I’m trying to reproduce this bug but I’m unable to do so on my instance. Do you have more details about the 500 error that you’re getting? There should be an error entry in /logs with a timestamp that corresponds to the time you attempt to delete the user. If you can share the details in the backtrace and info tab, it would make it much easier to figure out exactly where the problem is.
