in <top (required)>'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/exe/bundle:20:in `<top (required)>'
rake aborted!
ActiveRecord::ConnectionNotEstablished: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: No such file or directory (ActiveRecord::ConnectionNotEstablished)
/var/www/discourse/config/initializers/006-ensure_login_hint.rb:8:in `block in <main>'
Caused by:
PG::ConnectionBad: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: No such file or directory (PG::ConnectionBad)
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/pg-1.5.4/lib/pg/connection.rb:819:in `connect_start'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/pg-1.5.4/lib/pg/connection.rb:819:in `connect_to_hosts'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/pg-1.5.4/lib/pg/connection.rb:759:in `new'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/pg-1.5.4/lib/pg.rb:63:in `connect'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:58:in `new_client'
Tasks: TOP => db:migrate => db:load_config => environment
I, [2024-12-26T12:53:47.919752 #1]  INFO -- :
I, [2024-12-26T12:53:47.920249 #1]  INFO -- : Terminating async processes
I, [2024-12-26T12:53:47.920297 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 87
87:signal-handler (1735217627) Received SIGTERM scheduling shutdown...
87:M 26 Dec 2024 12:53:47.985 # User requested shutdown...
87:M 26 Dec 2024 12:53:47.985 * Saving the final RDB snapshot before exiting.
87:M 26 Dec 2024 12:53:48.018 * DB saved on disk
87:M 26 Dec 2024 12:53:48.018 # Redis is now ready to exit, bye bye...
Avez-vous joué avec la propriété du répertoire sous /var/discourse/shared ou l’un de ses sous-répertoires ? Cela cassera l’installation.
Si votre site était vide, vous pouvez supprimer /var/discourse et refaire l’installation.
Je pense qu’une ancienne image de base avait des identifiants utilisateur différents, ils doivent donc être chownés.
J’ai mis à jour Docker avant d’exécuter ./launcher rebuild app, est-ce la raison ?
Oui, Falco
J’ai sauvegardé avant de reconstruire, j’ai redémarré un serveur et j’ai restauré les fichiers précédemment sauvegardés, merci beaucoup pour votre réponse
