502 gateway-fout na het proberen te verwijderen van een tag met 6000 gekoppelde onderwerpen
Hi,
After trying multiple times to delete a tag:
Discourse will be frozen for a couple of seconds and returns the following error from error log console:
Unicorn worker received USR2 signal indicating it is about to timeout, dumping backtrace for main thread
config/unicorn.conf.rb:309:in `backtrace'
config/unicorn.conf.rb:309:in `block (2 levels) in reload'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:69:in `exec_params'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/postgresql_adapter.rb:894:in `block (2 levels) in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract_adapter.rb:1028:in `block in with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.3.4/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract_adapter.rb:1000:in `with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/postgresql_adapter.rb:893:in `block in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.3.4/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract_adapter.rb:1143:in `log'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/postgresql_adapter.rb:892:in `exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/postgresql_adapter.rb:872:in `execute_and_clear'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:77:in `exec_delete'
/var/www/discours...
Any idea how to get this solved? :slight_smile:
Thanks!
Probably with something similar to
