After upgrading earlier this evening, I was getting 500 “Oops” error pages and in /logs I was seeing errors like this:
PG::InvalidTextRepresentation (ERROR: invalid input syntax for type inet: "unix:"
LINE 7: client_ip = 'unix:',
I have Discourse reverse proxied behind Caddy, and it turns out that the solution was to add
header_up X-Real-IP {remote_host}
to the reverse_proxy section in my Caddyfile, which I hadn’t needed before.
I figured out that X-Real-IP was needed due to the similar error message in this post.
I hope this helps someone having a similar problem.
