Problema ao restaurar Discourse a partir de backup (3.4, banco de dados bastante grande)
Hi there,
We are one of your early bird users, we are using Discourse since 2015.
It works just fine until latest update with Postgres update included (possibly 3.4?). We have one backup points before this update. We decide to make clean install then restore from this backup.
OS: Ubuntu 24.04.1 LTS (latest updates) + docker 26.1.3
Trying to restore large discourse backup (44GB, single site) to a blank container.
Automated restore fails on DB migration with following error:
PG::DuplicateColumn: ERROR: column “notification_level” of relation “user_chat_channel_memberships” already exists (PG::DuplicateColumn)
logs:
Specifically, the migration stops after deploying the SQL archive because a column in the database is not unique.
column "notification_level" of relation "user_chat_channel_memberships" already exists
Summary
ALTER TABLE
ALTER TABLE
ALTER TABLE
ALTER TABLE
ALTER TABLE
Migrating the database
EXCEPTION: /var/www/discourse/lib/discourse.rb:139:in `exec’: Failed to migrate database.
rake aborted!
StandardError: An error has occurred, all later migrations canceled: (StandardError)
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in exec' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in async_exec’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:56:in block (2 levels) in raw_execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1004:in block in with_raw_connection’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/concurrency/null_lock.rb:9:in synchronize' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:976:in with_raw_connection’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:55:in block in raw_execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/notifications/instrumenter.rb:58:in instrument’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1119:in log' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:54:in raw_execute’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:538:in internal_execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:137:in execute’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/query_cache.rb:27:in execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:48:in execute’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/schema_statements.rb:629:in add_column' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/schema_statements.rb:418:in add_column’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration/default_strategy.rb:10:in method_missing' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1059:in block in method_missing’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1025:in block in say_with_time' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/benchmark-0.4.0/lib/benchmark.rb:304:in measure’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1025:in say_with_time' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1048:in method_missing’
/var/www/discourse/plugins/chat/db/migrate/20241003122030_add_notification_level_to_user_chat_channel_memberships.rb:10:in up' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:997:in public_send’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:997:in exec_migration' /var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in block in exec_migration’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/benchmark-0.4.0/lib/benchmark.rb:304:in measure' /var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in exec_migration’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:978:in block (2 levels) in migrate' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/benchmark-0.4.0/lib/benchmark.rb:304:in measure’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:977:in block in migrate' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:415:in with_connection’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:976:in migrate' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1190:in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1538:in block in execute_migration_in_transaction' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1591:in ddl_transaction’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1537:in execute_migration_in_transaction' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1512:in each’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1512:in migrate_without_lock' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1457:in block in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1609:in with_advisory_lock' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1457:in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1264:in up' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1239:in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/tasks/database_tasks.rb:262:in migrate' /var/www/discourse/lib/tasks/db.rake:259:in block (2 levels) in ’
/var/www/discourse/lib/distributed_mutex.rb:53:in block in synchronize' /var/www/discourse/lib/distributed_mutex.rb:49:in synchronize’
/var/www/discourse/lib/distributed_mutex.rb:49:in synchronize' /var/www/discourse/lib/distributed_mutex.rb:34:in synchronize’
/var/www/discourse/lib/tasks/db.rake:234:in block in <main>' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in <top (required)>’
Caused by:
ActiveRecord::StatementInvalid: PG::DuplicateColumn: ERROR: column “notification_level” of relation “user_chat_channel_memberships” already exists (ActiveRecord::StatementInvalid)
Caused by:
Tasks: TOP => db:migrate
/var/www/discourse/lib/discourse.rb:173:in execute_command' /var/www/discourse/lib/discourse.rb:139:in exec’
/var/www/discourse/lib/discourse.rb:35:in execute_command' /var/www/discourse/lib/backup_restore/database_restorer.rb:153:in migrate_database’
/var/www/discourse/lib/backup_restore/database_restorer.rb:28:in restore' /var/www/discourse/lib/backup_restore/restorer.rb:61:in run’
script/discourse:191:in restore' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/command.rb:28:in run’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in invoke_command' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor.rb:538:in dispatch’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/base.rb:584:in start' script/discourse:345:in <top (required)>’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:58:in load' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:58:in kernel_load’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:23:in run' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:455:in exec’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in invoke_command' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor.rb:527:in dispatch’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:35:in dispatch' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/base.rb:584:in start’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:29:in start' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/exe/bundle:28:in block in <top (required)>’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/friendly_errors.rb:117:in with_friendly_errors' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/exe/bundle:20:in <top (required)>’
/usr/local/bin/bundle:25:in load' /usr/local/bin/bundle:25:in ’
Trying to rollback
Rolling back
Cleaning stuff up
Dropping functions from the discourse_functions schema
Removing tmp ‘/var/www/discourse/tmp/restores/default/2025-01-09-180715’ directory
Unpausing sidekiq
Marking restore as finished
Notifying ‘system’ of the end of the restore
Finished!
