@sam I took your suggestion … deleted all the cookies and I still hit the bug.
Please see the attached video:
I can go back and forth between two sites at the same domain, different subfolders, and I don’t see anything out of the ordinary hitting the auth logs.
6 - seen token
5 - rotate
4 - seen token
3 - rotate
Those don’t happen very often.
@neil I can give you access to my system remotely if it helps you debug.
I am able to replicate the bug in the video every time.
I believe you, but subfolder debugging… ugh. Still working on it.
So you deleted your cookies but still have the problem?
Hmm, the problem definitely goes away for me when i’ve cleared cookies. Do yours look like this now?
I reverted the other fix, so you should undo that change since it’s worse behaviour than before. I don’t understand what you’re seeing, or how to fix what I’m seeing.
maybe its time for big boss @sam to step in !!
We are deferring on this for now. Running two instances of Discourse on the same domain in different subfolders is not a supported config at the moment. We may circle back to this in a few months, though.
makes sense … being able to say 'No" creates a great product.
We will give another go at this soon.
Please close this issue. It works now. By setting the DISCOURSE_TOKEN_COOKIE env var.
Well done !!
As @vikaskedia mentioned earlier, there is a workaround. You can use a different cookie name for each subfolder by using DISCOURSE_TOKEN_COOKIE
in your configuration.
However, there is still a bug here where cookies are not properly restricted to paths on subfolder installs, causing conflicts with their sessions. The only solution is to use a different cookie name for now.
A better fix from a security standpoint would be to restrict to the proper subfolder path per cookie.
Can you scope how much work this would be, in terms of “T-shirt sizing”? Small, Medium, Large, XL, XXL?
Somewhere between small and medium. It would log everyone off though when “fixed / changed”
Hmm that is fairly traumatic. Is there any way to fix it so it only logs people out on subfolder setups at least?
