Настройка бесплатного плана Discourse — варианты трудно читаемы
In the setup page of the Discourse Free Plan, the options are quite hard to read:
6 лайков
@derek Tried to find this page, but you’ll be faster no doubt
2 лайка
Hey @NateDhaliwal! I couldn’t reproduce this in Chrome, Safari, and FF on MacOS in dark mode:
However, I did find a missing CSS variable on the dark mode background for those toggles that might be the culprit. Just pushed a fix:
4 лайка
Hi @derek , I’m still repo-ing this on Chrome, Windows 10.
Are you sure this isn’t a cache problem? Have you tried a hard (Ctrl+Shift+R) reload? Do you have dark reader installed?
Yup, just tried that, no change. No errors in the browser console (though I doubt it would appear there).
I just checked on my phone (iOS/Orion) and it looks as intended. Try going to /wizard on the site with a different browser, preferably one that hasn’t visited it before
1 лайк
@NateDhaliwal I just tried this in Chrome on Windows 10 no luck reproducing it. Are you seeing this locally or on a hosted instance?
Could you inspect the toggle element in DevTools(Right click → Inspect) and share what you see in the styles pane?
1 лайк
I’ve looked through the styles and this seems like the key part:
The --1e94960e-csstools-light-dark-toggle--2 variable is controlling the background color here.
From what I can tell, the --wizard-primary-900 variable is undefined, and the --csstools-color-scheme--light variable definition looks like this:
If one changes the background-color, or adding the variables and putting random colors like green or yellow, then things look more “correct” (though frankly, I have no idea why green or yellow don’t show up: I suspect it’s an incorrect syntax?):
3 лайка
Спасибо за детали, @NateDhaliwal. У меня есть предположение, что это связано с отсутствующей CSS-переменной при работе со светлой/тёмной темой и тем, как она компилируется через PostCSS. Похоже, браузер переходит к фоновому цвету светлой темы, что странно, так как я не могу воспроизвести эту проблему.
Судя по скриншотам, моё исправление ещё не было развернуто на вашем экземпляре. Сейчас оно должно быть развернуто, поэтому попробуйте ещё раз и дайте знать, если вы всё ещё заметите какие-либо неполадки.
1 лайк
Не воспроизводится.