[FAILED]
Como corrigir um arquivo SQL para que db:migrate seja executado com sucesso?
Em qual commit o site antigo estĂĄ?
Houve algumas regressÔes em que um commit incluiu uma migração que não deveria ter incluído. Minha suposição é que este seja um desses casos.
VocĂȘ tem exatamente o mesmo conjunto de plugins em ambas as instĂąncias?
Em qual commit estĂĄ o seu Discourse existente e em qual commit do plugin de chat ele estĂĄ?
Agradeço seu gentil envolvimento. O dump SQL tem 45 GB, leva uma eternidade para trabalhar.
Tentei executar a atualização da GUI em 31 de dezembro, o que fez a migração do banco de dados travar. O site antigo desapareceu desde 06 de janeiro, tudo o que tenho é o dump SQL e os uploads de mídia salvos. Estou tentando iniciar um site novo e restaurar meu banco de dados lå. Executando apenas alguns plugins no meu YAML:
Qual Ă© o nome do arquivo de backup? (Ele contĂ©m informaçÔes sobre a Ășltima migração que foi executada)
sitename-2025-01-06-033732-v20240912212253.sql.gz
Ao fazer a restauração manual, os seguintes problemas foram relatados (podem significar algo também):
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842596361: ERRO: nĂŁo foi possĂ­vel criar o Ă­ndice Ășnico “category_featured_topics_pkey”
DETALHE: Chave (id)=(14) estĂĄ duplicada.
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842596928: ERRO: nĂŁo foi possĂ­vel criar o Ă­ndice Ășnico “incoming_links_pkey”
DETALHE: Chave (id)=(1) estĂĄ duplicada.
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842596937: ERRO: nĂŁo foi possĂ­vel criar o Ă­ndice Ășnico “incoming_referers_pkey”
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842597117: ERRO: nĂŁo foi possĂ­vel criar o Ă­ndice Ășnico “post_hotlinked_media_pkey”
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842597378: ERRO: nĂŁo foi possĂ­vel criar o Ă­ndice Ășnico “sitemaps_pkey”
DETALHE: Chave (id)=(2) estĂĄ duplicada.
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842597693: ERRO: nĂŁo foi possĂ­vel criar o Ă­ndice Ășnico “upload_references_pkey”
DETALHE: Chave (id)=(8) estĂĄ duplicada.
Isso Ă© interessante.
  • esses conflitos estĂŁo em tabelas bastante triviais e os IDs conflitantes sĂŁo baixos
  • seu backup Ă© de setembro e a migração column "notification_level" of relation "user_chat_channel_memberships" already exists Ă© de outubro, entĂŁo ela nĂŁo foi executada em sua instĂąncia anterior, e Ă© uma das primeiras migraçÔes que Ă© feita apĂłs a restauração.
Isso me parece que vocĂȘ tem um problema diferente. Esta Ă© uma instalação padrĂŁo? E sua instĂąncia anterior era uma instalação padrĂŁo? Tenho a impressĂŁo de que o backup nĂŁo estĂĄ sendo restaurado no esquema correto e as migraçÔes estĂŁo sendo executadas em uma instĂąncia em branco.
Sim, é uma instalação padrão do docker e meu site original foi criado usando este manual em 2015.
