Algunas preguntas sobre mover o eliminar temas por lotes
Hi. I’ve imported data from a phpbb and I’m reworking all the categories.
How do I move or delete all the topics from:
  1. One category (well I’m aware of Topic.where(category_id: XX).update_all(category_id: YY) but I don’t know how to delete topics this way)?
  2. Multiples categories?
  3. All the subcategories from a target parent category?
Thank you.
I usually create an array with the category ID that I don’t want and modify the category importer to skip those categories and makes sure that the topic importer skips topics if the category doesn’t exist.
1 me gusta
Hi, thank you for your reply.
Which file(s) should I modify? Is such a modification quick and straightforward or does it need work to be functional?
If I can avoid re-importing my forum I’d prefer though.
Also, I noticed that after moving some posts with Topic.where(category_id: XX).update_all(category_id: YY) the number of messages was not updated and it seems that it couldn’t be either from sidekiq tasks. Also, it moved the “about this category” topic which can’t be deleted.
I guess this is a more proper way to do so: https://meta.discourse.org/t/best-way-to-combine-merge-categories-when-importing-topics/21353/6 but it doesn’t tell me how to properly delete all messages from a category, just how to move them.
Las soluciones se encuentran aquí :+1::
3 Me gusta
