TypeError: Cannot set property deleteTopic of [object Object] which has only a getter
The discussion revolves around a TypeError: Cannot set property deleteTopic of [object Object] which has only a getter error in a Discourse installation. etc reports that their long-standing Discourse installation started experiencing JavaScript errors after posting a reply, resulting in a “something went wrong” screen when visiting a particular topic.
Lilly suggests checking safe mode, and etc finds that disabling all client-side plugin customizations resolves the issue. Further investigation reveals that the Discourse-Encrypt plugin is the cause of the problem. CocoQuark notes that this plugin is deprecated and provides a link to instructions for handling the deprecation. etc plans to uninstall the plugin, speculating that a change as of January 1 may have broken it.
I have a long standing installation of Discourse that seems to be getting js errors.
Uncaught (in promise) TypeError: Cannot set property deleteTopic of [object Object] which has only a getter
    at ye (index.js:1641:1)
    at y (mixin.js:281:1)
    at w.apply (mixin.js:482:1)
    at e.proto (core.js:600:1)
    at new y (core.js:91:1)
    at new e (core.js:371:1)
    at e.create (core.js:385:1)
    at h.create (index.js:385:1)
    at index.js:287:1
    at index.js:230:1
    at i.lookup (index.js:125:1)
    at u.lookup (container_proxy.js:19:1)
    at m.s (index.js:2075:1)
    at index.js:1310:1
    at validator.js:635:1
    at pe.get (index.js:1309:1)
    at m.r [as topic] (index.js:881:1)
    at Te (index.js:1682:1)
    at reference.js:164:1
    at reference.js:125:1
    at validator.js:622:1
    at d (reference.js:124:1)
    at reference.js:162:1
    at De (index.js:1806:1)
    at ze.create (index.js:1974:1)
    at Object.evaluate (runtime.js:2676:1)
    at Object.evaluate (runtime.js:1052:1)
    at It.evaluateSyscall (runtime.js:4204:1)
    at It.evaluateInner (runtime.js:4175:1)
    at It.evaluateOuter (runtime.js:4168:1)
    at Wt.next (runtime.js:4999:1)
    at Wt._execute (runtime.js:4986:1)
    at Wt.execute (runtime.js:4979:1)
    at Qt.sync (runtime.js:5046:1)
    at hr.<anonymous> (index.js:4672:1)
    at index.js:4934:1
    at Nt (runtime.js:4080:1)
    at gr._renderRoots (index.js:4916:1)
    at gr._renderRootsTransaction (index.js:4960:1)
    at gr._renderRoot (index.js:4905:1)
    at gr._appendDefinition (index.js:4830:1)
    at gr.appendOutletView (index.js:4820:1)
    at invoke (backburner.js.js:282:1)
    at h.flush (backburner.js.js:197:1)
    at p.flush (backburner.js.js:358:1)
    at B._end (backburner.js.js:798:1)
    at backburner.js.js:523:1
application.js:155 TypeError: r.subscribe is not a function
    at d.setupController (topic-from-params.js:94:21)
    at d.setup (route.js:444:1)
    at o (router_js.js:1544:1)
    at s.routeEnteredOrUpdated (router_js.js:1554:1)
    at s.setupContexts (router_js.js:1500:1)
    at s.finalizeTransition (router_js.js:1408:1)
    at router_js.js:1347:1
    at _ (rsvp.js:434:1)
    at y (rsvp.js:420:1)
error @ application.js:155
router.js:1141 Error while processing route: topic.fromParamsNear r.subscribe is not a function
I have a cascading set of js errors as a result. When I go to a particular topic, it just shows the error, something went wrong, screen.
Any suggestions on troubleshooting? Thanks in advance.
Hi @etc :wave: did you check safe mode yet?
when you say “long standing” - I assume you mean longtime functional; but has it been updated to latest version recently?
I’ll check out safe mode, thanks.
Yes, long standing as in it’s been functional for years. I was on 3.1, then I posted a reply and then started running into the errors. I upgraded to the latest version just to see if it would fix, but even though the update worked properly, the issue persists.
Thanks for the link, it is helping me narrow it down.
So, the option Disable all client-side plugin customizations ended up fixing it. Do you have some documentation on what precisely that is referring to? Thank you! <3 Happy New Year, btw
So, we’re pretty light on plugins, but it looks like it’s the Discourse-Encrypt plugin, which I believe is an official plugin. When I disable it, everything works, once I reenable it, everything goes down again. Not sure why this would happen out of nowhere.
This plugin is deprecated, you may want to uninstall it read the topic for instructions.
I’ll go ahead and uninstall it. I wonder if something flipped as of Jan 1 that would break the plugin. It seemed to have happened out of nowhere. Thanks so much! Happy New Year!
