Voeg een nieuw speciaal teken toe aan Kanban-thema-component, waarmee gebruikers 'alle categorieën' kunnen definiëren
Drew-ART is looking to add a special character to the Kanban theme component, allowing users to define ‘all categories’. This character, possibly ‘#’, would automatically apply Kanban views to all categories and subcategories, eliminating the need for manual setup. Drew-ART offered $250 for the task to be completed by November 26, 2023. Arkshine took on the task and successfully completed it, as confirmed by Drew-ART.
What would you like done?
The Kanban component currently has some special characters which define specific selections. I want a new special character/wildcard which defines ‘all’.
For example,
  • default modes: [All]:tags:backlog,sprint,doing,review,done
    so Kanban uses the above columns everywhere automatically, unless otherwise stated .
  • default view: [All]
    so all categories feature a Kanban board as the default view automatically.
The combination above means that new categories and sub categories won’t need to be manually set up with a kanban board as default view when created
Settings would look something like this:
Using a special character like # rather than all would reduce potential conflict issues
When do you need it done?
This Sunday evening (26/11/2023)
What is your budget, in $ USD that you can offer for this task?
$250
the Kanban component
If anyone wants to also fix the drag and drop of cards in mobile view which @david mentions in the 1st comment, drop me a quote as i may be able to fund it soon.
I’ll send you a PM. :slight_smile:
Task complete :partying_face: Thank you @Arkshine for a rapid turnaround and also very thorough build.
