TypeError: Não é possível definir a propriedade deleteTopic de [object Object], que possui apenas um getter
Tenho uma instalação antiga do Discourse que parece estar apresentando erros de JS.
Uncaught (in promise) TypeError: Cannot set property deleteTopic of [object Object] which has only a getter
    at ye (index.js:1641:1)
    at y (mixin.js:281:1)
    at w.apply (mixin.js:482:1)
    at e.proto (core.js:600:1)
    at new y (core.js:91:1)
    at new e (core.js:371:1)
    at e.create (core.js:385:1)
    at h.create (index.js:385:1)
    at index.js:287:1
    at index.js:230:1
    at i.lookup (index.js:125:1)
    at u.lookup (container_proxy.js:19:1)
    at m.s (index.js:2075:1)
    at index.js:1310:1
    at validator.js:635:1
    at pe.get (index.js:1309:1)
    at m.r [as topic] (index.js:881:1)
    at Te (index.js:1682:1)
    at reference.js:164:1
    at reference.js:125:1
    at validator.js:622:1
    at d (reference.js:124:1)
    at reference.js:162:1
    at De (index.js:1806:1)
    at ze.create (index.js:1974:1)
    at Object.evaluate (runtime.js:2676:1)
    at Object.evaluate (runtime.js:1052:1)
    at It.evaluateSyscall (runtime.js:4204:1)
    at It.evaluateInner (runtime.js:4175:1)
    at It.evaluateOuter (runtime.js:4168:1)
    at Wt.next (runtime.js:4999:1)
    at Wt._execute (runtime.js:4986:1)
    at Wt.execute (runtime.js:4979:1)
    at Qt.sync (runtime.js:5046:1)
    at hr.<anonymous> (index.js:4672:1)
    at index.js:4934:1
    at Nt (runtime.js:4080:1)
    at gr._renderRoots (index.js:4916:1)
    at gr._renderRootsTransaction (index.js:4960:1)
    at gr._renderRoot (index.js:4905:1)
    at gr._appendDefinition (index.js:4830:1)
    at gr.appendOutletView (index.js:4820:1)
    at invoke (backburner.js.js:282:1)
    at h.flush (backburner.js.js:197:1)
    at p.flush (backburner.js.js:358:1)
    at B._end (backburner.js.js:798:1)
    at backburner.js.js:523:1
application.js:155 TypeError: r.subscribe is not a function
    at d.setupController (topic-from-params.js:94:21)
    at d.setup (route.js:444:1)
    at o (router_js.js:1544:1)
    at s.routeEnteredOrUpdated (router_js.js:1554:1)
    at s.setupContexts (router_js.js:1500:1)
    at s.finalizeTransition (router_js.js:1408:1)
    at router_js.js:1347:1
    at _ (rsvp.js:434:1)
    at y (rsvp.js:420:1)
error @ application.js:155
router.js:1141 Error while processing route: topic.fromParamsNear r.subscribe is not a function
Como resultado, tenho uma série em cascata de erros de JS. Quando acesso um tópico específico, ele exibe apenas a tela de erro “algo deu errado”.
Alguma sugestão para solução de problemas? Agradeço antecipadamente.
Olá @etc :wave: você já verificou o modo de segurança?
quando você diz “de longa data” - presumo que você queira dizer funcional há muito tempo; mas ela foi atualizada para a versão mais recente recentemente?
Vou verificar o modo de segurança, obrigado.
Sim, de longa data, no sentido de que está funcionando há anos. Eu estava na versão 3.1, depois postei uma resposta e comecei a encontrar os erros. Atualizei para a versão mais recente apenas para ver se corrigiria, mas, embora a atualização tenha funcionado corretamente, o problema persiste.
Obrigado pelo link, está me ajudando a refinar.
Então, a opção Desativar todas as personalizações de plug-ins do lado do cliente acabou resolvendo. Você tem alguma documentação sobre o que isso se refere precisamente? Obrigado! <3 Feliz Ano Novo, aliás
Então, temos poucos plugins, mas parece que é o plugin Discourse-Encrypt, que acredito ser um plugin oficial. Quando o desativo, tudo funciona, assim que o reativo, tudo para novamente. Não sei por que isso aconteceria do nada.
Este plugin está obsoleto, talvez você queira desinstalá-lo ler o tópico para obter instruções.
Vou desinstalá-lo. Será que algo mudou a partir de 1º de janeiro que possa ter quebrado o plugin. Pareceu ter acontecido do nada. Muito obrigado! Feliz Ano Novo!
