إضافة دعم الأسماء المستعارة إلى منتقي الرموز التعبيرية
Twitter have alias support in the Emoji picker, it means that:
VS, what we have now:
It would be nice to have support for aliases on Discourse.
Note we should probably also add this as a fallback for : completion.
11 إعجابًا
Going to close this cause reading the code this is already supported, so the problem here is that we simply do not have enough aliases.
So for example :skel will show skull
4 إعجابات
While waiting for imports during the day :stuck_out_tongue: I implemented search aliases: FEATURE: adds emoji search aliases · discourse/discourse@691174f · GitHub
@sam I let you add the aliases you think are needed, the process is simple:
For others reading this, I prefer us going with search aliases in this case, aliases as we already have them will actually generate images, while search aliases is only a mapping of keywords to already existing emojis.
13 إعجابًا
The Unicode Consortium actually has a lot of resources regarding emojis. One of them is a list of emojis with keywords that could be used as search terms in the emoji picker. And there are even translations for emoji names and keywords.
9 إعجابات
