Erro 422 ao enviar mensagem para canal privado do Slack
When I try to send a test message to a private (but previously public) channel, I get a 422 error. When I check the logs, I see this:
Test provider failed {:error_key=>"chat_integration.provider.slack.errors.channel_not_found", :request=>"", :response_code=>"200", :response_body=>"{\"ok\":false,\"error\":\"channel_not_found\"}"}
This setup worked when the channel was private. I tried re-installing the Slack app and deleting the rules and recreating them. When I use @username rule or a public channel that seems to work well.
Double check you have configured all the “scopes” listed in the plugin topic: Set up Slack notifications using the discourse-chat-integration plugin
Do slash commands work from the private channel? If so, try creating a rule using those, and see whether it appears in the Discourse admin interface.
All scopes are configured as required by the docs.
/discourse watch private-category works from the private channel. I can see the rule get created in Discourse.
When I try to send a test message from Discourse with an ID of a topic in the private category, I get the 422.
chat integration discourse username is system
Temos o mesmo problema.
Curiosamente, as notificações para o Slack funcionam para o canal do Slack recém-criado, mas não para o antigo.
