I’m trying to delete 8 topics with the API but I get the following error after 4 of them have been deleted:
W20170727-16:21:10.014(2)? (STDERR) Request: [DELETE http://forum.docuss.org/t/6
75.json ]
W20170727-16:21:10.018(2)? (STDERR) Response: status=500 content=ActiveRecord::C
onnectionTimeoutError at /t/675.json
W20170727-16:21:10.023(2)? (STDERR) ============================================
W20170727-16:21:10.027(2)? (STDERR)
W20170727-16:21:10.029(2)? (STDERR) > could not obtain a database connection wit
hin 5.000 seconds (waited 5.000 seconds)
W20170727-16:21:10.033(2)? (STDERR)
W20170727-16:21:10.037(2)? (STDERR) config/initializers/100-quiet_logger.rb, lin
e 17
W20170727-16:21:10.040(2)? (STDERR) --------------------------------------------
W20170727-16:21:10.044(2)? (STDERR)
W20170727-16:21:10.047(2)? (STDERR) ``` ruby
W20170727-16:21:10.050(2)? (STDERR) 12 override = true
W20170727-16:21:10.053(2)? (STDERR) 13 Rails.logger.override_level
= Logger::ERROR
W20170727-16:21:10.056(2)? (STDERR) 14 end
W20170727-16:21:10.059(2)? (STDERR) 15 end
W20170727-16:21:10.062(2)? (STDERR) 16
W20170727-16:21:10.064(2)? (STDERR) > 17 call_without_quiet_assets(env).t
ap do
W20170727-16:21:10.068(2)? (STDERR) 18 if override
W20170727-16:21:10.070(2)? (STDERR) 19 Rails.logger.override_level
= nil
W20170727-16:21:10.074(2)? (STDERR) 20 end
W20170727-16:21:10.076(2)? (STDERR) 21 end
W20170727-16:21:10.079(2)? (STDERR) 22 end
W20170727-16:21:10.082(2)? (STDERR) ```
W20170727-16:21:10.085(2)? (STDERR)
W20170727-16:21:10.088(2)? (STDERR) App backtrace
W20170727-16:21:10.091(2)? (STDERR) -------------
W20170727-16:21:10.094(2)? (STDERR)
W20170727-16:21:10.097(2)? (STDERR) - config/initializers/100-quiet_logger.rb:1
7:in `call_with_quiet_assets'
W20170727-16:21:10.101(2)? (STDERR) - config/initializers/100-silence_logger.rb
:29:in `call'
W20170727-16:21:10.105(2)? (STDERR) - lib/middleware/missing_avatars.rb:21:in `
call'
W20170727-16:21:10.109(2)? (STDERR) - lib/middleware/turbo_dev.rb:34:in `call'
W20170727-16:21:10.112(2)? (STDERR)
W20170727-16:21:10.115(2)? (STDERR) Full backtrace
W20170727-16:21:10.119(2)? (STDERR) --------------
W20170727-16:21:10.122(2)? (STDERR)
W20170727-16:21:10.126(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_adapters/abstract/connection_pool.rb:189:in `block in wait_poll'
W20170727-16:21:10.130(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_adapters/abstract/connection_pool.rb:180:in `wait_poll'
W20170727-16:21:10.134(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_adapters/abstract/connection_pool.rb:135:in `block in poll'
W20170727-16:21:10.137(2)? (STDERR) - /home/sylvain/.rbenv/versions/2.3.0/lib/r
uby/2.3.0/monitor.rb:214:in `mon_synchronize'
W20170727-16:21:10.142(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_adapters/abstract/connection_pool.rb:145:in `synchronize'
W20170727-16:21:10.145(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_adapters/abstract/connection_pool.rb:133:in `poll'
W20170727-16:21:10.149(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_adapters/abstract/connection_pool.rb:425:in `acquire_connection'
