Problem bei der Wiederherstellung von Discourse aus Backup (3.4, ziemlich große Datenbank)
Hi there,
We are one of your early bird users, we are using Discourse since 2015.
It works just fine until latest update with Postgres update included (possibly 3.4?). We have one backup points before this update. We decide to make clean install then restore from this backup.
OS: Ubuntu 24.04.1 LTS (latest updates) + docker 26.1.3
Trying to restore large discourse backup (44GB, single site) to a blank container.
Automated restore fails on DB migration with following error:
PG::DuplicateColumn: ERROR: column “notification_level” of relation “user_chat_channel_memberships” already exists (PG::DuplicateColumn)
logs:
Specifically, the migration stops after deploying the SQL archive because a column in the database is not unique.
column "notification_level" of relation "user_chat_channel_memberships" already exists
Summary
ALTER TABLE
ALTER TABLE
ALTER TABLE
ALTER TABLE
ALTER TABLE
Migrating the database…
EXCEPTION: /var/www/discourse/lib/discourse.rb:139:in `exec’: Failed to migrate database.
rake aborted!
StandardError: An error has occurred, all later migrations canceled: (StandardError)
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in exec' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in async_exec’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:56:in block (2 levels) in raw_execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1004:in block in with_raw_connection’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/concurrency/null_lock.rb:9:in synchronize' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:976:in with_raw_connection’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:55:in block in raw_execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/notifications/instrumenter.rb:58:in instrument’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1119:in log' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:54:in raw_execute’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:538:in internal_execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:137:in execute’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/query_cache.rb:27:in execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:48:in execute’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/schema_statements.rb:629:in add_column' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/schema_statements.rb:418:in add_column’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration/default_strategy.rb:10:in method_missing' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1059:in block in method_missing’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1025:in block in say_with_time' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/benchmark-0.4.0/lib/benchmark.rb:304:in measure’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1025:in say_with_time' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1048:in method_missing’
/var/www/discourse/plugins/chat/db/migrate/20241003122030_add_notification_level_to_user_chat_channel_memberships.rb:10:in up' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:997:in public_send’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:997:in exec_migration' /var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in block in exec_migration’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/benchmark-0.4.0/lib/benchmark.rb:304:in measure' /var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in exec_migration’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:978:in block (2 levels) in migrate' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/benchmark-0.4.0/lib/benchmark.rb:304:in measure’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:977:in block in migrate' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:415:in with_connection’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:976:in migrate' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1190:in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1538:in block in execute_migration_in_transaction' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1591:in ddl_transaction’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1537:in execute_migration_in_transaction' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1512:in each’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1512:in migrate_without_lock' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1457:in block in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1609:in with_advisory_lock' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1457:in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1264:in up' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1239:in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/tasks/database_tasks.rb:262:in migrate' /var/www/discourse/lib/tasks/db.rake:259:in block (2 levels) in ’
/var/www/discourse/lib/distributed_mutex.rb:53:in block in synchronize' /var/www/discourse/lib/distributed_mutex.rb:49:in synchronize’
/var/www/discourse/lib/distributed_mutex.rb:49:in synchronize' /var/www/discourse/lib/distributed_mutex.rb:34:in synchronize’
/var/www/discourse/lib/tasks/db.rake:234:in block in <main>' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in <top (required)>’
Caused by:
ActiveRecord::StatementInvalid: PG::DuplicateColumn: ERROR: column “notification_level” of relation “user_chat_channel_memberships” already exists (ActiveRecord::StatementInvalid)
Caused by:
Tasks: TOP => db:migrate
/var/www/discourse/lib/discourse.rb:173:in execute_command' /var/www/discourse/lib/discourse.rb:139:in exec’
/var/www/discourse/lib/discourse.rb:35:in execute_command' /var/www/discourse/lib/backup_restore/database_restorer.rb:153:in migrate_database’
/var/www/discourse/lib/backup_restore/database_restorer.rb:28:in restore' /var/www/discourse/lib/backup_restore/restorer.rb:61:in run’
script/discourse:191:in restore' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/command.rb:28:in run’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in invoke_command' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor.rb:538:in dispatch’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/base.rb:584:in start' script/discourse:345:in <top (required)>’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:58:in load' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:58:in kernel_load’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:23:in run' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:455:in exec’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in invoke_command' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor.rb:527:in dispatch’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:35:in dispatch' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/base.rb:584:in start’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:29:in start' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/exe/bundle:28:in block in <top (required)>’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/friendly_errors.rb:117:in with_friendly_errors' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/exe/bundle:20:in <top (required)>’
/usr/local/bin/bundle:25:in load' /usr/local/bin/bundle:25:in
Trying to rollback…
Rolling back…
Cleaning stuff up…
Dropping functions from the discourse_functions schema…
Removing tmp ‘/var/www/discourse/tmp/restores/default/2025-01-09-180715’ directory…
Unpausing sidekiq…
Marking restore as finished…
Notifying ‘system’ of the end of the restore…
Finished!
