Good Afternoon,
It appears we are facing a pair of issues, though I am unable to locate a direct solution.
Our AI has identified a user employing offensive language, and I have permanently terminated their account, beginning with the eradication of all posts/messages associated with said account. However, in the notifications, as depicted above, I find there is no option to eliminate or erase the persistent blue lines.
Am I overlooking something, or is there a method to remove these?
Bumping as I have found a similar situation to what I’m having issues with, but this topic is now closed.
I’ve done a rebuild just to see if that would fix the problem, and also ran the ./launcher cleanup, but nothing has worked.
Hi, really enjoying these AI modules, thanks a lot for the work put in!
I’ve configured the toxicity module with the detoxify service running locally, and its working for posts, but for DM’s, it will flag bad ones successfully, however when I visit the review/moderation page (the summart “all” page or the “flagged item” page for these messages) I get:
Server Error
while trying to load /review?priority=low&status=pending&sort_order=score
Error code: 500 Internal Server Error
That’s only fo…
sam
(Sam Saffron)
18 בדצמבר, 2023, 12:29am
3
what is in /logs when you get that 500 error?
Good morning sam.
Message (43 copies reported)
NoMethodError (undefined method `chat_channel' for nil:NilClass)
lib/freedom_patches/ams_include_without_root.rb:57:in `include!'
app/controllers/application_controller.rb:532:in `serialize_data'
app/controllers/application_controller.rb:541:in `render_serialized'
app/controllers/reviewables_controller.rb:145:in `show'
app/controllers/application_controller.rb:423:in `block in with_resolved_locale'
app/controllers/application_controller.rb:423:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
lib/middleware/anonymous_cache.rb:393:in `call'
lib/middleware/gtm_script_nonce_injector.rb:10:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/request_tracker.rb:233:in `call'
Backtrace
plugins/discourse-ai/app/serializers/reviewable_ai_chat_message_serializer.rb:13:in `chat_channel'
active_model_serializers (0.8.4) lib/active_model/serializer/associations.rb:71:in `associated_object'
active_model_serializers (0.8.4) lib/active_model/serializer/associations.rb:192:in `serialize'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:368:in `block in include_associations!'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:367:in `each_key'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:367:in `include_associations!'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:362:in `serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:343:in `as_json'
sam
(Sam Saffron)
18 בדצמבר, 2023, 7:15am
6
Thanks, we will look at this over the next week or so and add protection to the serializer.
לייק 1
jancernik
(Jan Cernik)
3 בינואר, 2024, 5:01pm
12
Hi @Aaron_Walsh , thanks for the report.
After this commit, you should be able to load the reviewables and dismiss the ones that were about the chat messages from that deleted user
https://github.com/discourse/discourse-ai/commit/d9c052f8e7671bbf72b32cf33a4431db7970958a
2 לייקים
Thank you immensely! While I had no reason to question the task at hand, this has indeed worked marvelously!
לייק 1
jancernik
(Jan Cernik)
נסגר ב־
4 בינואר, 2024, 11:00am
14
This topic was automatically closed after 17 hours. New replies are no longer allowed.