W20170727-16:21:10.153(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_adapters/abstract/connection_pool.rb:349:in `block in checkout'
W20170727-16:21:10.157(2)? (STDERR) - /home/sylvain/.rbenv/versions/2.3.0/lib/r
W20170727-16:21:10.161(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_adapters/abstract/connection_pool.rb:348:in `checkout'
W20170727-16:21:10.164(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_adapters/abstract/connection_pool.rb:263:in `block in connection'
W20170727-16:21:10.168(2)? (STDERR) - /home/sylvain/.rbenv/versions/2.3.0/lib/r
W20170727-16:21:10.172(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_adapters/abstract/connection_pool.rb:262:in `connection'
W20170727-16:21:10.176(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_adapters/abstract/connection_pool.rb:571:in `retrieve_connection'
W20170727-16:21:10.179(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_handling.rb:113:in `retrieve_connection'
W20170727-16:21:10.183(2)? (STDERR) - activerecord (4.2.8) lib/active_record/co
nnection_handling.rb:87:in `connection'
W20170727-16:21:10.187(2)? (STDERR) - activerecord (4.2.8) lib/active_record/mi
gration.rb:383:in `connection'
W20170727-16:21:10.191(2)? (STDERR) - activerecord (4.2.8) lib/active_record/mi
gration.rb:370:in `call'
W20170727-16:21:10.195(2)? (STDERR) - actionpack (4.2.8) lib/action_dispatch/mi
ddleware/callbacks.rb:29:in `block in call'
W20170727-16:21:10.199(2)? (STDERR) - activesupport (4.2.8) lib/active_support/
callbacks.rb:88:in `__run_callbacks__'
W20170727-16:21:10.202(2)? (STDERR) - activesupport (4.2.8) lib/active_support/
callbacks.rb:778:in `_run_call_callbacks'
W20170727-16:21:10.206(2)? (STDERR) - activesupport (4.2.8) lib/active_support/
callbacks.rb:81:in `run_callbacks'
W20170727-16:21:10.210(2)? (STDERR) - actionpack (4.2.8) lib/action_dispatch/mi
ddleware/callbacks.rb:27:in `call'
W20170727-16:21:10.216(2)? (STDERR) - actionpack (4.2.8) lib/action_dispatch/mi
ddleware/reloader.rb:73:in `call'
W20170727-16:21:10.220(2)? (STDERR) - actionpack (4.2.8) lib/action_dispatch/mi
ddleware/remote_ip.rb:78:in `call'
W20170727-16:21:10.225(2)? (STDERR) - better_errors (2.1.1) lib/better_errors/m
iddleware.rb:84:in `protected_app_call'
W20170727-16:21:10.229(2)? (STDERR) - better_errors (2.1.1) lib/better_errors/m
iddleware.rb:79:in `better_errors_call'
W20170727-16:21:10.234(2)? (STDERR) - better_errors (2.1.1) lib/better_errors/m
iddleware.rb:57:in `call'
W20170727-16:21:10.237(2)? (STDERR) - actionpack (4.2.8) lib/action_dispatch/mi
ddleware/debug_exceptions.rb:17:in `call'
W20170727-16:21:10.242(2)? (STDERR) - actionpack (4.2.8) lib/action_dispatch/mi
ddleware/show_exceptions.rb:30:in `call'
W20170727-16:21:10.247(2)? (STDERR) - logster (1.2.7) lib/logster/middleware/re
porter.rb:31:in `call'
W20170727-16:21:10.251(2)? (STDERR) - railties (4.2.8) lib/rails/rack/logger.rb
:38:in `call_app'
W20170727-16:21:10.254(2)? (STDERR) - railties (4.2.8) lib/rails/rack/logger.rb
:22:in `call'
W20170727-16:21:10.258(2)? (STDERR) - config/initializers/100-quiet_logger.rb:1
W20170727-16:21:10.262(2)? (STDERR) - config/initializers/100-silence_logger.rb
:29:in `call'
W20170727-16:21:10.266(2)? (STDERR) - actionpack (4.2.8) lib/action_dispatch/mi
