A similar object exists in test mode error
Has anyone else gotten this error when, after having used the test api keys, tried to subscribe using the same user with the live keys in place?
a similar object exists in test mode, but a live mode key was used to make this request.
Yeah, I remember having that problem. Can’t recall how I got around it - think it was simply by deleting the test stuff.
It did strike me as a bit odd, but it is definitely a Stripe thing and nothing to do with the plugin.
I works the you need to delete the test records from rails. Don’t know how to do that offhand.
That sounds like a significant bug! I can’t recall if I did that (might well have), but that really shouldn’t be necessary.
It seems like an edge case that you’d have a test user in test mode that would then be a real paying customer.
