The icon "clock" is missing from the default SVG subset
The icon is used for the date in the GitHub PR onebox.
Also, for pending posts:
It can be fixed easily by adding clock to the SVG icon subset setting.
However, since this is a part of the core, I think it should be available by default.
@kelv / @david any thoughts on this one?
Sounds reasonable to me. Would you like to make a PR for that @Arkshine? Otherwise we’ll take care of it :eyes:
It is weird that it works fine here on Meta. Perhaps some other plugin is registering the clock icon
Sure!
https://github.com/discourse/discourse/pull/31093