Posso extrair algo do console postgres ou rails para esclarecer o que estĂĄ acontecendo?
Obrigado,
Qualquer dica, sugestão ou orientação serå muito apreciada.
VocĂȘ quer dizer um backup do Discourse apenas em SQL ou algum dump SQL que vocĂȘ fez de outra maneira?
Backup apenas do Discourse.
Em casa, configurei o PostgreSQL e nosso backup de dados foi restaurado quase sem problemas.
Parece que, ao restaurar o arquivo no PostgreSQL (que fica dentro do contĂȘiner do Discourse), o banco de dados antigo nĂŁo Ă© excluĂ­do, e isso causa um conflito, impedindo que o backup seja implantado corretamente.
Isso parece o que o Richard estava dizendo.
Houve alguns commits em torno do postgres recentemente, embora eu nĂŁo tenha certeza se eles foram aceitos. VocĂȘ pode tentar reconstruir antes de tentar restaurar novamente.
Ao restaurar o arquivo sql.gz, posso ver o seguinte:
Copiando o arquivo para o diretório tmp
Extraindo o arquivo de dump
Validando metadados
VersĂŁo atual: 20241224191732
VersĂŁo restaurada: 20240912212253
e obviamente db:migration falha com o erro relatado na postagem #1
Vejo que o banco de dados postgres “discourse” foi restaurado com todas as tabelas/dados necessários:
psql (13.18 (Debian 13.18-1.pgdg120+1))
Digite “help” para obter ajuda.
discourse=> \dn+
                                  List of schemas
        Name         |   Owner   |   Access privileges    |      Description
 backup              | discourse |                        |
 discourse_functions | discourse |                        |
 public              | discourse | discourse=UC/discourse+| standard public schema
                     |           | =UC/discourse          |
(3 rows)
discourse=> discourse=> \l
                                  List of databases
   Name    |  Owner   | Encoding |   Collate   |    Ctype    |   Access privileges
 discourse | postgres | UTF8     | en_US.UTF-8 | en_US.UTF-8 | =Tc/postgres          +
           |          |          |             |             | postgres=CTc/postgres +
           |          |          |             |             | discourse=CTc/postgres
 postgres  | postgres | UTF8     | en_US.UTF-8 | en_US.UTF-8 |
 template0 | postgres | UTF8     | en_US.UTF-8 | en_US.UTF-8 | =c/postgres           +
 template1 | postgres | UTF8     | en_US.UTF-8 | en_US.UTF-8 | =c/postgres           +
(4 rows)
mas o rake relata que estĂĄ usando o banco de dados errado:
rake db:version
database: discourse
Current version: 20241224191732
Como faço para apontar o rake para 20240912212253?
Obrigado
É isso que acontece quando há um problema de permissão. O Discourse manipula esquemas durante a restauração e, quando não tem permissão para enumerar as tabelas no banco de dados, as coisas dão errado.
Embora eu nunca tenha passado por isso, isso também pode ser um problema com o espaço em disco disponível?
Apenas um pressentimento: poderia haver um timeout durante a movimentação de tabelas após uma restauração?
Obrigado pela dica.
O espaço em disco não é um problema; tenho 6-7 vezes mais espaço do que o tamanho do banco de dados. Posso tentar uma importação manual antes de executar a migração e corrigir as permissÔes. A questão é, o que exatamente deve ser concedido?
Acho que vocĂȘ precisa atualizar o script manual desta forma:
DROP SCHEMA public CASCADE;
CREATE SCHEMA public;
ALTER SCHEMA public OWNER TO discourse;
CREATE EXTENSION IF NOT EXISTS hstore;
CREATE EXTENSION IF NOT EXISTS pg_trgm;
END;
NĂŁo hĂĄ necessidade de CREATE SCHEMA public (e definir o proprietĂĄrio), pois o Pg mais recente cria o esquema a partir do dump de backup do SQL.
No entanto, as permissÔes da tabela devem ser corrigidas para o usuårio discourse, por padrão elas são postgres.
Agora funciona! Obrigado a todos pelas ideias e apoio.
