Ошибка на ask.discourse.com: SyntaxError: Unexpected end of JSON input
Hey folks,
For the last 2-3 days, I keep encountering the same error message on ask.discourse.com:
3 лайка
Hmm… don’t seem to be seeing that:
Is there a specific question that you are using? Or is it across all questions/inputs?
1 лайк
Thanks for reporting @jrgong - I can repro this too and generate errors in the log. We’re having a look. :eyes:
4 лайка
I suspect this is rate limiting or some error with embedding backfilling, cause when I try to parse search results I get invalid json from a json API.
I put a safeguard in place.
We can later search our AI logs for “Failed to search” to see if it is still happening @Falco and I guess push the result.body somewhere.
So the errors should be gone now, but if search is failing hallucinations will go up.
Had trouble reproing this so I suspect there is an edge case with our new embeddings.
