הוסף סימניות לסרגל הצד
סיכום מבוסס בינה מלאכותית
Add Bookmarks to Sidebar Discussion Summary
The discussion revolves around the idea of adding bookmarks to the sidebar, with some users arguing that it was previously buried in the user menu and is not easily accessible on mobile devices. Kartoon suggests that having a direct link to bookmarks in the sidebar would be more useful than having categories, as users tend to have specific topics they’re interested in.
There are differing opinions on how to implement this feature. mcwumbly asks if users want a single link to bookmarks, a whole section, or something else. Kartoon suggests that either option would be preferable, but leans towards a whole section.
However, Jagster expresses concerns that having bookmarks in the sidebar would make it too cluttered, especially with a large number of bookmarks. mattdm suggests making the section collapsible, optional, or showing only the most frequently used bookmarks.
sam proposes that adding bookmarks to the sidebar might be a temporary solution, as the ultimate goal is to allow users to define custom sections in the sidebar where they can add any links they want. This would give users more control over their bookmarks and allow them to create a static section that fits their needs.
Overall, the discussion highlights the need for easier access to bookmarks and the potential benefits of adding them to the sidebar, while also considering the potential drawbacks and alternative solutions.
I’m having the opposite response, a lot of users have asked if they can get bookmarks there because they either don’t use them now because it’s buried multiple menus deep, or they suggest they would use it because almost universally having specific topics there instead of specific categories has been opinioned (although you wouldn’t have to remove the categories part to add this) as much more useful. Because all the categories you can just click on without even having to scroll much (or at all) whereas topics are two/sometimes three layers deep to navigate. I’ve honestly never even noticed the bookmarks there and I would wager others haven’t as well. Although I also think the Bookmark system as it is is fine, it’s not so much about changing THAT just adding SOMETHING related to individual topics to the sidebar.
Instead of moving the bookmark section out if it’s an issue the the initial idea proposed by this topic seems like a good alternative? Either a button in the sidebar (like how you can edit categories/tags), or a button on topics (or on the topic menu). It wouldn’t have to interrupt the bookmark system because these ones don’t necessarily have to give notifications or anything, and (IMO) also serves a different enough function (quickly jump into a topic/monitor it but not have a need to be notified) right from any page. Or even if it’s a redundant bookmark alternative I don’t see that issue with that either; before the sidebar I had Theme Selector in the old hamburger menu, as well as the (slightly more detailed) one in user preferences, same case as that.
6 לייקים
I’m curious which one of these things you had in mind:
  • a) A single link named “Bookmarks” that’d take you to your bookmarks
  • b) A whole bookmarks section in the sidebar, which would list individual bookmarks underneath
  • c) Something else
We did used to have (a), but took it out when we added bookmarks back to the user menu (as Kris mentioned earlier).
5 לייקים
I think either of the first two would be preferable, though personally I think the second option is the best one.
As it is currently the bookmark section is buried several menus deep (and I would almost say not intuitive at all on mobile). In most cases I would think having a direct link to a couple topics you want would be far more useful than say categories, because for the majority of sites (especially if trying to be efficient, which would be the group to utilize the sidebar at all) they don’t have such an expansive range of categories that having a one-click to ___ section is more convenient/saves times/whatever the use case. This is site specific of course, I’m sure some have lots of new topics in categories whereas some have a lot of posts in specific topics in the categories but even looking at it this way I’d say bookmarked/followed topics would be AT LEAST as useful and relevant/helpful as tags and categories. I have a mix of both on my site but my users all have a couple of (different) specific topics that they’re most interested in, and then will just browse the general categories.
There’s also already a precedent for having something in the sidebar and also in menus; both PM Inbox and Chat channels are (imo) more easily accessible from anywhere on any page in their normal spot in the top right then navigating to bookmarks which requires completely leaving the page into preferences.
All that aside, if that would be too cluttered Option #1 would serve a similarly useful function. The old Hamburger Menu had a theme selector plugin that was VASTLY easier than navigating multiple menus to change your theme (literally two clicks from anywhere) and I wouldn’t be surprised if a poll was taken a decent % of users wouldn’t even know they can change their theme from their profile unless they were specifically directed to it (then remembered) vs seeing it in the front menu (convenience aside) and IMO this applies even moreso to bookmarks. The Theme Selector has also now been reintroduced into the redesigned sidebar, it shows up at the bottom by the keyboard shortcut menu which makes it fantastically accessible and immediately noticeable.
If the sidebar wasn’t a thing I wouldn’t particularly have any feelings about changing it, but since it exists (and there’s comparatively a lot of space) it makes sense with the existing use of it. You could even make it so the sidebar sections themselves (tags/categories/bookmarks) can be turned on/off by users if crowding is a concern (you can already just leave them blank)
2 לייקים
I have 20+ bookmarks here. If those jump to sidebar and makes it a mile long, and I can’t modify it, I will jump off right away,
No admin can’t tell to me what I need on such trivial case, when deep dive to bookmarks means opening hamburger and one single click :wink:
There is absolut no idea what so ever start building the sidebar somekind centralized link farm of a forum. Or there must be an option to overdrive admin’s (personal…) preferences.
Currently, I use the user menu for quick access to bookmarks in these ways:
  1. I set reminders quite often. When they fire, I see the notification
  2. Aside from reminders, other bookmarks are shown on the tab
  3. I can double click the bookmark icon in the user menu to get directly to bookmarks.
Maybe that’s not all too discoverable, but can you play around with that a bit and let me know how well that serves your needs?
Allowing a user to customize what sections they have is certainly something that I think we’ll be thinking about, regardless of what we decide to do with bookmarks.
לייק 1
I was thinking about that too. What if it were a collapsible section? Or if pinning a bookmark to the sidebar were optional? Or if it showed your five most-frequently-used bookmarks and then “more…”?
לייק 1
I’m just wondering why we should have same content behind as many clicks (one…) on left and right side of main content.
Without extra tuning that would be quite… something on mobiles.
I feel like this would be a stopgap anyway, given we want to give users the ability to define custom sections in the sidebar where they add any links they want.
Bookmarks tend to pile up. With a sidebar custom section you get to properly put a lid on the problem and have something static that fits your particular needs. Users can also give them punchy short names which will fit visually into the sidebar.
5 לייקים
