配置支持的跟踪分支以获取 Discourse 软件更新
:bookmark: This guide explains how to configure a supported tracking branch for your Discourse instance to manage software updates.
:person_raising_hand: Required user level: Systen Administrator
:warning: Console access is required.
Managing your Discourse instance’s tracking branch determines the frequency and type of updates you receive. This guide explains the different tracking branches available and provides a step-by-step approach to changing the branch on your setup.
Summary
Discourse offers three primary branches for tracking software updates: latest[1], stable, and beta. This documentation explains the purpose of each branch, their key features, and how to configure them in your Discourse instance.
Supported branches
latest[1:1]
:information_source: Recommended Default
This branch provides the latest bug fixes and compatibility updates for plugins. Every passing commit from the main branch is tested by the build server and added to the latest branch after successful verification.
  • Suitable for sites that want to stay up to date.
  • Sites are only notified about new updates during beta releases but can update manually at any time.
stable
:information_source: For Sites That Value Stability
The stable branch is intended for sites prioritizing stability and security over continuous updates.
  • Released every 4–6 months.
  • Only security fixes are backported between releases.
  • May have limited compatibility with community plugins and theme components.
:warning: Note: Not receiving regular maintenance updates can leave some features outdated or visually inconsistent.
beta
:information_source: Rarely Preferred
The beta branch is a milestone release that represents a collection of commits regularly pushed from latest[1:2].
  • Notifies administrators when a new collection of updates becomes available.
  • Ideal for meeting milestones but generally not recommended due to limited advantages over latest[1:3].
Other branches or references
:warning: Tracking other branches (e.g., custom branches or specific commit SHAs) is discouraged unless you have a specific need and expertise to support it.
Instructions for configuring your tracking branch
Follow these steps to configure the desired branch in your Discourse instance:
  1. Access the configuration file
    Open the app.yml configuration file by running the following commands in your console:
cd /var/discourse
git pull
nano containers/app.yml
The nano editor will open the configuration file.
2. Edit the tracking branch
Locate the version parameter by searching for the word “version” in the file:
params:
## Which Git revision should this container use? (default: latest)
#version: latest
  • Uncomment the version line.
  • Replace latest with your desired branch name (e.g., stable).Example:
params:
version: stable
  1. Save and exit
  • Press Ctrl+O to save your changes.
  • Press Enter to confirm.
  • Use Ctrl+X to exit the editor.
  1. Rebuild the container
    Once the changes are made and saved, rebuild the container to apply the new configuration:
git pull
./launcher rebuild app
:warning: This process might cause temporary downtime. Ensure to update the instance during non-working hours if possible.
  1. Previously “tests-passed” ↩︎ ↩︎ ↩︎ ↩︎
26 个赞
