500 error when approving a reviewable post after editing tags in /review (tags saved as objects, not strings)
Summary
In the review queue (/review), if a moderator edits the tags on a queued post and then clicks Approve, the approval request fails with a 500 Internal Server Error.
Steps to Reproduce
  1. Ensure a post is waiting in the review queue (e.g., from a user/group that requires approval).
  2. Go to /review.
  3. Open the queued item.
  4. Edit tags using the tag selector UI.
  5. Click Approve.
  6. Observe a 500 response.
Expected Behavior
The post should be approved successfully, with the updated tags applied.
Actual Behavior
Approval fails with a 500 error.
Example request pattern:
PUT /review/{id}/perform/approve_post?version={x} → 500 (Internal Server Error)
What Seems To Be Happening (Root Cause)
After editing tags in the review UI, the reviewable payload stores full tag objects instead of tag name strings.
Before editing tags:
payload["tags"] = ["tag-one", "tag-two"]
After editing tags in /review:
payload["tags"] = [
  {"id"=>123, "name"=>"tag-one", "description"=>nil, "count"=>50, ...},
  {"id"=>456, "name"=>"tag-two", "description"=>nil, "count"=>30, ...}
When the approve action processes tags, it appears to expect strings, but receives hashes/objects, leading to the 500.
Workaround
Normalize tags back to names:
r = ReviewableQueuedPost.find(ID)
r.payload["tags"] = r.payload["tags"].map { |t| t.is_a?(Hash) ? t["name"] : t }
r.save!
לייק 1
Thanks for reporting. We’ll have a look.
3 לייקים
This will be fixed in FIX: Cater for reviewable tag payloads that have been saved as names by nattsw · Pull Request #37477 · discourse/discourse · GitHub. Highly appreciate the quick bug report.
4 לייקים
This topic was automatically closed after 2 days. New replies are no longer allowed.
