グループのユーザーメール設定を変更する機能
It would be REALLY useful if there was a way to change certain default settings for groups of users.
I have a number of ‘Absent Friends’ who are those members who joined some months ago and either never re-visited or did for a while but then stopped.
I have the default setting for community Activity Summary emails set to 3-days as a general rule because I think this is a good balance for members who may use the site irregularly but are engaged.
However, if you do not visit at all, then you very quickly accumulate a very large volume of emails from a community that you are not engaged with, and therefore you are pushed into unsubscribing entirely (since you are probably not aware of, or interested in, editing your preferences).
It would be better for me to either switch long term Absent Friends to a weekly or monthly reminder, or to switch them to a different mailer entirely aimed at engaging them with the community as a whole rather than with specific threads.
Does anyone have any ideas for a work-around that does not involve me impersonating each member individually to make these changes? Do you agree it would be a useful tool for Community Managers?
You can do it at the rails console. See Bulk suspend users based on criteria - #4 by blake for something similar.
「いいね!」 2
sadly I am not technical - I have no Rails knowledge and extremely limited SQL
I would need an admin tool / button / interface
Then you’d need a plugin or to do it via the API. Do you want to do it on-demand, or have it happen automatically periodically?
Are you self-hosted or using a hosting service? (I.e., are plugins an option?)
It’s not up to me, but his doesn’t seem like the kind of thing that’ll make it into core any time soon. Do you have a budget?
ありがとうございます。はい、おそらくその通りだと予想していました。急ぐ必要はありません。これは「要望リスト」的なもので、本来は機能提案(Features)に投稿すべきだったかもしれませんが、コミュニティに投稿したのは、私と同様に、ユーザーとのエンゲージメント向上(または離脱防止)に役立つ機能だと感じる人がいるかどうかを確認したかったからです。
私たちは Communiteq(旧 DiscourseHosting)でホストされており、プラグインを追加できるため、実現可能です。実際、現在カスタマイズ(おそらく CSS だけかもしれませんが)を手伝ってくれる人を探しており、この機能もその中に含められるかもしれません。
「いいね!」 1
I might be able to help. My contact info is in my profile.
「いいね!」 5
