특정 그룹에 전체 이름 노출 제한
Background
We are trying to set up our site to strike a balance between open access and privacy concerns:
  1. The site is public overall; anonymous users can browse, and search engines can index it. Usernames are public.
  2. Real names (full name) and profiles are considered semi-public; they should only be exposed to other community members (not to webcrawlers or anonymous lurkers).
  3. Email addresses are considered completely private; only admins should have access to those (and access is monitored).
Discourse already takes care of (1) and (3) by default. (Yay!) We are having trouble achieving (2).
By disabling “Display name on posts” and enabling “Hide user profiles from public”, we get something that seems better-ish, but does not quite achieve (2). User-search results and Badge recipient lists still display full names.(*) And, even in places where the UI does not display the full names, the server is still sending them — e.g., in the JSON for a fetched topic, every post object still has the “name” (and “display_username”?) populated.
We want to make the promise to our users that “Your real name is only exposed to other community members” but we cannot do that if the server is leaking full names everywhere.
Proposed Feature
How about a “Restrict exposure of full name to groups” setting, with the following properties:
  • The setting value is an allowlist of groups (with some value that means “everyone, even anonymous users”).
  • If a query comes from a client session that matches against the allowlist, then the server responds with full names. Otherwise, any field that would bear a full name gets a null value (or is left out of the object, etc.)
I think that would take care of our (2) — and it would even allow us to set the bar for displaying real names at TL1 (versus TL0).
It occurs to me that what I am asking for might simply(:blush:) be a finer-grained version of the existing “Enable names” setting (if disabling that does what it promises on the server-side, and does not expose full names to the client). Maybe that would make this really easy to implement… :thinking:
Does this seem like a plausible feature for the Discourse core?
(Alternatively, does it seem achievable in a plugin? I’d rather see it in core, but I also want to be able to actually open our site to the public).
(*: Preventing anonymous users from doing user-searches and viewing badge recipient lists — and thus being able to trivially grab a list of all our users — is a whole 'nother topic, for another Topic.)
3개의 좋아요
후속 업데이트: 이 기능의 구현을 시작했습니다. 기본적인 접근 방식은 다음과 같습니다.
  • 새로운 사이트 설정 “그룹에 표시되는 전체 이름”(즉, 사용자의 전체 이름이 표시되는 그룹)을 추가합니다.
  • 사이트 설정을 확인하는 새로운 can_see_full_names? 예측자를 Guardian에 추가합니다.
  • SiteSetting.enable_names의 (많은) 인스턴스를 can_see_full_names? 예측자로 대체합니다.
대부분은 직관적이었습니다. 가장 큰 어려움은 직렬화기가 scope 매개변수를 전달하지 않는 것이었고, 이로 인해 별도의 작은 하위 프로젝트가 되었습니다.
2개의 좋아요
