TypeError : Impossible de définir la propriété deleteTopic de [object Object] qui a uniquement un getter
J’ai une installation de Discourse de longue date qui semble générer des erreurs JavaScript.
Uncaught (in promise) TypeError: Cannot set property deleteTopic of [object Object] which has only a getter
    at ye (index.js:1641:1)
    at y (mixin.js:281:1)
    at w.apply (mixin.js:482:1)
    at e.proto (core.js:600:1)
    at new y (core.js:91:1)
    at new e (core.js:371:1)
    at e.create (core.js:385:1)
    at h.create (index.js:385:1)
    at index.js:287:1
    at index.js:230:1
    at i.lookup (index.js:125:1)
    at u.lookup (container_proxy.js:19:1)
    at m.s (index.js:2075:1)
    at index.js:1310:1
    at validator.js:635:1
    at pe.get (index.js:1309:1)
    at m.r [as topic] (index.js:881:1)
    at Te (index.js:1682:1)
    at reference.js:164:1
    at reference.js:125:1
    at validator.js:622:1
    at d (reference.js:124:1)
    at reference.js:162:1
    at De (index.js:1806:1)
    at ze.create (index.js:1974:1)
    at Object.evaluate (runtime.js:2676:1)
    at Object.evaluate (runtime.js:1052:1)
    at It.evaluateSyscall (runtime.js:4204:1)
    at It.evaluateInner (runtime.js:4175:1)
    at It.evaluateOuter (runtime.js:4168:1)
    at Wt.next (runtime.js:4999:1)
    at Wt._execute (runtime.js:4986:1)
    at Wt.execute (runtime.js:4979:1)
    at Qt.sync (runtime.js:5046:1)
    at hr. (index.js:4672:1)
    at index.js:4934:1
    at Nt (runtime.js:4080:1)
    at gr._renderRoots (index.js:4916:1)
    at gr._renderRootsTransaction (index.js:4960:1)
    at gr._renderRoot (index.js:4905:1)
    at gr._appendDefinition (index.js:4830:1)
    at gr.appendOutletView (index.js:4820:1)
    at invoke (backburner.js.js:282:1)
    at h.flush (backburner.js.js:197:1)
    at p.flush (backburner.js.js:358:1)
    at B._end (backburner.js.js:798:1)
    at backburner.js.js:523:1
application.js:155 TypeError: r.subscribe is not a function
    at d.setupController (topic-from-params.js:94:21)
    at d.setup (route.js:444:1)
    at o (router_js.js:1544:1)
    at s.routeEnteredOrUpdated (router_js.js:1554:1)
    at s.setupContexts (router_js.js:1500:1)
    at s.finalizeTransition (router_js.js:1408:1)
    at router_js.js:1347:1
    at _ (rsvp.js:434:1)
    at y (rsvp.js:420:1)
error @ application.js:155
router.js:1141 Error while processing route: topic.fromParamsNear r.subscribe is not a function
J’ai une cascade d’erreurs JavaScript en conséquence. Lorsque je vais sur un sujet particulier, il affiche simplement l’écran d’erreur “quelque chose s’est mal passé”.
Des suggestions pour le dépannage ? Merci d’avance.
Salut @etc :wave: as-tu déjà vérifié le mode sans échec ?
quand tu dis « de longue date » - je suppose que tu veux dire fonctionnel depuis longtemps ; mais a-t-il été mis à jour récemment vers la dernière version ?
Je vais essayer le mode sans échec, merci.
Oui, de longue date, dans le sens où il fonctionne depuis des années. J’étais sur la version 3.1, puis j’ai posté une réponse et j’ai commencé à rencontrer des erreurs. J’ai mis à jour vers la dernière version juste pour voir si cela résoudrait le problème, mais même si la mise à jour a fonctionné correctement, le problème persiste.
Merci pour le lien, cela m’aide à affiner ma recherche.
L’option “Désactiver toutes les personnalisations de plugins côté client” a fini par résoudre le problème. Avez-vous de la documentation sur ce à quoi cela fait précisément référence ? Merci ! <3 Bonne année, d’ailleurs.
Donc, nous avons très peu de plugins, mais il semble que ce soit le plugin Discourse-Encrypt, qui, je crois, est un plugin officiel. Lorsque je le désactive, tout fonctionne, une fois que je le réactive, tout tombe à nouveau en panne. Je ne sais pas pourquoi cela se produirait soudainement.
Ce plugin est obsolète, vous voudrez peut-être le désinstaller lire le sujet pour obtenir des instructions.
Je vais procéder à sa désinstallation. Je me demande si quelque chose a basculé le 1er janvier qui aurait pu casser le plugin. Cela semble être arrivé de nulle part. Merci beaucoup ! Bonne année !