[FAILED]
Wie kann ich eine SQL-Datei reparieren, damit db:migrate erfolgreich ausgeführt wird?
Auf welchem Commit befindet sich die alte Website?
Es gab ein paar Regressionen, bei denen ein Commit eine Migration enthielt, die er nicht hätte enthalten dürfen. Ich vermute, dass dies einer dieser Fälle ist.
Haben Sie exakt die gleichen Plugins auf beiden Instanzen?
Auf welchem Commit befindet sich Ihr bestehendes Discourse und auf welchem Commit des Chat-Plugins?
Ich schätze Ihre freundliche Beteiligung. Der SQL-Dump ist 45 GB groß und die Arbeit daran dauert ewig.
Ich habe versucht, am 31. Dezember ein GUI-Update auszuführen, das die DB-Migration zum Hängen brachte. Die alte Website ist seit dem 06. Januar weg, alles, was ich habe, ist ein SQL-Dump und gespeicherte Medien-Uploads. Ich versuche, eine neue Website zu starten und meine DB dort wiederherzustellen. Ich verwende nur wenige Plugins in meiner YAML:
Wie lautet der Dateiname Ihres Backups? (Es enthält Informationen über die letzte ausgeführte Migration)
sitename-2025-01-06-033732-v20240912212253.sql.gz
Bei der manuellen Wiederherstellung wurden folgende Probleme gemeldet (könnte auch etwas bedeuten):
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842596361: FEHLER: konnte eindeutigen Index „category_featured_topics_pkey“ nicht erstellen
DETAIL: Schlüssel (id)=(14) ist doppelt vorhanden.
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842596928: FEHLER: konnte eindeutigen Index „incoming_links_pkey“ nicht erstellen
DETAIL: Schlüssel (id)=(1) ist doppelt vorhanden.
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842596937: FEHLER: konnte eindeutigen Index „incoming_referers_pkey“ nicht erstellen
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842597117: FEHLER: konnte eindeutigen Index „post_hotlinked_media_pkey“ nicht erstellen
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842597378: FEHLER: konnte eindeutigen Index „sitemaps_pkey“ nicht erstellen
DETAIL: Schlüssel (id)=(2) ist doppelt vorhanden.
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842597693: FEHLER: konnte eindeutigen Index „upload_references_pkey“ nicht erstellen
DETAIL: Schlüssel (id)=(8) ist doppelt vorhanden.
Das ist interessant.
  • Diese Konflikte betreffen ziemlich triviale Tabellen und die konfliktierenden IDs sind niedrig
  • Ihr Backup ist vom September und die Migration column "notification_level" of relation "user_chat_channel_memberships" already exists ist vom Oktober, sodass sie auf Ihrer vorherigen Instanz nicht ausgeführt wurde und eine der ersten Migrationen ist, die nach der Wiederherstellung durchgeführt wird.
Das klingt für mich nach einem anderen Problem. Handelt es sich um eine Standardinstallation? Und war Ihre vorherige Instanz eine Standardinstallation? Ich habe eine Ahnung, dass das Backup nicht im richtigen Schema wiederhergestellt wird und die Migrationen gegen eine leere Instanz ausgeführt werden.
Ja, es ist eine Standard-Docker-Installation und meine ursprüngliche Website wurde 2015 mit diesem Handbuch erstellt.
Gibt es etwas, das ich aus der Postgres- oder Rails-Konsole abrufen kann, um Licht auf die Situation zu werfen?
Danke,
Jeder Hinweis, Tipp oder jede Richtung wird sehr geschätzt.
Meinen Sie ein reines SQL-Discourse-Backup oder einen SQL-Dump, den Sie auf andere Weise erstellt haben?
