הוסף אפשרות לתקעית לוח השנה, לאירועים, עבור תיבת סימון עבור "כל היום" עבור השעה
As the title describes, like may calendar-like applications (and calendars themselves), it would be nice to have a checkbox to say this is an all-day event and to not have to select a start and stop time.
3 לייקים
מקפיץ את זה מכיוון שזה פוגע קשות בעיצוב האירוע שלנו וחלק מהחברים שלנו עשויים להאמין שהאירוע מתחיל בשעה 3:00 לפנות בוקר לפי השעון שלהם תחת הפתרון הנוכחי שלנו.
לייק 1
Hi, in a related area of field there is a default event time parameter for all day event but it does not work so I created a tech issue for it. Setting in admin default start and end date for events has no effect in front end
לייק 1
תודה, אבל זו תהיה גם פונקציונליות טובה יותר פשוט לא להציג זמנים כלל, בדומה לאופן שבו פועל יומן גוגל - לאירוע של כל היום אין שעת התחלה או שעת סיום… כי זה אירוע של כל היום!
לייק 1
I totally agree. One thing though with the calendar plugin is that there is a long list of features that everyone wants and even such a “looking easy to implement” feature as this one may take time before being implemented(not blaming the devs, its great we have so much for free already).
However to remain solution oriented here I thought of a little hack (not saying I will do this script but here it is) :
-Devs were kind enough to set up a custom field that retains a value, you may with Javascript change it to an all day checkbox and bind an event that when the checkbox is checked, it sets the time of event from 00:00 to 23:59 and hides the hours fields directly.
I use it just use this field for showing the max participant of the event until the max participans feature is available.
By the way you said
our members may believe the event is actually starting at 3:00am their time under our current work around.
I’m curious, what’s the work around that generates this situation?
לייק 1
We recently added an All day event checkbox to the Create Event modal, which should address the primary concern here:
(For reference: FEAT: add all_day option to calendar events by tannerabread · Pull Request #38511 · discourse/discourse · GitHub )
If there’s anything else we need to do here, please let me know or feel free to open a new topic!
לייק 1
This topic was automatically closed after 2 days. New replies are no longer allowed.
