Hi guys,
I highlighted some weird things happening on the mobile version of forum.francaisalondres.com - I was wondering if you knew what is happening.
Thanks for your help
Hi guys,
The French texts seem to work fine here on Meta, so I don’t think it’s a problem with the French translation in general.
Based on the errors in the browser console when looking at your forum, it seems loading the additional locale files fails.
Access to script at ‘https://forumfrancaisalondres.b-cdn.net//extra-locales/6a7897ea231de2274b38eb816410d3f1ac2fe4e4/fr/main.js’ from origin ‘https://forum.francaisalondres.com’ has been blocked by CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
I still don’t find the error between the desktop and the mobile version, any idea ?
I don’t think the issue is between desktop and mobile. For me, it’s broken on desktop too. I still think you need to fix the problem that’s causing the scripts to fail to load.
@Moin thanks for you answer, i have no idea how to fix it - Do you do paid jobs ?
That’s not my area of expertise. I can tell you that there is an error, but I can’t fix it. I’m sure you’ll find someone in Marketplace.
@pfaffman , any idea ?
Looks like it was that the CDN url had a trailing slash.
