サインアップボタンにアイコンを追加する
Hello,
I want to add an icon to the register button using font awesome.
I looked everywhere for the html templates but I didn’t find them, so I guess they are being generated from javascript files, right?
Anyone can point me where I can add an icon to the register button?
For example:
this:
to:
Thanks in advance
Yes, that’s correct — those header buttons are a widget located here (more about widgets: A tour of how the Widget (Virtual DOM) code in Discourse works)
What I’m doing here is reopening the widget, copying the existing widget, and adding the line icon: user. You can add this to your theme’s </head> section in admin > customize > themes (or head_tag.html if you’re developing a remote theme)
<script type="text/discourse-plugin" version="0.8.13">
api.reopenWidget("header-buttons", {
      tagName: "span.header-buttons",
  html(attrs) {
    if (this.currentUser) {
      return;
    const buttons = [];
    if (attrs.canSignUp && !attrs.topic) {
      buttons.push(
        this.attach("button", {
          label: "sign_up",
          className: "btn-primary btn-small sign-up-button",
          action: "showCreateAccount",
          icon: "user"
    buttons.push(
        label: "log_in",
        className: "btn-primary btn-small login-button",
        action: "showLogin",
        icon: "user"
    return buttons;
</script>
Thank you, it worked.
