Problema con el icono invisible
Following script is not showing icon after font awesome 5.0 update.
Please help to make changes in the script.
        api.decorateWidget('header-buttons:after', helper => {
            if (Discourse.User.current()) {
                const createTopic = function() {
                    const Composer = require('discourse/models/composer').default;
                    const composerController = Discourse.__container__.lookup('controller:composer');
                    composerController.open({ action: Composer.CREATE_TOPIC, draftKey: Composer.DRAFT });
                return helper.h('button#create-new', {
                    className: "btn fa fa-plus",
                    title: "Create New Topic",
                    onclick: createTopic
                }, '' );  // ''-this is 'text' for the button, change as needed.
Assuming you have your own CSS for styling the button, this should get things pretty much back to the way they were:
  const { iconNode } = require("discourse-common/lib/icon-library");
            className: "btn fa fa-plus no-text",
        }, iconNode('plus') );
</script>
It worked perfectly
thanks
