Ability to "like" / +1 a post via email reply
Something to the effect of "You can like things by replying to this email with the text ‘Like’ (localized to the instance’s language), or ‘+1’ "
「いいね!」 2
Hi, I’m re-opening this topic to continue the conversation about exposing the +1 in email. What do you think about putting it in this error message instead?
See, my reply message was too short only because I was trying to say, “Got it. Thank you!” It didn’t make sense for me to make that longer, so after some research I discovered what the Like behavior was for. But then I thought, “How do I Like via email?”, which finally took me to this thread.
I imagine that other people whose reply was too short were also trying to “Like” a post in their own way, in which case instead of just having “If you can correct the problem, please try again”, you can also say “If you were trying to say “Thank you”, “I agree”, or another term of gratitude or agreement, you can reply with +1 to Like the post instead.”
「いいね!」 8
This is a great suggestion, @Osama can you improve the text here.
Instead of Body is too short (minimum is 20 characters)
Your reply was too short, minimum length is 20 characters. Alternatively, you can like a post via email by replying with ‘+1’.
@codinghorror is that text OK? I am really not a fan of the “Body is too short” text anyway cause it is way too … computery.
「いいね!」 7
We could get very “instructive” here ..
To promote more in depth conversations, very short replies are not allowed. Can you please reply with at least 20 characters? Alternatively, you can like a post via email by replying with ‘+1’.
It’s not
We hate your short reply
so much as
We love actual conversations
「いいね!」 15
I think the idea of communicating
Is exactly right!
「いいね!」 2
I’ve sent a PR for improving the copy:
https://github.com/discourse/discourse/pull/6232
「いいね!」 9
私たちもそう思いますが、スマートな会話も大好きです。
「ありがとう」「私も」などで「血塗られた」議論は、本質的な部分にたどり着く前に読みづらくなります。
では、以下の質問に対する答えはありますか?
これは実際に実装されていますか?そのように文書化されていますか?他に「魔法」的な返信はありますか?
「いいね!」 1
はい、このトピックの少し上の返信で述べられている通りです。
いいえ。
「いいね!」 2
つまり、いいえです。:slight_smile:
ふむ。GNOME discourse のような一部のサイトのドキュメントでは、watch、track、mute が機能すると示唆されています。これは彼らが使用しているプラグインによるものなのでしょうか?
あなたは他の種類の「投稿アクション」について尋ねていたと読みました。
トピックレベルのアクションには以下のようなものがあります。
「いいね!」 3
おお、すごい!ミュートトラックのウォッチメール返信については知りませんでした。メールからトピックや投稿のアクションを実行する方法について、「ヒント&コツ」カテゴリにトピックを作成するのは、ドキュメントのステップとして良いアイデアかもしれませんね。
「いいね!」 3
これは非常に強力な機能だと感じます。多くのコミュニティでは、これらのアクションを実行するためにログインする習慣を身につけてほしいという要望があるはずです。どこかにドキュメントとして残しておくと良いかもしれませんが、特に目立たせることは推奨しません。
なお、Discourse から送信されるすべてのメールの下部には、購読解除リンクがあります。それを選択すると、通知されている特定のトピックの購読を停止するか、そのサイトからのすべてのメールの購読を解除するかを選択するよう促されます。
「いいね!」 4