ddleware/request_id.rb:21:in `call'
W20170727-16:21:10.269(2)? (STDERR) - rack (1.6.8) lib/rack/methodoverride.rb:2
2:in `call'
W20170727-16:21:10.273(2)? (STDERR) - rack (1.6.8) lib/rack/runtime.rb:18:in `c
all'
W20170727-16:21:10.277(2)? (STDERR) - actionpack (4.2.8) lib/action_dispatch/mi
ddleware/static.rb:120:in `call'
W20170727-16:21:10.280(2)? (STDERR) - actionpack (4.2.8) lib/action_dispatch/mi
W20170727-16:21:10.284(2)? (STDERR) - rack (1.6.8) lib/rack/sendfile.rb:113:in
`call'
W20170727-16:21:10.288(2)? (STDERR) - lib/middleware/missing_avatars.rb:21:in `
call'
W20170727-16:21:10.291(2)? (STDERR) - lib/middleware/turbo_dev.rb:34:in `call'
W20170727-16:21:10.294(2)? (STDERR) - rack-mini-profiler (0.10.5) lib/mini_prof
iler/profiler.rb:282:in `call'
W20170727-16:21:10.299(2)? (STDERR) - message_bus (2.0.2) lib/message_bus/rack/
middleware.rb:62:in `call'
W20170727-16:21:10.302(2)? (STDERR) - railties (4.2.8) lib/rails/engine.rb:518:
in `call'
W20170727-16:21:10.306(2)? (STDERR) - railties (4.2.8) lib/rails/application.rb
:165:in `call'
W20170727-16:21:10.310(2)? (STDERR) - railties (4.2.8) lib/rails/railtie.rb:194
:in `method_missing'
W20170727-16:21:10.314(2)? (STDERR) - rack (1.6.8) lib/rack/urlmap.rb:66:in `bl
ock in call'
W20170727-16:21:10.317(2)? (STDERR) - rack (1.6.8) lib/rack/urlmap.rb:50:in `ca
ll'
W20170727-16:21:10.321(2)? (STDERR) - rack (1.6.8) lib/rack/content_length.rb:1
5:in `call'
W20170727-16:21:10.324(2)? (STDERR) - puma (3.9.1) lib/puma/configuration.rb:22
4:in `call'
W20170727-16:21:10.328(2)? (STDERR) - puma (3.9.1) lib/puma/server.rb:602:in `h
andle_request'
W20170727-16:21:10.332(2)? (STDERR) - puma (3.9.1) lib/puma/server.rb:435:in `p
rocess_client'
W20170727-16:21:10.336(2)? (STDERR) - puma (3.9.1) lib/puma/server.rb:299:in `b
lock in run'
W20170727-16:21:10.339(2)? (STDERR) - puma (3.9.1) lib/puma/thread_pool.rb:120:
in `block in spawn_thread'
W20170727-16:21:10.343(2)? (STDERR)
W20170727-16:21:10.346(2)? (STDERR)
W20170727-16:21:10.349(2)? (STDERR) at makeErrorByStatus (packages/http/http
call_common.js:13:10)
W20170727-16:21:10.352(2)? (STDERR) at Request._callback (packages/http/http
call_server.js:113:17)
W20170727-16:21:10.358(2)? (STDERR) at Request.self.callback (C:\Users\Sylva
in\AppData\Local\.meteor\packages\http\1.2.12\npm\node_modules\request\request.j
s:200:22)
W20170727-16:21:10.363(2)? (STDERR) at emitTwo (events.js:87:13)
W20170727-16:21:10.366(2)? (STDERR) at Request.emit (events.js:172:7)
W20170727-16:21:10.370(2)? (STDERR) at Request.<anonymous> (C:\Users\Sylvain
\AppData\Local\.meteor\packages\http\1.2.12\npm\node_modules\request\request.js:
1067:10)
W20170727-16:21:10.375(2)? (STDERR) at emitOne (events.js:82:20)
W20170727-16:21:10.378(2)? (STDERR) at Request.emit (events.js:169:7)
W20170727-16:21:10.381(2)? (STDERR) at IncomingMessage.<anonymous> (C:\Users
\Sylvain\AppData\Local\.meteor\packages\http\1.2.12\npm\node_modules\request\req
uest.js:988:12)
W20170727-16:21:10.387(2)? (STDERR) at emitNone (events.js:72:20)
I get the error both when I run the queries in parallel and when I run them in sequence.
Any idea?
I use a dev Discourse instance.
