Need a lottery Addon.
Such as the repo below:
Feature Introduction
  • The initiator can start a lottery based on a template in a specified category/tag.
  • Lottery posts must specify: lottery name, prizes, number of winners, drawing time, and a brief description.
  • Users participate by replying as required, no button clicking needed.
  • Automatic drawing at the specified time, excluding the initiator and duplicate users.
  • Automatically announce the winners in the topic.
  • Automatically add the tag “Lottery Ended” to the lottery topic.
  • Automatically add the tag “抽奖结束” (Lottery Ended).
  • Winners will be marked as winners in the winning post.
  • A system message will be automatically sent to the winners as notification.
  • After automatic drawing, the main post is automatically locked, preventing editing and replies (0710).
  • When posting, add 【抽奖】...【/抽奖】 (using square brackets) tags, and automatically check input content correctness, with front-end beautification (0711 requires cooperation with validation and beautification components).
  • New: Support setting a “Minimum Points” threshold for a single lottery (points come from the discourse-gamification plugin). If not set or set to 0, it means no restriction; users below the threshold will be automatically ignored, and a notice will be displayed on the topic page.
Usage Instructions
  1. The administrator sets the tags allowed for lotteries (e.g., Lottery Activity).
  2. Posting format example:
🎉 Floor-grabbing Activity: 2025 Summer Lottery
Prizes: One pair of Bluetooth headphones
Number of Winners: 2
Drawing Time: 2025-07-10 20:00
Minimum Points: 10
Brief Description: One entry per person, participation only via reply (one sentence)
Welcome to participate, good luck to everyone! Floor-grabbing activity instructions and posting method
Other activity descriptions and introductions.
  1. Users only need to reply to participate.
  2. The plugin automatically draws the lottery and announces the results.
AFAIK there’s no #plugin topic for lottery plugins. @joo might be still developing a plugin, but I’m not sure if it’s finished?
If you have a budget, you might want to consider opening a Marketplace topic.
hello @祁同伟
This is a too low quality topic. We do expect feature topics to be a little more fleshed out than a simple link. A description, mocks, use case, etc.
Can you update your post please.
I just saw a similar situation in another community, you can take a look (I haven’t actually used it)
Thank you very much for sharing, I will try to see if I can use it in my community!
I tested it today, and it really works, thank you!