Nur Discourse-Backup.
Zu Hause habe ich PostgreSQL eingerichtet, und unser Datenbackup wurde fast ohne Probleme wiederhergestellt.
Es scheint, dass beim Wiederherstellen der Datei in PostgreSQL (die sich im Discourse-Container befindet) die alte Datenbank nicht gelöscht wird, und dies verursacht einen Konflikt, der verhindert, dass das Backup ordnungsgemäß bereitgestellt wird.
Das klingt nach dem, was Richard gesagt hat.
Es gab kürzlich einige Commits bezüglich Postgres, obwohl ich nicht sicher bin, ob sie akzeptiert wurden. Sie könnten versuchen, neu zu kompilieren, bevor Sie erneut versuchen, wiederherzustellen.
Beim Wiederherstellen eines sql.gz-Archivs sehe ich Folgendes:
Archiv in temporäres Verzeichnis kopieren…
Dumpdatei extrahieren…
Metadaten validieren…
Aktuelle Version: 20241224191732
Wiederhergestellte Version: 20240912212253
und offensichtlich schlägt die db:migration mit dem im Beitrag #1 gemeldeten Fehler fehl.
Ich sehe, dass die PostgreSQL-Datenbank “discourse” mit allen erforderlichen Tabellen/Daten wiederhergestellt wurde:
psql (13.18 (Debian 13.18-1.pgdg120+1))
Geben Sie “help” für Hilfe ein.
discourse=> \dn+
                                  List of schemas
        Name         |   Owner   |   Access privileges    |      Description
 backup              | discourse |                        |
 discourse_functions | discourse |                        |
 public              | discourse | discourse=UC/discourse+| standard public schema
                     |           | =UC/discourse          |
(3 rows)
discourse=> discourse=> \l
                                  List of databases
   Name    |  Owner   | Encoding |   Collate   |    Ctype    |   Access privileges
 discourse | postgres | UTF8     | en_US.UTF-8 | en_US.UTF-8 | =Tc/postgres          +
           |          |          |             |             | postgres=CTc/postgres +
           |          |          |             |             | discourse=CTc/postgres
 postgres  | postgres | UTF8     | en_US.UTF-8 | en_US.UTF-8 |
 template0 | postgres | UTF8     | en_US.UTF-8 | en_US.UTF-8 | =c/postgres           +
 template1 | postgres | UTF8     | en_US.UTF-8 | en_US.UTF-8 | =c/postgres           +
(4 rows)
aber rake meldet, dass es die falsche DB verwendet:
rake db:version
database: discourse
Current version: 20241224191732
Wie weise ich rake auf 20240912212253 hin?
Danke
Dies geschieht, wenn es ein Berechtigungsproblem gibt. Discourse jongliert mit Schemas während der Wiederherstellung, und wenn es keine Berechtigungen hat, die Tabellen in der Datenbank aufzulisten, gehen die Dinge schief.
Obwohl ich das noch nie erlebt habe, könnte dies auch ein Problem mit dem verfügbaren Festplattenspeicher sein?
Nur ein Bauchgefühl: Könnte es nach einem Restore zu einem Timeout bei Tabellenverschiebungen kommen?
Danke für den Hinweis.
Der Speicherplatz ist kein Problem; ich habe 6-7 Mal mehr Speicherplatz als die DB-Größe. Ich kann einen manuellen Import versuchen, bevor ich die Migration durchführe, und die Berechtigungen beheben. Die Frage ist, was genau gewährt werden muss?
Ich denke, Sie müssen das manuelle Skript auf diese Weise aktualisieren:
DROP SCHEMA public CASCADE;
CREATE SCHEMA public;
ALTER SCHEMA public OWNER TO discourse;
CREATE EXTENSION IF NOT EXISTS hstore;
CREATE EXTENSION IF NOT EXISTS pg_trgm;
END;
Es ist nicht notwendig, SCHEMA public zu erstellen (und den Besitzer festzulegen), da neuere Pg-Versionen das Schema aus dem SQL-Backup-Dump erstellen.
Die Tabellenberechtigungen müssen jedoch auf den Benutzer discourse korrigiert werden, standardmäßig sind sie postgres.
Jetzt funktioniert es! Vielen Dank an alle für die Ideen und die Unterstützung.
